Happy to hear you had a grand time at the museum and model show. The hammock stanchions look great and so does the netting.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
41 minutes ago, SawdustDave said:
MEMORIAL DAY....
Being a veteran, I decided this would be my special Memorial Day statement.
Given the scale of the boat that certainly looks like a Garrison Flag, Dave.  Nice touch.
Jack
Current buildUS Constellation
Thanks guys.  The photo with the hugely oversized flag was taken using a flag which is now mounted over my wife’s brother’s grave stone.
Today is a very special day of memory and paying respect to our fallen warriors.
Cheers
Edited by SawdustDave
Sawdust Dave -
Current build - USS Constitution 1:60th (scratch)....
Visit my blog site - All previous builds.... http://davesmodelships.blogspot.com
TURNING TOPGALLANT MASTS....
With the outstanding build logs from a number of MSW fellow builders, I haven't found many things to share lately.  Most everything I've done lately has been my feeble attempt to emulate details found in their log postings.
I did, however, while turning the very delicate Topgallant Masts, wonder if my technique might be of interest to others faced with the challenge of getting very thin tapering at the end of a dowel.  Here goes....
The hardwood block of wood seen here has a small hole drilled through at the exact height of the center of my lathe chuck.  This allows me to move the block back and forth on the lathe bed while applying pressure with course sanding paper and files.
Pretty simple and very effective technique.
Sawdust Dave -
BELAYING PINS....
Before setting the three mast assemblies, I spent the last two days spinning tooth picks into belaying pins surrounding the fife rails.
Needed about 80 of these little guys.... only ten to go and I should be done with all belaying pins.
Sawdust Dave -
MAIN MAST ALIGNMENT.....
This photo was taken to visually check the vertical alignment of the Main Mast after rigging the first two shrouds.
Seen here, I used a plank laying across the lower rails with a framing square to check for perfect alignment.
I also used a plank laying across the fighting top to physically measure the distance of each side down to the channels.
Note....I will also be using a temporary stay line tied off to the bowsprit to physically hold the rake at 3.5 degrees as I proceed with rigging the remaining shrouds.
It's nice to see this phase finally begin, but I'm not real excited about it being one step closer to tying all those rat lines .....
(clove hitch, clove hitch, clove hitch, etc, etc...)
Sawdust Dave -
Nice work Dave and a nice touch with the large flag.  Yes, indeed, all our service men and women should be remembered and honored no matter what nation we hail from.  I have two I silently commemorate, August 18 and February 27 in addition to July 4.
Cheers,
                       VOC Ship Surabaya
Just finished rigging the shrouds and deadeyes for the Main Mast, and trying to decide whether to move on to the next mast or.....
RATLINES!!!
I really do dread the looming prospects of endless clove hitch tying (don't we all).... so, at this point, my inclination is to work on the ratlines for each set of shrouds as I go, thus breaking up the formidable task into smaller exercises.  Of course, this would include rigging the Futtock shrouds and Staves etc.
Also beginning to look at the rigging of the Bowsprit.
Sawdust Dave -
Dave, you will be surprised how fast those ratlines go when you get into a groove. I did all lower masts at the same time because I found that it was harder for me to come back to them rather then just do them all at the same time. Either way works though, so see what works best for you.
Dave, don't forget to add the forward line to the eyebolt on the channel.; every fifth ratline extends to it. But I am sure you are aware of this. :cheers:
Ken
Current build: Maersk Detroit"
Future builds:  Mamoli HMS Victory 1:90
Completed builds: US Brig Niagara, Dirty Dozen, USS Constitution, 18th Century Armed Longboat
https://modelshipworld.com/index.php?/topic/11935-uss-constitution-by-xken-model-shipways-scale-1768/
Dave, that could be slim pickings but if you have any questions just let me know. Keep in mind I will be out of the loop between July 19 - Aug. 7 and not sure about communications. I will be delivering the Constitution to my son in Southold, Long Island. A long drive from Morro Bay,Ca. 6130 miles round trip.
Ken
A little setback.... typical of me.
Had shrouds rigged to both sides of the Main mast.... rigged ratlines to the starboard side.
Then decided the upper deadeyes were too low..... ALL 18 OF THEM!
Yes I did completely remove everything.
Back to shroud #1.
:default_wallbash::default_wallbash::default_wallbash:
Sawdust Dave -
Back to shroud #1.
Not gonna' like that post but I do support the decision which obviously would be a very agonizing one to make.
PROGRESS..... Sometimes one step aft, two steps fore!
Happy to be back to where I was when my "fore progress" was interrupted.
Too many improvements to be of interest, so we will just move on from here.
Note, the production of rings and hearts to be used in the rigging of the Fore and Mizzen masts.
Also note that the addition of the starboard side futtock shrouds and ratlines.
Now ready to rotate the model and resume the exciting process of tying the port side clove hitches, etc. etc.....
Sawdust Dave -
TECHNIQUE TIP.....
Once in a blue moon, looking for a better solution to an issue, I might come across some little technique worth passing along to my modeling friends.
This particular one has to do with keeping the shrouds in true alignment as I work my way up with tying in the ratlines.  Don't know about everyone else, but I don't always manage to maintain perfect spacing between the shrouds around mid-way.  We've all seen it.... the tendency to allow those outside shrouds to CREEP INWARD.
Took a couple of shots to show my very simple and effective solution.....
Note the slit in my pattern paper about every third or fourth course of ratlines.
I simply pull the end of the line into the slits and touch it with a small dab of CA, thus locking the outside shroud in place so I don't have to be concerned with "Inward Creeping" as I work my way up.
Note, I have used tick marks on the pattern paper to indicate the spacing of all the middle shrouds.
Back to a few hundred more clove hitches.......:piratetongueor4:
Sawdust Dave -
11 minutes ago, usedtosail said:
Great tip, Dave. It also keeps the template from slipping out of position, I'll bet.
Absolutely right about that Tom.  Been fighting this annoying issue for over ten years.
Such a simple solution, huh?
Dave
Sawdust Dave -
Nice work and a great idea on the slits Dave.
Another thing that may help with maintaining spacing of the shrouds is to do the major ratlines (that go all the way across first, then fill in between.  I think I did the bottom then the middle and then the top majors, then the intermediates.  That helped me keep the spacing while I did the minors.  If your current jig resolves the spacing issue ignore this ramble :)
cheers
Pat
