Everything posted by mtaylor
I've found that the foam nail sanding blocks sold by beauty supply shops work well in many applications. For a "hard" back, I just cut a piece of wood and glue the paper on. One can also use dowels of assorted sizes where a inside rounded shape is needed. Scrap wood, basswood all work well for these.
Welcome to MSW, Ben.
You'll get it sorted, Jerry. You've come this far so what's a few more steps? I think Yancovitch might on to something. Is it that the "large" parts don't cool fast enough?
- 553 replies
- sloop of war
- constellation
(and 3 more)
Welcome to MSW, Colfitz. Steven gave the best advice and I can't add to it.
Prynhawn da pawb - (Good afternoon all) from Wales!
mtaylor replied to SweepHall's topic in New member Introductions
Welcome to MSW, Sweephall. Best advise I can give is to open log. Also check the kit logs for the one you're building because a) they're a good guide and b) they usually point out dead-ends, errors, etc. Also, check out the other sub-forums here at MSW if you have questions. Often a search using the search feature will find you and answer. -
Welcome to MSW, Andre.
Wasn't that called a "SWAG"? Scientific Wild A** Guess?
- 2,696 replies
- heller
- soleil royal
(and 9 more)
OC, I used to do AD&D type miniatures like orcs, dwarves in my deep dark past. One way I found to do them and not waste paint by cleaning the brush multiple times was to do like all the flesh on each one first, then hair, beards, and details. It seemed to be faster that way. By the time I had all the faces painted, the first ones were dry and I could go onto the next color.... wife, life, etc. permitting of course. Ended with a "little guys and creatures" assembly line. Fond memories from back then like: Dungeon Master: "You're in a round room. The treasure is in the corner."... Players: "We got the treasure and left the room." Laughter and beer all around.
build logs order
mtaylor replied to Papa's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
Check your settings on the logs... there's a button for each "era" labeled "Sort by". Make sure "recently updated" is selected. Once done it should stay that way and all the logs with new posts are at the top. -
Sea Witch 1846 by Zooker - RESTORATION
mtaylor replied to Zooker's topic in - Build logs for subjects built 1801 - 1850
Saliva... i.e.: spit. The enzymes in it will actually help clean off the dust and debris faster without harming the finish or the wood. -
Welcome to MSW, This sounds like an interesting project. I would suggest that you open a topic here on the ship: https://modelshipworld.com/forum/13-discussions-for-ships-plans-and-project-research-general-research-on-specific-vessels-and-ship-types/.
I changed your topic title scale for you. If you need to change anything on the title, just go to the very first post and hit "edit". As for the planking problem, if I understand this, you want to basically fill the areas between the bulkheads above the area you have filled, right? I've used basswood (lime) and also balsa for filling. I have found though that the lime works better.
When you add your pictures, please update the title with maker of the kit.
- 2 replies
- mantua
- amerigo vespucci
Welcome to MSW, Paul.
