Baker
Everything posted by Baker
  1. I have finished planking the deck. This work took a while. To prepare each plank separately before gluing on the model, takes more time. The advantage is that no more sanding has to be done on the model. So there will be no dust on the model itself. The base for the whip staff has also been made. It has not become a deck with a nice equal planking scheme. So, my apologies to everyone who does not like this. Whip staff deck Thanks for following
  2. Very nicely done and beautifully made I will follow this build.
  3. Ola, (Long live Google Translate )
  4. Some people say : "a drink a day, keeps the doctor away" But for me An hour of modeling per day, keeps the doctor away Patrick
  5. Welcome to MSW. Greetings Patrick
  6. Welcome to MSW and good luck with your build. Patrick,
  7. Short update, The rudder is cut loose from the hull and the bolts are placed. Now can be started with the further finishing of the hull
  8. ps I also use google translate
  9. hello Steven, If I see it correctly on the photo. I think your first frame on the upper right side is not in line with the rest.
  10. indeed. Just look at the topic below In those days the hull planks were 4.2 to 5.2 meters long. suppose that deck planks were 6.4m long (640 cm) Then a deck plank on scale 1/64 can be about 10 cm long maximum ( 4 inch). The deck planking on my Golden Hind will have bits and pieces.
  11. En groetjes uit Belgie.
  12. too long is not a problem. you can bend the tracks a little down between the return rollers. This calls "a sagging look" i think.
  13. Danny, Tracks on a scalemodel can always be a bit too long or too short (Unfortunately, I have already experienced this a lot...) Do not glue the tracks before you are sure that the length is correct. I would first place the front and last wheel (bottom rollers) then you see if the tracks have the correct length. The track tension is controlled with the idler wheel. Nice work.
  14. Thank you, In the meantime, a cautious start has been made with the fitting of bolts. These must be carefully sanded later And an attempt to imitate the "nails and planks" "bolts and nails" are made of stretched spreu
  15. And good luck with your first wooden ship
  16. Groeten uit Belgie
