Follks  how do you age your decks on your wood builds, as wood that has been exposed to the elements even if looked after, goes a grey color with age.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Hi O.C. - what I did on my current build was I soaked the planks in household bleach for about 40 minutes,then rinsed them,then laid them out to dry. They turned a light grey when dry. The planks I used were kit supplied 1mm thick walnut,so I don`t know how that would come out using other types of wood - haven`t tried it on anything other than walnut. It didn`t seem to hurt the wood,either.
current build - HMS Vanguard - Model Shipways
Thanks mark,  the planks are already fitted on the deck so what ever I do will have to be in a controled manner and kept tidy,    I  had heard a bout a wire wool and vinegar trick,   painting that  onto the planks - and making sure they were sealed afterwards.
OC.
Edited by Old Collingwood
Current builds
Completed works.
I'm not sure anything acidic is good to use unless the wood is washed or the acid neutralized.  I've heard of sails colored in tea/coffee being eaten in a few years so I'd think the same would apply to wood but over a longer time frame.  This would apply to vinegar also.   I might be wrong and if I someone knows different, let me know and I'll delete this post.
Mark:
What's being described are chemicals being added to wood and a reaction starts - and then doesn't stop unless something is done to stop it.  Neutralizing as you mentioned stops it.  I would be very careful about doing anything that isn't able to be neutralized.  Not hard to dobefore it is installed but difficult after.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Right Kurt.  I think we're both saying the same thing...  I don't think anything acidic would be a good idea.
You can use some acrylic paint in a light grey color. Dilute this until it is the consistency of milk. Put a light coat on and let it dry thoroughly. Take a piece of metal (I use a #22 or #25 blade) and scrape the surface in one direction gently until you get the color you want. There will be variation in the color. But, that adds to the reality of the weathering.
Hope this helps
Thank you for all the replies,  I have decided to leave my planks sanded then flat top coated, its easier to do it this way.
OC.
Current builds
Completed works.
If the model is Royal Navy, at least during a particular time period, the decks were stoned nearly white once or twice a day depending on the
Captain's whims.
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
Another technique is to use white glue mixed with cigarette ashes and water...no only serves for the caulking also to give an antique look to the wood. Once the mixture has passed and removed with a slightly wet cloth, pass a fine sandpaper to remove even more excess.
(The same technique is used for the hull).
Completed.... Charles W. Morgan,Sea Horse,USS Constitution,Virginia 1819,San Fransisco II, AL HMS Bounty 1:48
L'Herminione 1:96
Spanish Frigate,22 cannons 18th C. 1:35 scale.Scratch-built (Hull only)
Cutter Cheefull 1806 1:48 (with modifications)
Current Project: Orca (This is a 35" replica of the Orca boat from the movie Jaws)
Amazes me to see this idea of ageing decks, most of the models are of warships with large crews that need to be kept busy, so sweeping, washing and scrubbing  supplemented by Holly Stoning was common. Saltwater wash downs acts as a bleaching agent and merchant ships had painted decks. These decks are on a Heavy Cruiser, kept white by salt water scrub downs with weekly holy Stoning using a cleaning agent made up of salt water, scouring powder, bleach and boiler compound, mixed the night before in a garbage can, which came out shinny. The decks in these 2 photos are 3 years old, they are not gray. The one looks like the decks have not been cleaned up after blowing tubes, they were seldom that dirty.5a39b8814b31a_DIRECTFROMCEARCLICK207.1.thumb.jpg.0d5bd842b601aefe181257baf6cacaab.jpg5a39b8b058b74_DIRECTFROMCEARCLICK209.1.thumb.jpg.ff134e92be6a4007c4c56533c8859678.jpg5a39b42cd358c_DIRECTFROMCEARCLICK206.1.thumb.jpg.7130827108510bc286cb1fdb310595ed.jpg
I use thinned acrylic paint.i mix up four parts brown (burnt umber) with one part blue (ultramarine blue) which makes a good very dark brown color suitable for representing tarred rigging at full strength. When thinned with plenty of water it makes a stain that you can paint on with a brush and controls with a rag or q-tip. You can gauge the color as you go and if it’s too dark you can wipe it up or buff off some of it with a moistened rag. You can also lightly sand right through this very thin coat exposing highlights that are pleasing to the eye. Certainly, as with any coating technique, I would try it out on scrap wood first.
Quote
 Niagara USS Constitution
Someone gave me a bottle of Hunterline Weathering Mix, Light Grey. It is a wood stain with rubbing alcohol solution so should not be injurious to the wood. I have not used it yet. www.hunterline.com
Joe
I am with Jud, as an ex-navalman I am mystified with some of the over weathering of models I see (mainly plastic).  I believe that through the ages, basic naval practices (cannot speak for merchant service) will be based around the same principles.  I am sure that as there was not too much shore leave (fear of runners etc)  one of the first things the First Lieutenant would have organised was a cleaning and painting party for the ship's sides etc.  I acknowledge however, this is more difficult in such times as performing blockades etc.
The ship is the sailor's home and cleanliness is paramount if you do not want a sick ship, or an angry Admiral/Squadron/Flotilla Commander.  Ship's husbandry and maintaining fighting skills can be achieved together.  Even in times of war, in most theatres some effort was made to keeps interiors clean, and basic ship's husbandry done on accessible parts of the upper decks and ship's equipment (especially life boats etc).  Yes in times like WWII, during prolonged partols or escort duty in rough weather (Murmansk run) would have prevented any maintenance at all.  That said, even during our long deployments (6-9 months) some effort was made to minimise corrosion and maintain the ship's appearance (but not at the expense of proficiency).
While I am not a fan, and this is intended as a personal opinion only,  I understand some modellers use weathering to display their skills - each to their own preferences and I do admire the skills required to do this level of weathering.
cheers
Pat
I feel weathering is dependent on the theme or state of the model/vessel you are modeling.  Even in brand new vessels a certain amount of weathering is expected if not avoidable.  Sun, salt water is caustic to wood and metal and to eliminate the effects entirely is, IMV not representing the vessel accurately.
Current build:
Finished build:
Current build(On hold):
Vast difference between how commercial and military vessels are maned. That difference is reflected in upkeep , maintenance and appearance. A military vessel depicted as weathered and worn out would reflect a long time in combat or sickness, a long voyage of a military vessel maned with enough men to fight her would still be clean, painted and taring kept up. Sail and lines may even have been taken down and drug to whiten them and prior to being seen by a Senor or Pears in port, a Skipper would insist in a through cleanup and paint touch up took place, even today. Depicting a military vessel rusty and dirty is not what you would have found in history except, after long hours standing at general quarters or exceptionally heavy weather right up to the harbor entrance. Military Store ships would have large crews to defend her, to handle the stores quickly and have the crew to do fleet maneuvers, unlike a small crewed commercial vessel sailing alone and watching expenses, even then when on long voyages, often long runs without handling sail would take place if weather allowed, maintenance would have been the rule of the day. Poor maintenance and extreme weathered appearance reflected hard use and neglect, no exceptions. If that is what you are modeling, weather them hard, if not, go easy on the weathering or do none and let time create the look. My opinion, each his own. That Troller, ( Cape Race, wood hull ), I rode to Alaska and back after fishing for 6 months, looked as good the day we returned to Belingham as the day we left, we worked the boat long hours and hard, her decks were painted haze grey.5a664adfdd067_RESIZED003.1.thumb.jpg.c38e4ee4f71345def802ab629d1d0408.jpg
Edited by jud
I read that one way of holystoning a deck was : the stone was attached to 4 ropes and
4 crewmen moved it back and forth over the deck while spreading sand around it.  This
would essentially be sanding the deck.  Now - I have sanded a lot of species of wood.
All it did was to return the wood surface to its native color.  Apart from Holy, no species turned white.
Actual Holy would not be a realistic choice for a deck on a ship.  The holystoning would remove a
sun bleached/oxidized grey and would help remove splinters which would be bad for the bare feet of
the crewmen, as well as any tar stains from foot trafic - but how did this change the color of Pine or Fir or Oak to white?
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
In my experience..it is like taking a piece of greyed pine(weathered) and then plane it down to raw wood...it becomes much lighter..hence the *whiteness* mentioned and referenced.  Fresh planed wood cannot be made any whiter then it is already is...not unless you bleach it with chemicals.
Even as you mentioned..tar stains and the like that came from dirty feet that have been climbing tarred ratlines and similar fixtures needed to be removed from the deck...I'm sure  holystoning made the deck lighter.  Buffing a high traffic area (In a tiled public building) with a buffer today is probably the modern equivalent.
Rob
Current build:
Finished build:
I use yellow cedar for my decks as it more closely represents a hollystoned deck. I asked a while back why modelers chose Holly for decking as it was just way to white.
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
The decks on the Helena were scrubbed with a concoction of Salt Water Soap, Scouring Compound, Boiler Compound and I don't know what else. It was mix the day before in a galvanized Garbage Can  and let to work over night, the can came out shiny. That was what the decks were scrubbed with ahead of the Holy Stone. The stones were a sandstone brick, oversized like some fire brick. A half brick was used, a dimple was chipped into one side so the end of a swab handle had a socket to ride in. Wet down, scrub using long handled scrub brushes then holy stone the wet decks. Seamen would line up on a board, place their stone on it and their swab handle in the socket, bend over and grab the handle with one hand, reach over with the other and grab the forearm  and hold the handle against the shoulder at the same time. a Chantey was used to keep the timing,'one a rock, 2 a rock, 3 and a 4 a rock building up to the number of strokes wanted, then Shift a board was entered into the chant and start the count over. 10-12 men could holy stone fairly quickly, most chose to be bare foot with pants rolled up. Salt water was used from the fire mains, fresh water on a Steam Ship is not used to clean weather decks. Our decks were Teak. Can find some data on line to fill in and add and perhaps correct what I observed.
I think we are digressing from the OP's original question.  How do you age a deck to look.....weathered?
Personally I use extremely diluted India ink in 90~100% Isopropyl alcohol sprayed on from a spray bottle.  The ink is spread along the cracks and creases using capillary action and then the alcohol evaporates and leaves a nice *Weathered* surface.
The extent of the Weathering depends on your ink dilution and your application.
Rob
Edited by rwiederrich
Current build:
Finished build:
That's an interesting technique Rob, have you any pictures of a finished deck you have done?  From your description, I think that would look pretty realistic.
cheers
Pat
This may not be of any help to you at this point, but on the "old" ships the decks were holystoned which gave them a whiter versus grey finish.  Holly is an excellent wood to give this look.
Allan
cheers
Pat
Pat the technique works on any thing you want to weather.  You can substitute brown Ink for the black if you like.
Here are some images of the Revell Cutty Sark I converted into the Portuguese Ferriera.  This is modeled when she was at her lowest, rotting in some backwater. before she was purchased and rebuilt to her original glory.
I applied the alcohol technique to everything and then applied cerium oxide(which is an extremely fine(5 micron) powder to dust and add further ageing.
Rob
Current build:
Finished build:
Thanks Rob, that is a really great finish; a very believable 'mothballed' look to her.  Thanks for sharing.
cheers
Pat
There is and was probably a big difference between commerical and naval vessels. As has been pointed out before, on naval vessels intensive maintenance was both, a necessity to maintain a good fighting capability and a work-therapy for large crews that otherwise would become bored and unmanagable very quickly. During WWI and WWII particulary the axis powers faced supply chain issues, lacking spare parts and materials. War losses also meant long duty-cycles with only short breaks. All this together had its effect on the appearance of say German ships.
Apart from the aspects of owners' and master's pride, crews as small as possible meant also that maintenance was only carried out when really needed and there was the spare time for it. So, after a rough trip across the North Atlantic they may not look their best. Or, fishing vessels constantly moving between ports and fishing grounds will look rather worn, at least during the season - maintenance is carried out during the off-season. There are plenty of old photographs that show particularly smaller ships involved in local trade are not all 'shipshape and Bristol-fashion' as Dana put it.
Coming back to the original question: I used a mixture of approaches, namely washes with burnt umber (I would rather avoid black as being too stark) and white, as well as a dusting with white pastels. It may be worthwhile to have a look at what railway modellers do, who sometimes are quite fond of the aged and degraded. Belwo is an example not of a real wood-deck, but a painted one. However, the weathering technique would be more or less the same:
http://www.maritima-et-mechanika.org/maritime/models/botter/BotterModel/BotterModel-088.jpg
