Everything posted by druxey
Miniature Russian carving tools
druxey replied to druxey's topic in Modeling tools and Workshop Equipment
You'll love using them! -
If the foot of the sail is about 5' 0" above water or more, I doubt if those holes were necessary.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
You should already have some semi-scratch or scratch building experience, mugje. Small power equipment helps: a mini circular saw and scroll saw make things go easier than using hand tools alone. Be prepared for a few 'do-overs'; this is normal even for experienced builders. The book is a step-by-step one, with lots of photos and diagrams as well as the plans mentioned above. A copy of The Fully Framed Model, Volume I is also very helpful if you are not already familiar with 18th century ship construction.
That's true, but seen at a later time when the steeve of the bowsprit was less steep and the foot of the sail was much closer to the water.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Taken one piece at a time it's not so intimidating.
- 221 replies
- queen anne barge
- Syren Ship Model Company
Actually, Echo has less frame components than Triton!
- 221 replies
- queen anne barge
Welcome! There is (or was) a nice maritime museum in Valletta that I've been to some years ago. Is it still there?
Did you have to do much thole-thearching before correcting things? (Sorry, Steven, but I can never resist!) Well done for revising them.
Is it possible that you know someone who can cut wood to size for you? Are there other model-makers in your area that might have the equipment to do this for you or, if you are familiar with using power equipment, might have some time to use it? Well-seasoned, straight-grained wood should be dimensionally stable enough for your purpose.
I don't understand why you feel that you need to laminate up a keel. Using solid wood, held straight in a building jig, should be more than adequate. Am I missing something here?
Glad that you spotted the reproduction shrinkage early: this is a common issue even with good printers.
- 43 replies
- mediator
- first build
4 jaw chuck for a Proxxon lathe??
druxey replied to md1400cs's topic in Modeling tools and Workshop Equipment
I believe that the DB 200 takes a 12 x 1 mm metric thread. -
Allan: Riding bitts, as their name implies, were always used when at anchor. This would place a lot of strain on the bitts in a forward direction, further securing the cross-piece in its score as well as abrading it. The wear piece would be presumably simply nailed on for frequent replacement and the main cross-piece less often, but must have also worn on ts upper and lower sides. Anchor handling would not require use of riding bitts unless there was a problem bringing the cable aboard.
I take an alternative approach and file out the half-holes almost to size in the hawse timbers before assembling them on the model. This automatically puts the holes at the correct upward angle and parallel to the long axis of the model. Also, there is zero risk of tear-out by drilling. Ah, well - on your next model!
