BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. Hi all, There is also an interesting paper by Mark Staniforth on the subject at: http://www.academia.edu/358814/The_Introduction_and_Use_of_Copper_Sheathing_-_A_History - you have to signup to download the pdf but it is free; and the article can be read online without signing up. he also has some other interesting topics. cheers Pat
  2. Now that will be one very nice model when made up. Thanks for the extra pics; shows off this little lady's lines very nicely. cheers Pat
  3. Hi Kier, the rabbet is not a scary beast Simply, it should be the depth to accommodate both layers. However, this does not mean twice as deep as usually the first layer is much thicker than the second layer. This second layer is usually just a veneer and very thin. So just make it as deep as the two combined. lay the first layer and there should be a very thin fall about the thickness of the veneer. cheers Pat
  4. That looks great; and side or front/bow views? the error is probably evident to you but I cannot see it cheers Pat
  5. Your a brave man Jason; taking a file to such small detail details requires good nerves and steady hands - but, the result is excellent and looks a lot better - well done mate. That stern will look so much nicer with all you attention to detail. cheers Pat
  6. Not necessarily so Ken, for me at least, once I have conceptualised what it is I need to make, I find it is far easier in the workshed. Using your virtual creations you can experiment with copies of each piece and break them into manageable parts. I am in the very early stages of learning 3D just for this very purpose. Nice work on the virtual modelling; look forward to seeing it all come together. cheers pat
  7. Slow but steady will get you there Coming along very nicely. cheers Pat
  8. So, all these bits and bobs will sit on the wood things you walk on, which fit to the tub that keeps it afloat then .... Nice work! cheers Pat
  9. Great to see you back and obviously refreshed from your holidays Glenn. That is a great technique you came up with for the tarred roof, looks very authentic. The model looks great and is a testament to your skills. cheers Pat
  10. Seems you have resolved it quite nicely Dave; good bones = good body they say cheers Pat
  11. Welcome to the Endeavour club Rexy; I am sure you will enjoy this build and it appears you have made a great start. Plenty of build logs on the site to get ideas and resolve issues. cheers Pat
  12. I wish I had seen that traveller ring before I tried making one Chuck, far superior than the one I made. I wish I has your forethought to think ahead, but alas my bowsprit had already been assembled and I would have caused more issues trying to fit it. I will order a couple though, they are great looking travellers (and hooks). I did utilise your plastic ones in areas on low stress, and they worked a treat. cheers Pat
  13. JP, I purchased the MM feather boards for use with my Jim Byrnes say. The bars were not the right fit for the mitre slots so I simply replaced the bars (can't think of the correct term at the moment) from some spares I had. You could easily make them from hardwood, add a little wax for slide, install a bolt from underneath in a countersunk hole(s), at the appropriate point(s) so that it clears the top of the featherboard, and then add a washer and wing nut (the botlt etc from the MM featherboard can be utilised for this) - Voila As the feather boards have a slot pre-cut, this makes them easy to adapt to other mitre slot bars. If, like me you have a spare, unused or another bar from something you can sacrifice, the job is already done and you will have something that precisely fits your mitre slots.. cheers Pat
  14. The left/right thingy, and all your other work, is very well done Kishmul, this will be a very nice model when converted from the virtual to metal and wood. cheers Pat
  15. There are some very fine models shown on this site and yours is amongst the very best Alex, exceptional craftsmanship. cheers Pat
  16. Thanks for explanation of the materials, and the processes you are applying to this build. Great work at such a small (micro) scale. cheers Pat
  17. Watch that light at the end of the tunnel Denis, it might be an oncoming train Seriously, with the end in sight you must be pretty happy with this build as it looks great. cheers Pat
  18. Thanks Nils. While the ship is complete, i still have two small boats to do which are now underway) cheers Pat
  19. Hi Mike, missed you and welcome back mate. Onto the club build of HMCSS Victoria (see scratch build logs); some progress made but a lot of research still to do. cheers Pat
  20. Missed your calling Greg; Holden (GM for non-Aussies) would not have shut up shop if you had been their production manager cheers Pat
  21. Nice work Rusty, they look nice and "tidly" the "Jimmy" will be very happy with that cheers Pat
  22. Looking really good Ulises; some nice detail there and a great looking finish. cheers Pat
  23. You may still need a spreader bar or two near the base of the shrouds though Denis. cheers Pat
  24. You'll just have to sniff on that Old grouse then Carl! cheers Pat
