Indeed, a mast top is not a crowsnest.
When I was young. I (and probably many of us) dreamed to be a pirate, exploring the horizon from the crowsnest, high in the mast.
Now I discover that I sat actually in a simple mast top. ☹️
My childhood dream, shattered to pieces 😲 😆
https://en.wikipedia.org/wiki/Crow's_nest
https://maryrose.org/blog/in-the-museum/museum-blogger/the-mary-rose-crow-s-nest/
Patrick,
Nice work with mast - reminds me of the Vasa I did some time back. I have the mast parts from the museum if you like - I can find and post them here? Looks as if you have it just right however.
Cheers,
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Thanks, would be nice.
I already had the idea to visit your vasa every now and then 👍
Building the mast tops
Mast tops
The size ??
In this era you will find all sizes : small, big,  high, low.
Looks like 2 armed soldiers or sailors should have enough space in it.
And the  "supports" under the mast top are usually longer than the bottom diameter of the mast top (white arrows)
The top of the main mast is usually slightly larger than that of the fore mast.
20200803_163143.thumb.jpg.bf6ffbab410318968653186a0d66d112.jpg20200803_163203.thumb.jpg.067716ef342a79afd70aafab2d24b30d.jpg
First did some testing with paper before buildig the "baseplate"
I first do the main mast until the base plate is ready, and then do the same with the fore mast.
20200728_110313.thumb.jpg.c5d7c29fe107e538a52b84efb0d257e4.jpg20200801_135355.thumb.jpg.698b901b7b8d3c7ca9dd03944cea12f3.jpg20200728_153920.thumb.jpg.e05288acfc39aab7d72a61cd8b423742.jpg
20200802_125447.thumb.jpg.bf7b33ad4e2d5418b767b81fed1e1515.jpg20200802_185438.thumb.jpg.8be9a86d6f983760d33ca83e47e556c6.jpg20200802_190733.thumb.jpg.e53c60b4b10a88c013cc9c814834c5e8.jpg20200802_190742.thumb.jpg.d11efae15a46fd4f1d652c04d88b69b7.jpg
Thanks for following
Enough space? It looks to me that their legs are cut off to create space 😁.
Maybe that's the reason that the right man needs some boose, to daze a bit. I have the impression that the left man needs some as well. Luckily it is coming.
Maybe they haven't earned their sea legs yet?
(Not sorry)
Current build:  AL HMS Bounty 1:48
(Not sorry)
If we look at this complete drawing. Life on board of a 16th century ship was fun.... 🙈
Eating, drinking and the "other pleasures" in life.
The only one who looks serious is the captain.
Continue with the construction of the mastops.
This is more thinking time than construction time. The intention is to make something with these as examples.
(Start at the top left clockwise Mataro model, Vasa, Mary Rose, Vasa)
An uninvited guest at the shipyard ...
Adding the main "supports" as on the Mary Rose.
20200809_153837.thumb.jpg.e2646919c3db946f8271f2d02aa29b2b.jpg20200810_165925.thumb.jpg.99cddfaf84b7b348b1cd6ecbe66b5a9b.jpg20200812_165258.thumb.jpg.629d03023de7be3ea4b03bda80168011.jpg20200812_165347.thumb.jpg.28299c2e7b66d621dd8c40fd5dc347f7.jpg
Making the "upper ring" from  several planks
20200813_162238.thumb.jpg.20a96016e73ff810d7377dfd5b162ae3.jpg20200819_152558.thumb.jpg.7a3ac5ce4e0247efd36baf7437282dc2.jpg
Glue the ring to the supports.
20200819_164403.thumb.jpg.fd13845758ab29a13fd4ec9d982ece22.jpg20200820_201016.thumb.jpg.8585899091d4dd4ec5762c3c2dc7106a.jpg
Still a lot to do
Main mast top under construction, fore mast is following.
Thanks for following.
That guest is part of the rigging crew, leave Pelican alone too long and she'll be festooned in silk rigging 😁👍
Mast tops are looking good, nice job😉
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thanks
A Pelican and a Bounty in a "spider proof" area.
As Steven just said - yes! - and Vasa platform are indeed helpful 😄
Cheers,
Under the table:
Completed:
Vasa-Corel -
1 hour ago, G.L. said:
Patrick, there is plenty of space for a lot more ship models
Indeed.
The Vasa model has found another home (sold).
Maybe i make a "2nd edition Vasa" one day ;)
Slow progress
Further finishing the 2 mastops.
20200826_192929.thumb.jpg.10c9bf4be5c9ce9ba3e52eadb2db5b8b.jpg20200828_140307.thumb.jpg.fed886269aa50838baadda3ab23bb683.jpg
Added these
Now I have to make 80 small planks (40 for each masttop) . None of them are identical.
And add more knees.
Work in progress
Thanks Chris.
It is useful to take a photo now and then. And then take a good look at it
I see that the mast top of the fore mast is actually a bit too big. So I'm going to rebuild this top a bit smaller.
Better now than later ;)
Those tops look very good, Patrick.
It's hard to tell from the photo whether the foretop is too big because it's closer to the camera than the maintop is. Just check it by eye to be sure, or take a photo from directly side-on, so you don't get the camera messing up the proportions. Otherwise you may be giving yourself unnecessary work.
Thanks Steven
The fore top is only 2mm smaller in diameter than the main top.
This really doesn't look good and the conversion is now underway.
These are the "charms" of scratch building a model without plans, haha.
Fair enough. 2mm isn't much - it's probably hard to see the difference between the two mast tops - so it's probably right to do all that work again (sigh) tomake a new top that looks right on the foremast.
I do know what you mean . . .  :default_wallbash:If I had a dollar for every change I've had to make in a scratch build, I'd have - several dollars.
Hiya Backer, I guess you use a scroll saw for the mast tops which one, great work by the way love the wood staining to give the weathered look.
Slowhand,
Current build Apostle Felipe - OcCre
Polacca scratch build from Amati plan - on hold
San Martin - OcCre
HMS Resolution - Corel
Half Moon - Corel
Dragon keel boat - Billings
Thanks,
Actually not.
A Stanley knife, half round file and sandpaper are used
Hello,
With the main mast top ready and a smaller fore mast top under construction, it is time to think about the main and fore topmasts.
In many drawings the top mast and flagpole are in one piece. A simplification of the 16th century painters or was this reality.
 (In one piece about 15    Seperately : 1  )
Masts in this period could not be dismantled.
The different parts of the mast were firmly attached to each other How? not a clue yet ...
Mast tops
20200912_111941.thumb.jpg.b605d9fcf74f83545bcf8e45938f0cd1.jpg20200912_111710.thumb.jpg.9452091cfd42c57c957f6c62ae05868e.jpg
Making top masts on my home-made lathe.  To my surprise it worked out quite well.
Determine the length
The masts in the Aeropiccola drawings are quite correct in length.
20200907_164053.thumb.jpg.d28a9eb6d54243afedfc5fcc6f3c88e8.jpg20200907_164041.thumb.jpg.dc2c636f04cbc6e4c59a17fd02b018ec.jpg
The length of my top masts are long enough to use both methods. Top mast flagpole separately or in one piece ( not yet decided what methode).
To be continued, thanks for following.
Patrick, comme toujours un très bon travail. !!
Je ne sais pas si votre deuxième langue, après le néerlandais est le français - je suis né en France donc c'était ma première ....
 Je pratique juste haha - J'ai aussi vécu au Mexique quand j'étais adolescent, j'ai épousé un Brésilien donc juste par «chance» pas par intelligence, je peux parler quatre langue hmmmm
Many Europeans speak three - two are very common indeed.
Under the table:
Completed:
Vasa-Corel -
"Aeropiccola" is a famous Italian publishing house, unfortunately, like many it has long since gone bankrupt (I have files in pdf)
congratulations for the work, really nice!
black Wolf
Lupo nero
_______________________________________
finished models  Carrack Santa Maria by luponero - scale 1/50 - diagrams of Adametz
https://modelshipworld.com/topic/19739-carrack-santa-maria-by-luponero-scale-150-diagrams-of-adametz-finished/
models under construction Athenian triere of the 5th century B.C  https://modelshipworld.com/topic/25956-athenian-triere-of-the-5th-century-bc/
  San Giovanni Battista 1598 by luponero - Medicean galleon  https://modelshipworld.com/topic/25930-san-giovanni-battista-1598-by-luponero-medicean-galleon/
Thanks for this nice French text. Great that you speak four languages (always handy)
I once learned French as a second language at school.
Some German during my military service in Germany
And some English in between.
black Wolf
Looks they had interesting models.
Too bad the company no longer exists. You can apparently still contact them according to the website
http://www.aeropiccola.com/index_eng.html
In the meantime, the second mast top is finally ready. Now continue with the top part of the main and fore mast.
And now we make a "ezelshoofd"  (donkey head in Englisch :blink:)  What does a donkey have in common with a mast part?
20200928_162436.thumb.jpg.d08667792831263aca5562c61dcebcf0.jpg20200928_165640.thumb.jpg.0000179b0c6ed32b1f1c29fedd3f550f.jpg20200928_164715.thumb.jpg.75be2396505c23a51859abe6b14c453a.jpg
On 9/13/2016 at 3:34 AM, Backer said:
History of the ship
Captain : Francis Drake (after 1580 Sir Francis Drake)
1577  Build or rebuild and launched as the Pelican
1577 Set sail with 4 other ships for an expedition intended to pass around South America
1578 Renamed as the Golden Hind(e)
1579 Captured the Spanish galleon Nuestra Senora de la conception
1580 Arrived back in England after a trip around the world
First English ship to sail around the world
And after this journey stored in dry dock on public display until she was finally scrapped.
Patrick,
I have only just discovered this great build.  Congratulations.
Just to add a little to your history:
The reason that the Pelican was renamed was that Drake's sponsor was Sir Chistopher Hatton whose coat of arms included a golden hind.  Hatton's home was Hatton Gardens in London, now the site of the famous diamond dealer and where, in 2016, the largest robbery in British history took place.
John
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Schooner for Port Jackson
That's a much more interesting name than the English one - just boring "mast cap". The Italians, on the other hand, call it a testa di moro - "Moor's head". But we make up for it with deadeyes - because they look a bit like a skull. The French call them caps de mouton - sheep's caps (unless it's an old name incorporating the Latin capitum - "head". Somehow sheep's head sounds more poetic.
