popeye the sailor
  1. I hear you on that! looks good though.....also glad to see your still working on her. nice detail work!
  2. thanks Dragzz and Matti........this past week has been hard to get anything done! I'm seeing light at the end of the tunnel though, and I should be back at the table.
  3. the most I've had with that, is that I didn't scrape away the paint enough, and a pin rail came loose on the inner bulwark. if you've done that, you should be fine. usually, if I know that associated parts are to be the same color, I will assemble them first, then paint.
  4. glad to see you back Andy! been out of the loop for a week or so.....now I have to play catch up! with so many different colors in primers these days, it's nice to be able to take your pick. one thing to consider though, is the hue the base coat is going to give the color coat. red sounds like a good choice.....and gray is such a solid color. it is going to deepen the gray, but hopefully, you won't get any sort of a reddish hue. you'll have to do light coats.....with all those angles, there is a threat of gathering in the corners. you might want to wait after the base is done, to give it time to fully cure. there's nothing worse than reanimated paint no jealousy here Augie......only that Andy has a new and exciting model to build. I think he's too shrewd to fall into the same pit as I did play on......after you ply on Andy!
  5. great looking flooring Augie.........you mean to tell me that all this time I was taking the long way around! I never thought to do it that way! that would sure beat playing with individual tiles.....but for what I did, I guess that was the road I had to take I'll have to try this out :) thanks to Chuck as well nice overall look at your progress.....I've been out of the loop {so to speak}. you've really made some terrific progress. look forward in seeing the deck work!
  6. been out of the loop for a week or so.....you've more sweet work on her! looking awesome!
  7. been out of the loop for the last week or so.........I must say, you've made some great progress! good to see your moving ahead.......looking really sweet!
  8. sweet looking build B.E. great looking ship! looking forward in seeing pictures of the hull Nigel....... to me, there's something cool about building an old kit......reminds me of when I build the Nordkap. truly a lucky man to have the chance at this baby!
  9. just a small glitch that happened a while ago........yea...you'll need to put them back in, if you want to keep your log in good order I still have one that I need to redo the whole thing. wishing you a happy birthday......I love to be as free, as you are right now!
  10. nice fix on the fore castle deck Bob.....all that's left to do now are the two lockers
  11. I am as well Dave.....but sadly, much of my tool buying has been geared toward the automotive field. when I quit the garage, I went into warehouse work. now I work on trailers......been doing this for about ten years now. I have quite a few specialty tools for automotive.....stored away in my garage at home.
  12. pulley assemblies look very good......which looks good on the cannon placements. sweet job all the way around
  13. very nice progress.....if your going to add weight. do you have the quadrants compartment-ed out? {fore / mid / aft}
  14. if I'm correct, these saw work off of a spring tension in the upper part of the arm. the tab on the end is pushed down to insert a new blade. the end under the table is the reciprocator. do you have a manual, or an exploded part's view to look at?
  15. Your Craftsman Scroll Saw/Sander was thoroughly inspected to rigid standards prior to leaving the manufacturer's factory and should give you many years of satisfactory service. Occasionally when the Craftsman Scroll Saw/Sander is removed from its carton and the table attached, the user will notice that the blade does not appear to be perpendicular to the table surface. Before attempting to correct this condition, first check to see that the table is in its horizontal or zero degree( 0") position. Use a square or other right angle device (a piece of paper will suffice) to check the blade position relative to the table surface. if the blade is not perpendicular to the table, simply push the upper arm of the saw frame in the direction that will correct the blade alignment. Handling the saw by holding the upper arm of the saw frame can also cause the saw blade to tilt from the true vertical position. this is not an unusual condition and can be easily corrected by, again,applying slight pressure to the upper arm of the saw frame in the direction that will correct the alignment. if the user avoids the natural tendency to use the upper arm of the frame as a handle when lifting or moving the saw, there should be no further need to realign the blade. Figure 5 shows the proper way to pick up the Scroll Saw. Before deciding on any adjustment, it is recommended that you operate the saw and make some trial cuts so that you can experience scroll cutting. Be sure to check the mounting of the saw blade in the blade holder prior to cutting. Generally the blade is mounted so that the teeth are facing front. However, the blade can be mounted with the teeth facing the side. Always have the saw teeth oriented to a downward cut. Boy.......I didn't think it was this hard to copy and paste a section of a PDF manual, but the spelling was so jumbled! almost a waste to have posted this. it's not the problem. I got an old Craftsman scroll saw from a pawn shop......it has a built in side disc sander, but I don't have those parts. with the way that this scroll saw is made, I can see where this problem would arise....I found myself doing the same thing. from what I can see, there is no adjustments for the tension of the blade. what I have noticed though is that the blade suffers from deflections while it is in operation.....there is no built in guide for the blade, as it comes through the table. your looking at a 1 mm thick blade, coming through an opening that may be around 5 mm wide. even if you were to use {or make} a guide for the piece your cutting, adding to much pressure to the 'work' will make the blade 'walk' side to side. if your using a guide......work very slowly, allowing the blade to cut it's path. I thought I might have saved the link to the instructions and stuff, but I guess I deleted them. I would suggest making changes in the way your cutting, and see if it works out better for you.
  16. thanks for the good word and all the likes! I took Monday off......hopefully I can get more done on her thanks John thanks J........just the bow spirit for now....I have a few more parts that will go on the bow area. with the spirit in place, I can get a better idea of where the other parts go thanks for the good word! the Tee shirt idea.........I like it!
  17. glad you made the trip....you two what a great way to spend a birthday
  18. I cut out the 'punch outs' for the insert that I spoke of earlier. the part is not laser cut, so I drilled some holes in the areas that needed to be cut out. Iused my scroll saw for this. I wasn't the steadiest when I cut them out.....I may go in a different direction with this. this is a really thin plywood......very stiff and tough to sand, as well as work with. all I have at my disposal is either 1/16 and 1/8 basswood flat stock. the grain of the wood, either way is going to play a big part in how sturdy one would be...I've already tried to make a second one.....I don't like it. anyway, this one didn't come out as well as I would have liked it to. so, I may try a different approach. I began to add the ribs to the interior of the plastic boats. I continued on........and soon they both were done. I still need to trim one or two of the ribs I took another Monday off.......I'll see what I can do further on them
  19. thanks Pete......this was done in my first build, a newbie idea http://wenzelswharf.wordpress.com/2011/07/01/the-nordkap-476-part-40/ http://wenzelswharf.wordpress.com/2011/06/29/the-nordkap-476-part-38/ http://wenzelswharf.wordpress.com/2011/07/01/the-nordkap-476-part-39/ http://wenzelswharf.wordpress.com/2011/06/01/the-nordkap-476-part-22/ these do have some aspects of the boat.........others are just for musing. feel free to browse around the Wharf.......I don't mind at all! this build was my kick start into this wonderful medium. for an already started build that was given to me, I truly enjoyed it. .....and I learned to bash.......something I think every newbie should try. if you think about it, it's the basis for all that one will do in a build......fashioning parts and making shapes. I continued looking for the logs where I made the boat......Eureka! http://wenzelswharf.wordpress.com/2011/05/26/the-nordkap-476-part-19/ just click on the links at the bottom of the page, and you'll see these logs in order. it all boils down to what is supplied in the kit before you, and what you do with the supplied parts. sorry to have gone on such a tangent Pete, but I wanted to show you how I got this idea.......more importantly, that I was a newbie when I though of doing it....I had not read of it being done before. thanks to you as well JesseLee.........in continuance to what I've been saying, truth be told......it probably has been done before. I can't really say that it was my idea.......I probably just brought it to the forefront again I'm glad I did though......it is a good idea. for those who are at a loss with scratch building, this is a great exercise for the imagination.
  20. I'm sure you'll figure that out. once you get organized......is it for fumes or for sawdust collection? if for sawdust, I think small sized dry vacs under the table {however many you think you'll need} might fit the bill. the lament will be, having to clean the 'pots' every now and then. I will look forward to the pictures......I really liked your last set up
  21. glad to see your back! looks as though your taking some lessons from the Wasa {Vasa}. I like it none the less......the imagination that is going into this build is very good......keep going! I look forward in seeing more!
  22. you've gone from massive rain to a drought!........I know all too well what your going through. I lived on a small farm when I was growing up. our water supply was from a well, and every August it would dry up. we'd have to truck the water from the river in 55 gal drums, for our use as well as the livestock. we would have supper early......after that was bath.....all of us down at the river....all eight of us {not including parents}. it was kinda cool, because it was the only time we'd see our mother swimming in the river with us ;D tried to get her to go off the rope we had in the overhanging tree......no dice I hope things turn around for you soon!
