Everything posted by mtaylor
Just fantastic and you should be proud of them, Kees.
- 434 replies
- pelikaan
- beamtrawler
Coats and Clark Thread for rigging
mtaylor replied to bigcreekdad's topic in Masting, rigging and sails
You can also try any fabric store. I bought some 1200 yard rolls at Joanne's. -
Ray, Looking good. My only advice is to use less rope for breeching. About 2 1/2 times the barrel length. And to get the sag, just touch a bit of CA to the line and stick it to the deck. It will be dark on that gundeck so much of the details will be lost... but you and we will know what's there.
On the Triton cross-section, a lot guys do it that way. I did too. Just a small drop of PVA. Once some planking is in place a bit of alcohol on a paper towel on the joint should pop it loose.
- 649 replies
- dunbrody
- famine ship
Hmm... I think you'd need to leave quite a few spalls on to constantly make sure nothing has shifted. Might I suggest that you put them on top the frame? A lot of the builders do it that way so they can get the spalls off.
- 649 replies
- dunbrody
- famine ship
John, This one: http://modelshipworld.com/index.php/topic/1465-18th-century-longboat-by-bobf-ms-148-tri-club/
- 64 replies
- 18th century longboat
- model shipways
Cutter Cheerful 1806 by rafine - FINISHED
mtaylor replied to rafine's topic in - Build logs for subjects built 1801 - 1850
A sweet build, Bob. Your builds have rank right up as a gold star standard.- 525 replies
- cheerful
- Syren Ship Model Company
David, That bit of gun rigging is the inhaul for the guns. If, for some reason, the gun didn't recoil enough to reloaded, it was used to pull the gun back. It would have only been in place when "action" was expected and even then not always. It was sometimes unhooked and kept out of the way so as not to be tripped over but kept close at hand if needed. I'm playing "catchup".... Your build is looking great.
- 117 replies
- constitution
- model shipways
I'm loving it, Sjors. You are obviously taking very good care of the rigging spiders.
- 1,616 replies
- caldercraft
- agamemnon
Daniel, I do believe you are correct. In France, the India Company ships were also warships so plans were sent to the appropriate place. They also planned on only one voyage per ship. Some shortcuts were taken, but since the King was involved, much of those ships were built like warships. England was a different beast as I understand. When the Navy bought a ship, they took of the lines and some of the details. The did do some upgrades as time and money permitted, like the stove, gunports, but I'm not sure wales were on the list. It was a quick and cheap way to get a ship for a purpose, usually, short-termed. As I recall, there were ships bought solely for use as fireships, victualers, powder and transports and very little was done. Others, got a massive overhaul. Do we know how much was re-worked when the government bought her? The shipyards were very good at detailing these things but not always on the drawings.
I believe that kit is the same or a slightly modified version of the AL kit. As to how good it is, I can't answer but I remember seeing some logs here on MSW.
Sweet work on the details.. the battens and the grates. Let's hope this is your last move, Danny. Being a nomad is rough on building ships.
- 268 replies
Where does one find those extra-extra large quarters? That is some seriously beautiful work and those pieces are tiny.
- 641 replies
- greenwich hospital
- barge
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Ok.. I see that you set up the thumper and the worm came to you. That is a great looking bucket.- 4,152 replies
- cutty sark
- tehnodidakta
A great save on that deck, Denis. We've all pulled dumb things like that. And rails... a wow! on the painting even if I did like them as bare brass.
A question for al you users of scroll saws
mtaylor replied to michael mott's topic in Modeling tools and Workshop Equipment
Moxis, Maybe something like this? http://www.proxxontoolsdiscount.com/store/p23/37088_Scroll_Saw_DS_115%2FE.html I've seen some videos and the blade goes vertical as the arm doesn't move. -
Thinking outside the box? I don't think there was a box to begin with. Looks like a great idea carried through to working, Michael. If I'm seeing and reading this right, then the whole u-shaped blade holder doesn't pivot but goes up and down and the is always dead on vertical?
