Good morning Grant
i have just caught up with your log, i have missed so much,
The Bismarck - for me certainly was not a mistake, i lost my direction with the Victory, and rather than get rid of it i decided for a change of direction,
With my mojo back, the intentions are to have her back in the workshop around Easter, and push forward with her through the summer months, i dont want - or have the room for two big builds on the go at the same time
hope you are well
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi Grant,
I like what you are doing here mate and your process is well thought out and executed, however I think that the Anvil is a little thick. I feel they could be reduced a little from the underside which would add a little more shape to the horns.
It may just be angle of the photos I don't know and the real test will be when you attach them to the ropes.
The Caldercraft cleats attach to the ropes over the top of the anvil, will yours attach the same way or do you intend to attach around the base of the cleat.
I hope you don't mind me mentioning this mate.
Be Goodie
mobbsie
Sent from my IPhone
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Thanks for the comments and "likes" folks.
Bug - assembly line is the only way to go for these parts! Working with a larger piece of stock is also much easier than trying to shape these little critters individually.
Kevin - welcome back. I've been keeping an eye on your Bismarck, but I'll be looking forward to seeing more progress on your Victory.
Mobbsie - you just knew I wasn't quite satisfied with them didn't you? ;) I agree, the anvil is still a little heavy. I've got an idea half formed that I might try tomorrow - now that I've got the basic shape and method worked out, it shouldn't take too long. My biggest concern though is making the horns too fragile. To answer your other question, fixing to the shrouds will be via lashings around the "legs" and also around the centre portion - as per the actual ship fit. That's the intention, anyway.
Hi Mate,
Thanks for that, hope I haven't caused you too much aggro. :( :(
Good luck when you attach them to the shrouds, that's going to be some fiddly work, I still have that pleasure to come. :(
I'm having to redo the deadeyes on the main shrouds, didn't take into account the rope stretch, that's a real pain in the **** I can tell you. :( :(
That should make you feel a bit better. :) :)
Be Good and Stay Cool
mobbsie
mobbsie
Next Build :-
Hi Grant,
Would it help to sand a bit of a concave shallow in the top surface of the strip before making the other cuts?
I'm glad you mention that the grain direction issue messed with your head a bit.  In looking ahead a little, contemplating how I am going to make the cleats for my bulwarks, that was a puzzler for me.
Robert
Current Build: HMS Mars
Thanks Robert,
I think the top surface is okay in terms of when to do it. I'm thinking about being a little more aggressive on the side cuts though. I'll do a test today and let you know how it goes.
Glad to hear that I'm not the only one whose head gets messed with thinking about grain direction ;)
Okay, so I wasn't really happy with the last version of the shroud cleats.  I was being lazy and thankfully Mobbsie called me on it - thanks mate!  ;)
So this morning I had another crack.  As I'd already prepared another piece of stock with the basic saw cuts, it didn't take much additional work.  I widened the dados in the side, and filed the curves in again.
Here's the results of the latest effort (not yet stained black):
And here's a comparison of the new (on the left) with the previous version (on the right).  I've included a metric ruler as a reminder of just how small these things really are.
I think these are much better, but I'd value any and all opinions.  Do I go with these, or is it back to the drawing board?
I would be reluctant to try and make any parts thinner as I'm already down to 1mm square on the "feet' that will attach to the shrouds.
Waddayareckon?
Edited by gjdale
Thanks Robert and B.E. - your votes of confidence are much appreciated.looks like we have a winner. :)
Thanks Lawrence and Augie, and the "likes".  I think even Mobbsie will be satisfied with this version! :D:P
I've been pondering the Mast Cleats as well over the last few days and came to the conclusion that making wooden ones just wasn't going to do it - they would either be too large/chunky or too fragile.  So I got an idea from B.E.'s Pegasus log, where he had made some brass cleats from eyebolts.  That got me to thinking in terms of brass, and eventually I hit on the idea of making them in two parts (one for the "stem" to mount into the mast, and one for the "horns") and silver soldering them together.  So that's what I did......
Starting with some 1mm diameter brass wire, and cutting two pieces, with one bent at a right angle.  I deliberately made each part extra long to make it easier to handle.
Then a quick visit to the garage and a few minutes with the silver solder paste and mini torch:
Then cleaned them up with a file and cut each leg of the "Y" to size:
And finally, chemically blackened using Casey Birchwood Brass Black (thanks Danny for putting me on to that stuff! ;) ):
Now, unless Mobbsie sends me around the buoy on this one, I think these are ready for installation. :)
Edited by gjdale
G'day Mate,
Where do I start, firstly let me congratulate you on your new shroud cleats, they are so much better than the old ones, well done mate. :P  :P
Now, you only have a short trip around the buoys and you can do that in a row boat, is it possible to just turn the horns on the mast cleats down a little, I know they are tiny and they are good but I think you can improve them, by turning the ends down you will give them a better shape and the rope will not slip off.  :mellow:
This is just my humble opinion mate, you are onto a winner whichever you choose. :)  :)
mobbsie
mobbsie
Next Build :-
I'm with mobbsie - just a quick tweak with the pliers on the ends should do the trick.
The choice of metal was a good one too - just looking at the wood cleats I agree that they would be far to delicate, and would result in breaking and much cursing during the rigging process.
Colin
Current Builds: HMS Pandora 1/64 Scratch
                         Jeannie Johnston;
                         18thC Longboat with my son
Previous Builds: HMB Bounty - Caldercraft
Running Round my head: HMS Speedy (1782) - vaguely thinking POF
"If at first you don't succeed, try it your wifes' way"
Thanks guys - a small tweak with the pliers just prior to fitting the mast cleats it shall be then. :)
I really appreciate the input folks - constructive criticism really helps to achieve the best possible outcome. Thanks for keeping me "honest".
B.E. - silver soldering is not at all difficult. I'm still quite a novice, but seem able to get by to meet my needs. There is a good tutorial in the downloads section of the site. With your evident abundant skill set, I expect you will master it in no time at all.
Great work Grant, and the input for everyone is awesome. Since my next build will be from this time frame, all of this info and trial and error is going to prove enormously valuable!
-Bug
Nice work on both types of cleat Grant :) . Your method of making the brass ones looks a bit easier than the one I used on my Norfolk Sloop - I cut and filed them from 1mm thick brass strip :
BTW - did you use English Box for the wooden cleats or Castello? The English is probably twice as close-grained and can be cut and shaped to TINY sizes without falling apart :) .
:cheers:  Danny
Cheers, Danny
Thanks everyone for the comments and "likes" - all very much appreciated.
Danny - I used Costello boxwood. I didn't want to dip into my very limited supply of English Box for this job, especially as it was partially experimental. ;)
Bug - I get all my timber from HobbyMill these days, though you won't get any English Box there. For that you will need a balaclava and a baseball bat, and the address of someone who has some stashed away! :P Seriously though, English box is pretty hard to come by and I understand quite expensive when you can get it. Very happy for someone to tell me I'm wrong on this though.
Edited by gjdale
Bug-  That translates to a ski mask and a Desert Eagle .50 over here :D
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Hmm .... I have quite a stash I bought cheaply from a former ship modeller - but you didn't hear it here, and NO it's not for sale :D .
:cheers:  Danny
Cheers, Danny
:cheers:  Danny
Beware unexpected visitors wearing balaclavas in summer Danny!!!
Wonderful wooden cleats.
If they are still needed even smaller, here a little commercial for the case, if it is allowed :-)
http://www.dafinismus.de/plates_en.html#anker7
Cheers, Daniel
Edited by dafi
Excellent cleats Grant and a nice tutorial for those of us watching from the peanut gallery.
Did someone mention a stash of English Box? :ph34r:
Careful Mark.... I grew up in Oregon and I know exactly where Medford is. :P
-Bug
No problem.. I don't have the stash, but come by anyway.  We'll share a beverage.
