GrandpaPhil
NRG Member-
Everything posted by GrandpaPhil
Lancia Assunta by maurino
GrandpaPhil replied to maurino's topic in - Build logs for subjects built 1901 - Present Day
Congratulations! Very well done! -
Papegojan 1627 by mati - FINISHED - 1/48
GrandpaPhil replied to mati's topic in - Build logs for subjects built 1501 - 1750
Nicely done! -
I use the thread needle method (CA on the end) and then cut it at an angle. It works well for me for all rigging fittings. Plus, if you have a difficult to thread area, you can also mold a curve into the thread needle to be able to grab it with tweezers on the other side of whatever you are feeding it through.
It’s steel. I usually just paint them. I’ve never had a problem with corrosion. Although, I tend to clear coat everything, too.
I like to use annealed steel wire from the hardware store. It bends easy, but holds its shape. Plus, it’s already blackened.
Thank you very much for the likes and just for stopping by! I set up on the back porch today, to carve outside. I could not pass up the weather. The main lantern is carved: It’s made out random square hardwood stock, that I had, that was the right size. This is the second attempt, the first one failed catastrophically. I’m not the greatest at three dimensional carving, but I’m getting better!
The Ensign Staff is made and glued down now. I figured out how I will make the lanterns. The lanterns are too small to make it worthwhile to make the sides from clear plastic (10/32” tall). The framework would have to made from thin thread or equivalent to be in scale. Also, any adhesive that I know of, that would actually bond with any strength would make a mess of the lantern. Therefore, I am going to carve them and use war gaming painting techniques to make them look internally lit.
The 100 Gun Ship Victory (Anatomy Of The Ship) by John McKay has very good rigging plans. Those are what I am using for my Victory. The sail plan is not the greatest, but there is a side-on view of the Victory in Brian Lavery’s “The Ship” that I am going to use to make the sails.
The flag lockers are done and a few minor detail pieces have been added. I rough made the Ensign Staff. It started out life as a bamboo kitchen skewer. It still needs the cap piece, to be painted and three sheaves added. I am done with most of the deck furniture now. I am going to start at the stern and work my way forward, finishing all the rigging fittings, boat davits, remaining hull fittings, hammock cranes, etc. To that end, I’m going to start with the lanterns and a couple of fittings on the poop deck.
