Everything posted by mtaylor
Gluing 101
mtaylor replied to CPT_D's topic in Building, Framing, Planking and plating a ships hull and deck
I find what Mark (Blue Pilot) said.. toothpick and wax paper. I use it also for CA. A little goes a long way. -
She's going to be a beauty, Nils. Lovely lines and your usual excellent details are already showing up.
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
I have to keep reminding myself how tiny those parts really are.... amazing work, my friend.
This looks to be a fun build, Ken. Mind if I tag along?
- 80 replies
- choctaw
- heinkel models
That is a different method. It's fascinating to watch this come together.
- 22 replies
- master korabel
- 75mm boat
Hi Nigel, Fully planked both sides. Admiralty orders. The battens have been removed and planking is progressing. Carl... oh yeah...he did it. A lot of fussing and agonizing going on as well as some real-world distractions. Stay tuned.... we'll see where this goes.
Cathead, I think you're pretty much spot on. I've seen a display years ago (at the Arch in St. Louis) and I recall those engines being on most of the riverboat models they were showing.
I would suppose that companionways on some ships could be removed and sent below for air circulation or as part of clearing for action but I have no evidence. I'm thinking that they're like the roundhouses (cabins) that appear on some ships on the quarterdeck. On French ships, they're supposed to be very temporary except for one on certain frigates and that was the one for the captain. Around 1790, IIRC, they banned them totally.
- 1,051 replies
- cheerful
- Syren Ship Model Company
Bummer... Hopefully, this will do the trick.
- 119 replies
- la reale de france
- heller
Nice work, Sjors. You have been busy on the Aggie... Lots of fiddly bits completed.
- 1,616 replies
- caldercraft
- agamemnon
Jeff, Nice work on the bits and pieces and everything else... On the order of the pictures. after hitting "attach", put the cursor on the screen where you want the picture. Hit the little "add to post" under the thumbnail. The order you hit "add to post" is the order they will appear.
Jesse, After you hit the "attach this file" button, under the thumbnail is "Add to Post". Put the cursor where you want the pictures and hit that button. The order you hit them will be the order they appear. I'll this update. Wooden hinges... wow.
- 71 replies
- pirate ship
- bottle
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
- 4,152 replies
- cutty sark
- tehnodidakta
Thanks for the comments and "likes". Just a small (by MSW standards) but a big one for me. Sadly, I forgot to take pictures during this process as my mind was on the process and not much else. I lined off the hull starting a frame 20 (dead flat) and then went fore and aft from there at every 4th frame. At the dead flat, I needed 27 strakes to cover the hull, at the sternpost, 27 also with a dip to 25 a couple frames in front of the stern post. At the bow... 18. Note that these are "full width" measurements. I grabbed the planking fan and began lining it off bow to sternpost based on "27 planks" and realized I should be able to plank without stealers or drop planks.. Happy dance... My next step was to lay some battens (3 on each side) and check the run... looks good but I needed to tweak the lining off a bit. I've since pulled off the battens and the garboard plank and started planking. I'm working from the wales toward the garboard. I made this choice based my feelings that I can use the wiggle room provided by the extra-wide garboard for adjustment if my planking doesn't quite match the lines. Back to sawdust, planking and trying not to overthink this too much.
Congratulations on a fantastic model, Danny. The flags are just icing on already wonderful cake.
Frégate d'18 par Sané , la Cornélie
mtaylor replied to JohnE's topic in CAD and 3D Modelling/Drafting Plans with Software
Excellent explanation, John. This helps put a lot of things into perspective...
