Everything posted by mtaylor
I'll add this to the pumps.... The French had a another way of "manning the pumps".. see video. http://www.youtube.com/watch?v=Y-qoLpcyFfU
Kancabas cargo boat by mhmtyrl - FINISHED
mtaylor replied to mhmtyrl's topic in - Build logs for subjects built 1501 - 1750
Beautiful work and the weathering is perfect. Congratulations.- 32 replies
- kancabas
- cargo ship
Looking pretty good. I've not done this kit, so I'm just sort of following along. I saw your questions in the other area and thought I'd drop in. MSW is a great resource. If there's specific questions about something... do like you did with your deck question. Ask it in the appropriate area where more eyes will see it. BTW, power tools are not sacrilege. Just about everyone uses them.
- 843 replies
- niagara
- model shipways
Build Deck Separately
mtaylor replied to mikiek's topic in Building, Framing, Planking and plating a ships hull and deck
Mikie, Have you had a look at the other Niagara build logs? I'm not sure how they did (and there's quite a few) but the logs would also tell you how they did it and what problems they ran into. -
Druxey, I'm looking at that drawing (above) and it looks like the top of the lower plate overlaps the upper... I agree on the stern. Am I miss interpreting somewhere? I think that starting at the keel the lower plate would be overlapped by the top one. I hope I'm having a senior moment on this... Edit: I just doubled checked Le Venus... the same drawing and text states that the upper plate is overlapped by the lower one. The plate to the rear is overlapped by the one in front. Stern to bow and wale to keel. Edit to the Edit: I double-checked Belle Poule and now it gets messy.. no word on how she was plated in her early years as some point, the plating was removed. However, in 1780, she was re-plated and the lower one is overlapped by the upper one and the rear overlapped by the one in front. Stern to bow and keel to wale. The problem I think, is the Brick is after both Belle Poule and Le Venus although Le Venus is closer in time to the Brick. And then there's the variation in the various shipyards in France as to the way things were done. I think I'll just wander off mumbling to myself... scratching head... Two ships and not plated the same way... puzzling.
I wasn't going to bring that up, Ben... I figured someone else would. :P
- 1,083 replies
Be careful of using "too much" pressure as it can create issues down the road by crushing the wood. I've heard both good and bad about Titebond. Gorilla is the big problem child as it foams in the joint and tries to separate the pieces. Looking good Julie. You're getting excellent advice and counsel from Keith. I'm just following along with a cup of coffee....
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
- 4,152 replies
- cutty sark
- tehnodidakta
Aye... lots of beverages on this one... I've not done the yacht/schooner types. I think I'll stick with something simple like frigates and 74-gun ships... :P
- 203 replies
- artesania latina
- marie jeanne
Go for it Jack... I guess you're in one of those "I've got 2 choices" situations. I would have thought they ran fully up.... but then again... <shrugs> I have no idea. Have you tried running a batten or two and see how they land?
- 203 replies
- artesania latina
- marie jeanne
Inspirational work, Giampieroricci. I didn't realize how tiny that was until I saw on your finger.
Bingo!!!! You nailed it. Great looking and working door, Patrick.
- 1,083 replies
Fittings/Accessories to Billing Boats Meta af Byxelkrok
mtaylor replied to samaka's topic in Wood ship model kits
Anders, Rumor has it that the Billings is no longer in business or reorganizing (depending on the source). Have you tried Googling? Maybe E-bay or Amazon? The fitting kit is #485 Having said that.... someone might be able to help with what's in the fittings kit. -
Greg, I Googled "steamboat Sultana" (without the quotes and then added "model". I also did one with "plans" instead of "model". Lots of news items but little of help to us modelers. Maybe drilling down deeper might yield something?
Indeed, it is. Many of the mills that look like that along with many of the mini-lathes come come out of Central Machinery in China. BTW, here's a good link that has a lot of info: http://www.littlemachineshop.com/default.php Bob, What Frank suggested. Having said that, I wouldn't buy things until you think you need them. I have, for example, an edge finder that I've used once. Then again, I'm newbie and may not be fully able to utilize it.
Greg, A quick Google doesn't show a kit.. but I did find some links http://steamboats.com/museum/lossingmodels.html http://www.arkansas.com/attractions/detail/sultana-disaster-museum/96771/ There's plans listed here: http://steamboats.com/museum/lossingmodels.html You will probably have to do a scratch build....
So far, so good, Jack... Looking very prim and proper. There's no pics of the stern? I would think there should be... Hmm... Have tried Googling and seeing what others out there have done? <scratches head>....
- 203 replies
- artesania latina
- marie jeanne
Chuck, Your logs are one of those that set the standards for tutorials. Beautiful smithy work.
- 1,048 replies
- cheerful
- Syren Ship Model Company
Lovely work.. and so clean. Keep it up, Mark. You're doing great.
- 172 replies
- druid
- sloop of war
