Everything posted by druxey
Swan-Class Sloop by Stuglo - FINISHED - 1:48
druxey replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
The curse of having one's train of thought interrupted! So annoying. Looking at the chips coming off your edge tool in the second to last photo, I have two recommendations. Use a piece of hardwood as a cutting block. Using the cutting mat for this will lead to chipping out on the far side of the cut. Second, is the tool sharp and honed sufficiently? If you have difficulty maintaining a really sharp edge, Look at Lee Valley/Veritas' honing guide (with the narrow-blade head): https://www.leevalley.com/en-ca/shop/tools/sharpening/guides/101899-veritas-mk-ii-standard-honing-guide?item=05M0901 Together with a good set of stones, you will have surgically sharp tools. (BTW, it won't hold a short-bladed tool such as you show in your photo; a narrow chisel will be perfect for the job. I've no connection with Lee Valley other than as a long-time and satisfied customer.- 475 replies
I think Goodwin was correct. Check earlier illustrations of cable/messenger and capstan; everything is shown happening at deck level.
The Complete Modellist - 1667 shipwrights tables
druxey replied to bruce d's topic in Nautical/Naval History
It's a nice little book, isn't it? Congrats on your 1,000 mark. -
Looking very nice, Clare. The 'wood' looks very convincing.
- 175 replies
- hanse kogge
- shipyard
Bravo! That upper finishing looks very tricky to achieve.
- 589 replies
- le gros ventre
- cargo
Me neither! The Byrnes plate was a revelation to me when it first came out.
Looks like you are on track now, Stuart. The relative positions of the hawes holes look much better than before.- 475 replies
If at first we don't succeed....Good for you to stick (and unstick!) to it, Stuglo.- 475 replies
Fascinating to follow your lines of reasoning as you proceed.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Well, you are getting a lot of experience doing this.... After you've planked a complete hull you will be an expert.
- 740 replies
- Tudor
- restoration
(and 4 more)
Another rot-reducing measure were holes bored into the beam ends for air circulation. A longitudinal hole was drilled into the end for about a foot or so, then another smaller hole bored up from under the beam to join it. The inner surfaces of the holes were then sealed using red-hot irons to char them. Be sure to include this detail!
Completing that planking is a major achievement, Toni. Now roves at 1:48? Impressive! What kind of punch are you using?
