Ken:  The hand torch is really like a glorified butane lighter.  It works great with conventional solder, which melts at 450 degrees F., but it's hard to get the temperature high enough to melt silver solder, which flows at 1500 degrees F.  I had to train the flame on the joint for 2 minutes to get the silver solder to flow.  If you use propane and oxygen together, the flame is much higher in temperature than butane alone.  You need a regulator to mix the two gasses.  Ever wonder why they sell oxygen containers near the propane torches at big box stores? The photos show the hand torch I used, and the setup Bob Hunt uses for silver soldering from his practicum series.
All that is truly out of my league.
I'll have to think of something else.
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
I cut out 8 rosewood gun supports.  For the metal caps I used a 1/4" square styrene tube and glued strip styrene to each end.  I trimmed the styrene and cut of the caps.  I drilled a pilot hole in each.  They were then painted gunmetal color and glued to the gun supports.  I enlarged the pilot holes to 1/16" diameter and fixed 4 yokes in place.  The trunnions will be threaded through the yokes and guns and fixed with a drop of CA.  The 4 starboard supports will have guns, the 4 port supports will be gunless.
Fantastic work!
Really excellent.
Ken
Completed Builds:
Very nice Dave, she'll have her place on the shelf very soon. Have you ever checked into resistance soldering? Very pricey, but I think that is the way to go. Here is the place www.americanbeautytools.com that sells them, daverow(here on msw) uses this and swears by it
Edited by donrobinson
Busy day in the shipyard!  I installed all the deadeyes and chainplates and covered the from edge of the channels with some cherry to finish them off.  I also glued the gun supports to the hull and assembled the swivel guns.  They were mounted (temporarily) on the starboard gun mounts.  There are just a few tasks left:  The horizontal portion of the catheads, finishing and rigging the anchors, and making the great cabin lights.  Almost done!
The ship will be mounted on the backs of some cherry seahorses fixed to a cherry base.  I still need to rout a profile on the base and glue the seahorses in place.  # or 4 coats of wiping varnish and it'll be done.
I started working on the stern lights in the great cabin.  The kit includes five 3-D printed lights that look fine, but I wanted mine made of wood.  My first decision was, "what color?"  The kit-supplied lights are white, so I made up a mockup out of holly.  Because my mockup was a little beefier than the kit parts, the white holly seemed way too much.  I settled on boxwood.  The first step was to cut a few strips of 1/32" thick boxwood to 1/16" in width.  I then traced the outline of the kit lights on a piece of paper and covered the drawing with double sided tape.  The frames are made in two layers.  I laid out the first layer on the double sided tape and used CA to glue the second layer to the first.  It's important that the second layer have spans that cover each butt joint of the first layer.  If not, the frames fall apart.  The crude drawing in the photo is the layout for the 2 layers that make up the frames.  There are 18 parts per frame!  They need to be cleaned up and fitted to their place on the stern, but overall I'm happy with the result.  It was actually easier than I thought it would be!  Two more to go.
The model is nearly done.  I had a nice wide piece of cherry to use for the display base.  The four seahorses support the model on their backs!  They need to be sanded and glued in place.  I routed a simple cove along the edge of the base to dress it up a bit.  I think that's all it needs - a simple cove versus an ogee or other more complicated shape.  Agree?
I agree Dave, no need to take away from that superb ship! Beautiful work
I really like that display stand.  You should market it.
Ken
Completed Builds:
Beautiful, Dave.  That build is very easy to look at.
The simple cove is best, I agree.  And did you cut the seahorses yourself?
You mentioned that you used rosewood for the gun mounts -- what is that wood like to work with?
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
I really like that you didn't use paint, but use different woods to achieve that 'authentic' look.
What wood is the dark brown wood on the hull?  And is that redheart on the inner bulwarks?
Thanks.
Ken
Completed Builds:
Thanks, guys, for the comments and the "likes"!
Martin:  The seahorses are provided with the kit as two halves that you glue together and sand smooth.  The cherry is my own wood.  Rosewood is beautiful.  I used it for gun mounts, the wales and black strakes and hatch coamings.  It tends to be oily, so you need to wipe it down with an acetone soaked paper towel before gluing or finishing.  It takes a finish beautifully.
Ken: The photo shows the various species I used on the hull. Yes, the inner bulwarks are redheart.  Mine oxidized or UV'd a bit to a reddish brown - not the bright red like your Rattlesnake.  Next time I may use blood wood again, as I did on my MS AVS.
Edited by DocBlake
Thanks Dave.
My red heart has also faded.  So I'm looking for another type of wood.  I may have to use paint on my next time.
What is your source for blood wood, purpleheart and rosewood?  I do like the look of your hull.
Thanks.
Ken
Completed Builds:
Hi Ken!
I have a great hardwood supplier that I use for wood to make furniture.  Great prices on cherry, walnut, mahogany and maple.  They also stock exotics, so I buy blood wood, holly and rosewood there.  Your local Woodcraft or Rockler store should stock purpleheart, yellowheart, boodwood and maybe even rosewood.  I've not found holly there, however.  The place I shop is called Kettle Moraine Hardwoods:  www.kmhardwoods.com
FINISHED!!  14 months to the day, and my AVS is finally done.  It was great fun, and makes a pretty attractive model, I think.  Bob Hunt is still producing this kit, but is using laser cutting to fashion the parts.  If anyone is looking for a challenge and a lot of enjoyment.I heartily recommend this kit! It's available at the Lauck Street Shipyards website:  https://lauckstreetshipyard.com/avskit.htm
A beautiful built model Dave,
nice wood selection and wooden tones, well done   :)
Nils
Current builds
-Lightship Elbe 1
Completed
Great work!  Congratulations on building such a fine ship, you'll get years of pleasure looking her over.
I built the Rattlesnake using Bob Hunt's practicum.  I'm glad to hear he's gone back to producing kits -- which he's stopped doing for a while.
Can't wait to follow your next build
Oh, and thanks for the link to Kettle Moraine -- hardwood suppliers are always a good source (I have 3 carving projects going at the moment, and am always looking for affordable sources of wood)
Martin
Edited by Martin W
Congrats. and thanks for the information.
Your build is excellent.
No rest for the weary, however.  Waiting to follow the Independence again.
Great job.
Ken
Completed Builds:
Thanks for all the kind words and the "likes".  I am going to go back and work on Independence.  I also have 3 other Lauck Street kits:  Halifax, Kingfisher and Fair American.  I'm thinking of starting Fair American at the same time as I work on the Independence!  All this is working up to a scratch build of "Hannah" in 1/24 scale.
Congratulations Dave, she is simply beautiful. Thanks for the wonderful log that you have done, it was an enjoyable voyage.
Really, Doc, you set a level quite unreachable for me! Still, I find you're work (and help occasionally) very admirable and inspiring! Love it!
Cheers!,
Bouke
currently: master korabel Schooner Polotsk
finished: the Swift 1805, the Lady Nelson
on the shelf: US Brig Syren, Le Renard and the Hermione
