Posts posted by druxey
Interesting. However the frame looks far too 'fat'. Do you have scantlings for a 44-gun ship?
- mtaylor and Retired guy
2
As you've figured out, cutting tools have to be really sharp and don't try to cut off too much or deeply at a pass. Slow and steady does it. It helps to have a template of the rabbet profile aft at each station so you can see the changing turn of the rabbet. Hope Take Two goes better!
A fire boom was used to push off an attacking fire ship or burning debris.
- thibaultron, Keith Black, Moonbug and 4 others
5
2
Congratulations on launching your new project, Eberhard. Lovely subject!
- Keith Black, shipman and mtaylor
3
I've used Titebond II successfully many times for veneering. The advantage is that the glue can be reactivated more than once by heat. Regular white glues can only be reactivated successfully once.
That said, a properly spiled and pre-bent plank will stay in place with only about 30 seconds of finger pressure.
So the observations were written, not typeset, as I had assumed. Stag it is, then!
Shaping up really nicely, Chris!
- Glen McGuire, AJohnson, thibaultron and 3 others
6
I said it was a stretch, Rob! How about if the typesetter accidentally omitted the 'hound' in 'staghound'? More plausible?
Not so much Wat the Tyler as Wat the Heck.
- FlyingFish, KeithAug, GrandpaPhil and 3 others
3
3
OK, this many be a stretch, but "other devices" might include a staghound chasing the stag/deer on the counter? Would that work for you?
Some lovely color accents now, Mark! A helluva masking job, though. Do treat yourself to a new hose.
The tapered wedge shape forward of the quarter gallery allowed the occupant a view forward along the ship's side while ensconced....
- CiscoH, Hubac's Historian and mtaylor
3
There are some differences between the photographed prototype and the production model. As noted, the end result is the same.
- CiscoH, Dan Poirier, MBerg and 1 other
4
Sussex ain't so bad, surely, Keith? I recall as a child visiting an uncle and seeing the glow of the steel furnaces in the night sky.
- FriedClams, Doreltomin, AJohnson and 2 others
5
It is more than likely that Wolf was steered by tiller alone. No reflection on your work at all, but on the kit design! Some of these smaller sixth rates were retrofitted with wheels in the position mentioned.
- catopower and modeller_masa
2
I had no idea that planking a transom could be skirting danger! Looking very fine, Keith.
- Valeriy V, AJohnson, Doreltomin and 5 others
8
Very neatly done, Clare!
The tiller/wheel set-up is unlike any I've seen - usually if a wheel is present, it is on the quarterdeck where the funnel-like structure is sitting.
- modeller_masa and catopower
2
North Carolina Oyster Sharpie by Paul Le Wol - FINISHED - 1/24 - from plans drawn by Thomas Pratt
I'm late to the scene: very nice neat work and bending job!
