Tigersteve
Everything posted by Tigersteve
  1. Thanks guys! All the bulkheads are squared and braced with wood strips. This is absolutely necessary. The squaring process was more difficult with this one than with the longboat due to the amount of thin bulkheads. I'd say they're about 98% square. The filler pieces and transom have not been added yet. In the photo there is a 1/16" x 1/16" strip that will be used to shim the bulkheads where they meet the bearding line at the stern. Steve
  2. Echoing the above comments, Mike. Try a trophy shop for the nameplate. Steve
  3. This work inspires everyone to work to another level. Steve
  4. Very nice crafting of knives. Hope you feel better. Looking forward to more progress on your ship! (Hint, hint) Steve
  5. Mike- congrats! It came out great. Finally started mine and not looking forward to planking. ;-) What's the next project...Mayflower? Steve
  6. The hull is looking good. I would change the font on your settings though so it's easier to read your post. Steve
  7. The false keel, keel, and stem were glued on top of a piece of glass. There was a slight space between the stem and keel. I added a small bead of glue to seal the gap. Squaring the bulkheads is next. Steve
  8. Yes- start a log, Walt. We'd like to see your progress. Believe it or not there aren't too many logs of the Pinnace on MSW. Steve
  9. A slow start, but here we go...First task was to sand the laser cut sheets. I removed all bulkheads, false keel, keel, and stem. Currently working on creating the rabbet using Chuck's method of pinstripe tape. To create the taper I'm using sanding blocks. Steve
  10. In Chuck's instructions the photos are even more clear on this one than the longboat as to how the garboard is shaped and placed. My plan is to line off the hull using a planking fan before laying them down. This should give the correct shape. After lining out the hull and making a test garboard, I also edgebend the next plank to make sure it curves around the garboard. If it's too severe, I adjust the garboard to a more gentle curve. I do this before gluing them down. This process is very time consuming, but necessary. Bob F used this method for the first couple of planks on his longboat. Hope this helps. Steve
  11. That's looking really good. Looks like the planks are lying against the bulkheads and not lifting. I also bent the planks that way for the longboat and cut off the excess. Bending the plank that hugs against the garboard was the most severe. Been sanding and removing parts from my laser cut sheets and prepping the keel. Hope to post some pics soon to join you in this project. Steve
