mtaylor
Moderators
Everything posted by mtaylor
  1. Super nice saloon, Patrick. The chairs are a great touch.
  2. Thanks for the "likes" and comments. Druxey.. I'll try. Dan... thanks for explaining the anchor stowage planking. You beat me to it. Hi John, I have the pictures from Boudroit's History of the French Frigate 1650-1850 As built, she had wales similar to the English but her decorations including quarter galleries were typical for the period. See pictures. After a rebuild/Great Repair or whatever the French called it, she resembles the Belle Poule and it also appears the L'Hermoine is similar (same period) in galleries, planking but Licorne, has the full Arms of France for the stern decoration due to not having the chase ports on the quarterdeck level. The wales were converted to as shown and also as you explain. It's been a bit confusing at times especially since Hahn thought it was Le Venus that should be used. Le Venus was an 18-pdr of a later period and design. One big surprise was they went from 5 stern windows (4 real and 1 deadlight) to 7 windows (4 real and 3 deadlights). Also, the original design had lids on the ports. After the rebuild.. no lids. One thing I did discover from Boudroit's works is that the 8-pdr and 12-pdr frigates were very similar and the biggest difference as far as visual is that on a 8-pdr, the quarter deck stops on the aft side of the main mast. On the 12-pdr, the quarterdeck continues to the fore side of the mainmast. The more I get into this build, the wilder some things seem to get. Edit.. accidentally hit "post" while writing this.
  3. Beautiful build, Anthony. Are they any more pics of the build in progress? I was beginning to think that you had given up on this.
  4. Hello Santiago, I really can't offer any advice other than what Jason and Ulises said. Pick the one you want to build first and open build log. A build log is the best way to get help when you need it.
  5. Jeff. It wasn't unknown for that practice but other than the French, it wasn't used much. The center line planks were thick stuff, sometimes scarfed, sometimes not (depending on the country). Generally, the English let the planks into the beams while the French for a period left them proud of the beam. There's pros and cons to either method..
  6. Keith, In addition to what Izzy suggested with the alcohol wipe... use a piece of 100 grit sandpaper to rough up the surface. I'm finding that this works a charm as some of the wood I have when thickness sanded, cut, machined, etc. has a surface that just doesn't seem to like the glue until it roughened.
  7. Thanks for the "like", the comments and looking.... Here's the current state... The wale (wide) planking is complete on the port side. Work is continuing on the starboard side. I've temporarily tacked in place the garboard strakes in order to measure the remaining area for the "normal" planking strips. I'm also sorting out how many battens I'll need... I'm thinking probably 3 of about 8-10 planks between battens.. At this point, I know I'm going to need drop planks and stealers since various monographs show them... I'm assuming this was the normal method for the French ships and not the monograph author's but haven't been able to verify it. Click on the image to enlarge and as always ideas for improvement are welcomed.
  8. Walt, Try this... open an "new" drawing and hit "save as". It will open the "save" window at the last folder... although depending the program, it might open the folder at the default location. Otherwise, you can hit the start menu and if you remember the name of the drawing, enter it in the search bar. If not the name, then try *.XXX where xxxx is file type.
  9. Ah, yes... ebony. The bane of model shopbuilders. Lots of heat as soaking doesn't do much... lots of extra wood to deal with the breakage.. I'm going to try and get away from it even though I just love how it looks. Maybe stain or dye next time around.
  10. The area circled in red? Not rope but metal bands wrapped while hot and then riveted, usually. A lot of us use black paper to simulate the iron bands as it's easier to work with than brass.
  11. Nice work, Mike. The planking looks to be going well. I had that problem with wales and double layers and I won't be doing that again. I'd rather fiddle with the thicker wood than trying to line everything up.
  12. Now that is a scary photo if ever I saw one. To have the bowspit that close....
  13. Wow.. impressive work and you did earn your beer. I'm not sure the bear would be tasty or friendly unless he got a beer also.
  14. Excellent progress, Mobbsie. The mast base is different and interesting....
  15. Chuck, I'd suggest reading the planking tutorials here: http://modelshipworld.com/index.php/forum/14-building-framing-planking-and-plating-a-ships-hull-and-deck/ and here: http://modelshipworldforum.com/ship-model-framing-and-planking-articles.php There's a wealth of information in them. Some of it is repetitive but each author has a different slant. Part of planking is finding which method works best for you. Oh. and then there's the Jim Robert's book: Planking the Built-up Ship Model which to me, helps put it all together.
  16. Years ago when I worked for an aircraft company, they said when the weight of the documentation equals the weight of the airplane, the airplane will fly.. I'm not sure how true that is, though. :P
  17. Looking good, Jeff. I'd call them wales (not whales... those are a different critter ). If you can, put a touch of flat black paint in the hawse pipes... I think you'll be even happier with them.
  18. Jay, I agree.. he's wrong. I was just trying to figure how why and how since it doesn't make sense.. those are obvious errors...
  19. Been a bit since that last update... I stripped off 5 strakes of planking at the stern and reworked it with some help in the form of advice and mentoring from Dan and Druxey. They set me straight and on the right path. I'll do a bit more sanding (still rough only for now) and then turn the hull around and to the other side. I did some templates and the shapes look pretty close so I think that side will go a bit quicker. I shouldn't have to plank, rip off the planks, sand and then replank several times... I have a dummy fashion piece held in with the blue pin to get the plank ends correct and I'll be fitting the real thing later. I'm not too worried about the plank ends being 100% squared up as there's a reasonably wide covering trim plank that will go over them. Besides, isn't it supposed to be deal with one headache at a time. I just noticed....my work area is beyond messy... sorry. Thanks for the comments, the help, and the support. Back to motoring on and making sawdust.
  20. That's good that that your dad got a better job, Lextin. I think you're headed out for some adventures... and sometimes these are more important than college. If you get a chance, check in from time to time and let us know how you're doing.
  21. Jay, The problem here may not be Marquardt but the period in time... if that makes sense. The way the ship sits now isn't the way it was built from what I'm understanding. The MS model is based on the 1929 refit. I have no idea what Marquardt based his book on but apparently there are issues that Gene B. found. I guess the question is: which problems need fixing and which can you live with based on the available information since it is conflicting information?
  22. I think you're looking for true engineering detail drawings. I just don't think you'll find those. There are some plans that have details but not to the degree you're asking about. If it's an older wooden ship, the plans are basically within a few inches...more or less. They were hand drawn. It's probable that some of the newer ships do have very detailed engineering drawings but getting a copy of those will probably be difficult, if not impossible. I guess the questions we have are... what ship? what type of ship? what era? and what are you doing with the plans? CNC, kit making? 3D super detailed down to the last nut and bolt?
  23. That very well could be. I recall when Gene Bodnar did his huge build of her that there were questions about Marquardt's being correct on several issues. Also, I believe Jud is right. Those where the scuttles for passing the power bags up to the powder monkeys.
