Posts posted by petervisser
I'd like to plug Oxford Companion to the Seas. Lots of wonderfull info in alphabetical order no less! It covers a broad range of topics and should answer all your queries. The book is widely available on the internet at a very respectable price.
Cheers,
Peter
Having built the Billing Bounty, I can tell you it is no easy feat for a first time builder. The Bounty was the 4th Billing kit I tackled, so it with the experience gained from earlier builds and lessons learned, it was a very rewarding and enjoyable experience. And that's what you want out of this challenging hobby. A project that you can start and finish with minimal frustration and maximum pleasure. There are countless unfinished models out there where the builder went in with the best of intentions but a lack of tools, experience and patience. And there is nothing worse than tossing out a perfectly good kit that has been started and never completed.
If you are still keen on building a model ship (and who wouldn't be?...) then pick a kit that you really like the looks of, and figure, hey I can do this! Billing make some very nice kits in the beginner and advanced beginner category which you might be interested in.
I have included a picture of my own Bounty with this post. The rigging alone should be enough to scare you away....🙂
Well, the railings are completed. It was a bit of a slog. The first coat of primer took 2 hours to apply to all the railings. Phew. That was a bit much, my neck and back told me. Thereafter I painted them in sections as they still wanted two coats of white. But now they're finished and I am pleased woth the results. Modelling will now take a back seat for a few months as summer is arriving and the outdoors and the yard call for some attention instead. I hope to putter with the ships boats during rainy days, whenever they happen. Cheers guys!
Thanks for the tip guys. I'll try that in the future. I have an ancient Danmark kit that has a ton of railings as well. And thanks for looking in too!
Peter
Hi All,
I have been busy in the shop of late due to the self isolation and making some progress. But boy, there is no rushing with a model ship so things are going slowly. I have been detailing some more of the main deck and added some fairleads and mooring bits here and there. I have also tackled the railings on the foc'sle and aft deck which went rather well considering. I tried my hand a soldering and it went so-so. In the end, I found that they didn't need it, and all is well seated without. I had intended to solder them so I could paint the railings off the model. But they looked so good without solder that I decided to paint them in situ. Therefore I had to tape off the stanchions at the base. Now the tedious painting begins. One coat of primer and two top coats. It took 2 hours for the first coat. Yikes. As mentioned earlier, model ship building is not done at lighning speed...
- hof00, WalrusGuy, Vladimir_Wairoa and 8 others
- 11
Thanks for the spreadsheet Allan. When it becomes the Danmark's turn to appear on my bench, your rigging plan will come to good use!
Cheers,
Peter
Hi Keith,
Your model is looking fantastic! Have you been able to use all the Billing fittings or have you had to resort to buying third party fittings? Having built a few of their kits myself, I have made due with what they supply but sometimes resort to poaching bits and pieces from other kits I have that are still in the box. I am tempted to purchase the Billing Victory myself. Your model makes it very tempting...
Cheers,
Peter
I just finished up the labour intensive work on the deadeyes on the main deck. It was a multi-step process that invoved some "metalwork". Billing supplies the chain plates and a bunch of plastic deadeyes. I opted to poach a bunch of deadeyes from another kit so as to use the chainpates that were provided. It would not have been easy to use them together. Once the chainplates and deadeyes were married, I used a drop of glue to make them rigid so as to paint them easier.
Here's a bunch of pictures showing the process...
Have to say I have always put black thread between the seams of the planks on the decks of my models. I realize that others do it differently and I really admire some of their techniques, but to each their own. As for the procedure, I now have a method that works for me. First I give all the planks a preliminary sanding before I glue them to the false deck. Then I lay down a plank to glue it. Before the next plank is put down I wax and lay down a black thread adjacent the plank. The wax helps somewhat in keeping the thread in place. Then the next plank is glued down adjacent to the thread, which provides the space between planks. Once the planking is completed, the threads are removed. The planking can now be sanded again to remove any glue and smooth out rough spots. I also take a #19 exacto blade and run it dwon the seams to remove any glue that might have got left behind. Then the thread is laid down again between the planks. I like my decks lacquered so I apply a coat as the threads are laid down. It takes a couple coats of matt lacquer to finish off the decks for me. I realize it's a bit of a process but I like the results, so I keep doing it. Not for everybody I know, but hey, we're snowflakes, we're all different. Here are a few pic's...
- BLACK VIKING, GrandpaPhil, mtaylor and 3 others
- 6
After just about snapping off the bowsprit (several times) and the dolphin striker (once), it was time to take some preventative measures. I decided to "splint" the offending spar so as to avoid some dfficult repairs later on. Here is my solution. Once the bowsprit has some standing rigging in place, I can dispense with the milk carton.
Finally, here are some photos of the gunwale stanchions and trim along with the attachment of the foc'sle deck. I didn't think I would bother with the trim and stanchions but other builders of this model added them so I had to try and keep up. I have finally found a re-purpose for the styrofoam trays our meat gets packaged in. They are perfect for holding tiny fittings while they get painted!
What with the foc'sle deck being added, I had to afix the bowsprit in place. This made the model instantly longer by 8.5" so it is alot more susceptible to damage. Yikes!
- marktiedens, ccoyle, gieb8688 and 4 others
- 7
The hull trim has also been added. The strips were pre-bent and prepped with paint or stain before they were nailed/glued to the hull. This whole process was pretty tricky and it did not turn out perfectly, but it will have to do. Next time around I think I will glue them on while the hull is bare wood and paint or finish them in place with masking tape. I did however rough up the paint with sandpaper so that the glue had a better chance of holding.
- reklein, marktiedens, etubino and 5 others
- 8
Well, work has been progressing albeit slowly. The decks are finally all caulked and several layers of varathane applied. This is what they look like now...
- etubino, marktiedens, gieb8688 and 4 others
- 7
Your ship must be getting to be a challenge to lift and move. She looks amazing!
Peter
- Andrea Rossato and mtaylor
- 2
Holy cow! By that I mean your model is going to be the size of cow! Amazing. I am building my Cutty Sark at 1:75 scale which means yours will be twice the size. And I thought I had my hands full...
At any rate, you have done an amazing job so far. The engineering alone of building a ship to this scale is very impressive and I wish you all the best in going forward. I have to follow along as this is one of the most impressive builds I've seen.
Cheers,
Peter
- mtaylor and Vladimir_Wairoa
- 2
Hi Jens,
Just looking in and am really impressed by your model. I also had a look at kpunts Cutty Sark just now and its amazing how this model gets the treatment by various modellers. A real inspiration for me. I am envious that you are working on the masting and rigging already. You have done beautiful work in prepping the masts and yards. I wish I had your talent for making all the fittings for them.
All the best going foward!
Peter
Your model is looking mighty fine. I am neck and neck I think in our build of this model although I am building the Billing version. It's always interesting to me how each one of us tackle their model with regards to how and when bits and pieces get added. I really like how yours is going and it will be stunning when completed.
Cheers,
Peter
- samson and popeye the sailor
- 2
Hmmm, and I thought they specialized in latex...
- Julie Mo and Duanelaker
- 2
Hi Allan. Fantastic work on your masts! They look like the real deal!
I came across this youtube video which you have probably seen, but maybe not. I really enjoyed watching it. Not the best quality but the ending is kinda fun!
- coxswain, alpayed, Kenneth Powell and 1 other
- 4
Thanks for the words of encouragement guys. Now that there is some colour on the model, it really starts coming together. I just realized that there needs to be some white trim added to the hull and some decoration. I will start prepping that while I finish the decks. So much to think about and plan. Kinda fun really.
Peter
I used the Zinsser sanding sealer to prep the hull and get it nice and smooth. That took several coats, but with this scale of hull I wanted it perfectly smooth. Then several coats of Humbrol enamel paint were applied by brush. Finally the copper plates were applied to the hull. I picked up the copper tape from a shop that specializes in stained glass supplies. The roll of 3/8" tape is 36 yards and cost me about 20 bucks Cdn. That process was a bit of trial and error, plus more errors and some more trialling. But finally I had them all on to my satisfaction, Good from far, but far from perfect. Anyway, here are some pics of the process...
- Jolley Roger, sferoida, samson and 7 others
- 10
Well, things have been progressing in the ole shipyard. I worked on a bunch of the fittings for the foc'sle deck including the bowsprit so that I can eventually finish the decks and put the foc'sle in place.
Once those little jobs were done I could start work on finishing the hull.
Hello Jens. Really nice work on your masts and yards. I especially like all the fittings you made. Where did you learn to make such detailed fittings?
Peter- popeye the sailor and samson
- 2
Zeeschouw by petervisser - FINISHED - Billing Boats - Scale 1:22 - Small
Hello Jan,
Sorry for the late reply, but I have been absent from the site for some months. As for "stepping the mast", I think I attached the bottom supports of the mast to the mast itself and then used tiny dowels to glue the mast supports to the deck. It's not too secure as you can imagine, but the standing rigging is what will secure everything properly.
Jan (Amateur) is correct when he states that mast hoops are not normally used on Dutch sailing vessels. But I had the mast hoops on hand and they are easier to bend the sail to the mast. Easy way out, that's me...
Now that the fall/winter rains are back, I hope to resume work in my shop. I would love to see photos of you model and feel free to ask any more questions you may have regarding your zeeschouw! A PM will get a quicker response. 😉
