Tigersteve
Everything posted by Tigersteve
  1. I like the way you worked through the scale of the oars. Looking forward to the final presentation. Steve
  2. Wood project source is very good also. http://www.woodprojectsource.com/ Steve
  3. Two planks remain on each side of the hull. A rough sanding was done with 180 grit sandpaper. More sanding with progressively finer grits of sandpaper is needed later and filling. Even hard maple gets gets thin enough to become transparent! My planking still needs work. Steve
  4. The structures came out great. I like the idea of one door kept open. Steve
  5. I suggest sanding as smooth as possible first, then fill, then sand again. You can mix the sawdust from the basswood with white glue to create the filler. Mix the glue and sawdust until it's a paste consistency. Just a tip that has worked for me. Steve
  6. Ed, I for one am definitely appreciative of your writing style and greatly looking forward to how it all comes together in volume 3. Steve
  7. Well worth the wait. Best Syren on the block. Steve
  8. Thanks for the compliment, Ken. It's just a small clamp that came with a set I bought a while ago. Here's a link to a similar set. HyperTough 8-Piece Hobby Clamp Set https://www.amazon.com/dp/B01AFHANF4/ref=cm_sw_r_cp_api_QGCMzbV3GR569 Steve
