Every time I look at your boat I am amazed at your skill.  It always inspires me to do better.
Bob
Current build:  SS_ Mariefred
Thank you very much for your kind comments and compliments, Albert, Bob (raf), Jeff, David, Denis Bob (cap`n),
I`m so pleased that you liked the progress
Also thanks to all the "Likes" for looking in...
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much John,
I also love those benches, they were the nicest I found after some related search with help of the web....  (photo etch kits), they are for the "Titanic" in scale 1:144
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils
I'm just catching up on your KWDG.  Wow, wow and triple wow!
I tell you what, every time I say that I can't do something, I'll look at your KWDG for inspiration.  That's enough to teach me that anything's possible and that if you strive to do your best, anything's possible.
Inspirational.
Cheers
Patrick
Thank you very much Patrick and John (Neptune),
and thanks to all the "likes"
Patrick.
a very kind compliment, much appreciated, glad you like it...
John,
thanks so much for your nice words, and for your catch up....
I`ve put on the aft portion of the boats deck now on permanently and it worked out fine. Of course something came to eye after mounting it and clamping it down, I noticed that two of the benches below on the promenade deck were just mounted in the way/ space where the upward stairs should be placed, and four of the holes for the downward vent tubes had been planked-over on the boats deck and forgotten to be cut free again, but both little misfits can easily be put right again.
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Hi Nils
So much good things happened with your Kaiser while I was away, GREAT BUILD!
Deepest RESPECT!
Regards
Gerhard
Problems just mean: solutions not yet found
Models in progress
SMS DANZIG
http://modelshipworld.com/index.php/topic/12842-sms-danzig-1851-by-gerhardvienna-radio-150-scale/
USS CAIRO
http://modelshipworld.com/index.php/topic/13282-uss-cairo-by-gerhardvienna-live-steam-radio/
Baby Bootlegger 1/10
http://modelshipworld.com/index.php/topic/13625-baby-bootlegger-110-radio-by-gerhardvienna/
Swiss paddlesteamer RIGI 1848 1:50, after plans from the Verkehrshaus Zürich, rescaled to original length
Anchor tugboat BISON, 1:50, plans from VTH, scratch
Finished models
See-Ewer ELBE, Constructo kit 1:48
German fastboat after plans from german Reichskriegsmarine measure unknown (too ugly to show up!)
German traffic boat for battleships WW2, 1:50, after plans from Jürgen Eichardt, scratch
German Schnellboot TIGER P6141 VTH plans, scratch
Thank you very much Gerhard,
I`m only adding tiny bits and pieces, but when holding the hull in hands I can feel the constantly increasing weight, although the hull was such a lightweight, when taking it off the build-slipway some months ago. Probably its the brass parts and the metal plating coat that owe to the weight....
Nils
Current builds
-Lightship Elbe 1
Completed
Wonderful work, Nils.  The scope and detail of this project amazes me.
Ed
Ed
 Ed,
thank you very much, its slowly coming together and its fun with the fitting out of the decks....
as far as the work is concerned, I can only return a bunch of compliments to you for your wonderful "Exreme Clipper " build, which I love so much, a great model shipwright performence
Nils
Current builds
-Lightship Elbe 1
Completed
Little update...
the stairways are quite easy made due to the pricise brass etch patterns.
One of my most importent work documents is the orientation plan for vents, red indicated (size and tube diameter), and the stairs, green indicated
Nils
folding and primercoating the stairs
Current builds
-Lightship Elbe 1
Completed
I bet Bassett Lowke would have liked the brass etching methods back in the day. Lovely work as always Nils.
Michael
Thank you very much Carl and Michael,
and all the "likes"...
Carl,
the etched stair sides and the steps are only folded and you`re right, afterwards (after priming and painting) glue into place with a drop of CA
Michael,
right, I agree, although I have highest respect for the skills of those professional builders work in much earlier days
Nils
Here is a little update .......
on the making of the aft handrail portion in place where the railing performs the rounded bend. I tried several times two flat bend the mahagony handrail by wetting and soaking, with and without heat, etc, very frustrating and without success. Then came the idea not to flat-bend over the 1,5 mm wide side, but to flat-bend and laminate 3 single 0,5 mm thick strips with CA and with help of a little jig, Sigh of relief, it worked out well. Only have to mount and carefully sand down to the required flatness
Current builds
-Lightship Elbe 1
Completed
Hi Nils - either the pins are very big or the rail is very small. It looks great.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Keith,
Thanks for your words, I should have thought of the "laminating way" of those bends earlier.....
Nils
Current builds
-Lightship Elbe 1
Completed
Lamination is the way to go,  The rail looks great.
Bob
Good solution. This is an old model airplane trick for making rounded wing tips and control surfaces. When one is thinking ships sometimes different techniques fade into the background.
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
Many thanks Bob and Bill,
there are probably quite a lot of valuable "know hows" in relation with model aircraft building, especially those made in the good old way with all the framework and shrink-span tissue coating.....
Nils
Current builds
-Lightship Elbe 1
Completed
I could almost feel your frustration with that railing Nils. It's so maddening to bend a piece of wood just to have it kink when your about 2 degrees from success. I can feel myself getting tense just thinking about it.
Your ship is looking terrific.
Gary
Completed Scratch Builds
thanks for your words of sympathy Garry,
maybe the experience (laminating wooden bends), if not already known,  may also be of help to fellow builders
Nils
Current builds
-Lightship Elbe 1
Completed
great idea on bending..........hand rails look super.    nice looking ladders too  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Many thanks Denis,
glad you like it
Nils
Current builds
-Lightship Elbe 1
Completed
Update:
Today fitted stern anchor crane, and anchor rest cradle
Nils
the chain is a liitle bit thinner than the bow anchor chains
Current builds
-Lightship Elbe 1
Completed
Hi Nils, its been a while since I commented, but your work is just so wonderful.  I've learned so much from you and how you can create these details without relying on kit parts.  Can't wait to see her in her final glory.
Cheers,
Jason
In the shipyard:
Thank you very much Jason,
for your nice compliment
Nils
Current builds
-Lightship Elbe 1
Completed
I had been wondering why the rail was shaped that way.  Now it makes sense.
Bob
Thanks for your nice comments Bob, Albert and John,
Nils
Current builds
-Lightship Elbe 1
Completed
