druxey
Everything posted by druxey
  1. As your own master shipwright, you are on your own for this one. You will need to make your own decision. What you have learned is that you must check frequently for cumulative error as you go along, so you don't make this discovery at the end of framing.
  2. Another two strakes completed. The next strake will be the sheer strake. A smooth sheer line will make or break the model. Speaking of breaking, the moment of truth nears; that of removing the shell from the plug. From past experience there will be loud cracking nosies - heart-stopping! - and usually a few planks 'spring' a little, but it is all repairable. We shall see....
  3. Hubac: there are several museum examples of models where friezework on paper was applied to the planking. From experience, I can attest to how much easier this is than to paint directly on the model!
  4. Mark: I agree that the solid line/hatched line is another way to delineate a scarph joint (without the 'X'). Also, that there are regrettably few early examples of disposition of frame.
  5. Welcome aboard, Kirk!
  6. Mark: Certainly some toptimbers were scarphed, but I repeat that I've not seen too many delineated this way (with the 'X') on disposition of frame drawings. The ones that show this are later rather than earlier.
  7. The old-time model-makers were as crazy as we are, it seems!
  8. I see you did that that hard way: placing the fenders over the moldings rather than cutting the moldings to butt the sides of the fenders! The fit looks perfect.
  9. And another strake completed. As these strakes now run out over the transom, they are easier to fit. On closer inspection of the plans the uppermost strake, interrupted by the tholes, is actually a wash strake. It will be fitted after the shell has been removed from the plug. This means only three more strakes to go.
  10. Those joints were normally chocked at that time period. Chocks are more economic; not only do they uses up offcuts of timber but, with thoughtful layout, the individual floors and futtocks could be a little shorter than if they had been scarphed.
  11. Just catching up, Allan. Very ship-shape and Bristol fashion! Well done.
  12. Five strakes down; halfway there. If progress seems slow, it is. One strake can take an hour or two to complete. Each plank has to be spiled, marked out, cut, the joints refined, the free edge smoothed and then shaped and glued. After gluing the plank often needs finessing using the hot iron and water. Once the strake is complete, it is carefully sanded almost down to the finished surface.
  13. Good luck finding a new home. We'll await your return! Nice modification to those figures. It's hard to realize how small they really are.
  14. Yes, there is a slight concavity in the newest strake, Eberhard, but nothing extreme.
  15. So, another day, another strake on each side. Today it's strake 4. The junction at stern post and transom needed care. (I think Eberhard was wondering about this.) The plank runs were arranged so that the seam between two strakes would run into this junction. Another 'have to think well ahead' strategy. I also cut away the plug for safety here. (Photo order reversed!) Yes, Maury, I wash the planks well with a wet brush and mop up excess glue before it dries. In places such as the keel/garboard junction, I also use a dental tool (elevator) shaped like a mini chisel to clean out the angle. Thanks for stopping by.
  16. It's his mast-erpiece, Steven! Actually, it looks like a clip of some kind.
  17. Exactly, Maury. There is very little gluing surface. Hence the occasional frame.
  18. But that method means that the block cannot slip out of the line - the line would have to break first.
  19. Thanks for looking in, everyone. Progress will be slow. Fitting planks that average about ⅛" wide is exacting work. You can see strake three going in in this picture.
  20. Thank you, Craig. However, we are referencing pre-1800 building practice.
  21. Beautifully done, Daniel! First class work.
  22. Note to Alan as well: on smaller vessels where contemporary framing plans exist, I've seen nearly all with chocked toptimbers, but there is the occasional scarph indcated.
