cog
Everything posted by cog
  1. Thank you, Kortes. It is a delight to follow your build!
  2. what are you drilling? portholes ... I did them by hand ... to kill some "spare" time
  3. Stevendtslag should be Stevenbeslag de Steven is the prow Real astonishing work, Kortes. How do you weld/solder the parts?
  4. nice details. Do you use silver solder on the rings, or the standard one
  5. how thick is your primer at the armour plating? If you don't want the etching to be to visible/sharp edged, could it be possible to etch, and have another layer of primer on top, or would that make the etching invisible after painting ...
  6. It seems even Murphy can't keep up, OC. Hope things get back to normalish soon
  7. interesting setup, Gaetan. You made the intricate swivel arm youself?
  8. maybe wait till things get less murky ...
  9. Jack those are Schmincke pastels, artists quality, as the "grain" is much finer
  10. I prime everything with either Tamiya rattlecan or Tamiya surface primer. The latter to touch up or for small items which I build/shape off model, and add later You could add thinner/water to your paints, which is what I do even when using a brush. You might need an extra layer, but it doesn't look sluggish. The deck of my model Tribal Destroyers are painted by hand with Vallejo Air mixture 1 prt Prussian Blue (71 109), 4 prt Steel Blue (71 087), 13 prt Blue Grey (71 115). On top of that I use White, brown, red, yellow, cobalt blue and black pastels, applied with a small hard bristled brush (pigs hair) round straight tipped. I found that the colour is still to dark, so next build I will have it mixed with 10 - 25% light grey to tone it to scale example: the superstructures B-turret platform
  11. it seems the further we are "digitised" the less social and humane we become. I get the feeling some organisations think we have the StarTrek transporter at hand and money is no longer an issue Get some rest and try to keep your spirits up, you know where to find us ...
  12. Sorry to hear about the missus. Hope she's doing better. Give her my best wishes, and lots of strength to you mate!
  13. Like the swivel chairs, and the high tech screens ... you really know how to fill the nooks and crannies mate ... mind boggling ...
  14. Thanks Patrick a lot of praise from someone so versatile in modelling tiny crafts Thanks for the wishes too, I'll get back to you on that subject a wee bit further on in the month
  15. Your work at the ropewalk is becoming as fine as your detailed brass work, Johann. You have set yourself a very high standard ...
  16. Kortes, Marvelous metal and wood work on those leeboards
