HMS Kingfisher 1770 by Remcohe - 1/48 - English 14-Gun Sloop - POF
The ships boats are just (like the rest of the build) exquisite (Mozilla's spell checker helped me with that word ;) )
a silent "oh, my gosh" sips through my lips when I browse all you images. Great!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Link to comment
Share on other sites
Remco,
good to see your build log again. Dans and your work are the main inspiration for me.
Regards Christian
Link to comment
Hi Remco,
Anja told me that I have to take a look at your build.
She ask me that several times.
I was wondering why.
But now I've seen it, I know why.
Really great work
When I look at the builds of you and Mark and Danny and some much more scratch builders I just feel like a novice.
What you can do with wood is almost out of this world.
Sjors
Link to comment
Great save, Remco. I had forgotten about your marvelous hold diorama consisting of ballast, pig iron, weaved basket and barrels. At what point, if any, will you find it convenient to add the items permanently into the hold?
Greg
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Link to comment
Thanks all for your kind words! It was fun for me too to go through all the pictures and make a summary of what has been going on over the  past years. Brought back a lot of memories. There is more but I didn't want to make it too long. Dave (Midnight) has a backup of my log and Dave and Danny are sorting things out to get it in a format easier to repost. So hang on and at some point the text will be back too.
Greg, if I'm going to add the items (I'm not sure yet) it will be when the fore platform is ready. I think the sequence will be finishing the main mast partner , switching to the fore platform. And then adding the ballast. I need to figure out a way get them secured permanently. There will be lots of handling of the hull for time to come and I don't want to have pieces flying around. I think it's wise not to use the gravel.
So now I'll reconstruct my last post on the old log and than move forward. It was a little how to make copper bolts, I use them extensively
First the end is rounded  off with a cup burr
The bolt is cut
The cutting leaves a little burr on the edge that needs to be removed, other wise I'm having a hard time inserting the bolt in the hole (my drills are 0,5 mm and the rod something like 0,47 mm so the burr gets in the way). Rolling a steel ruler over it does the trick.
Next up is making a thin burr half way down the bolt. This will keep it in place so I don't have t use glue to fix the bolt. The blade is rolled diagonally with light pressure over the bolt.
Now the bolt is ready to be installed, I use a home made pushpin with  a small hole in the tip so the dome of the bolt will protrude. Blackening is done with liver of sulphur once installed. I make them in small batches so it doesn't become to tedious. I don't dare to make an estimate of how many bolts will be used in this ship.
And here's the current state of the foremast, holes can be drilled in the cheeks for the bolts.
Edited by Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Link to comment
Hi Remco,
I'm pleased to see your HMS Kingfisher buildlog up and running, looking forward to more updates :)
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Link to comment
Hello Remco,
Ryland Craze recommended your build log to me, he said I would enjoy it, boy was that an understatement!  Let me say your work is FANTASTIC and I look forward to following your build.  You are truly an inspiration to a mere kit builder as myself.  :)
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Link to comment
Remco,
I've said it before and I'll say it again, you have the cleanest, sharpest, most accurate building skills I've ever seen!  Your photos are captivating and are an inspiration to us. Thanks for sharing with us (again).
Regards,
Clay
Current build:  HMS EURYALUS (36) 1803  1: 48 scale
Link to comment
Glad to see you repost this great build mate.
A quick question.  How do you fit the round hole of the cap to the topmast (place the topmast into this hole)?  I am building the caps for my Endeavour and find that with the 6 sided beveled conical piece at the top I simply cannot slide it through and I have had to cut the calp[s in two longitudinally.
cheers
Pat
Link to comment
Thanks for the kind words folks.
cheers
Pat
Well the topmast is supposed to slide in from underneath, so if I make it the right size it will fit like its supposed to. The Swan's topmast is octagonal at the bottom and round from there on to the top
Hi Remco, is there no end to your ingenuity to find solutions to the problems you encounter in this marvellous build, thanks for sharing it with us.
Martin.
:) Only time will tell
Remco
Link to comment
Hi Remco,
Good to see you back at it :D .
Only about 2000 :huh::D  .
:champagne:  Danny
Cheers, Danny
Link to comment
Good morning Remco!
Can I ask you to explain your "treenail technique"? How you get so small pieces of wood in diameter and the wood you used for them. Is amazing to see the framing process on your log.
It used to be a topic about this.
Thanks and good week to all!
Daniel.
Link to comment
Hi Remco,
Your Build log s definitely appreciated again. I am amazed at your perfect wood and metal craftsmanship.
Is there any way you can perhaps post a tutorial on how you manufactured your metal hinges like the one in your image "IMG_7922.jpeg"?
John
"Without ships there is nothing"
Link to comment
Truly marvelous work Remco . Glad to see it up and running again .
Cheers Dave
PS . i have sent you a PM about your log i saved .
Thanks Dave I got all the files in good order 58 Mb  :o of pdf content to process..
Good morning Remco!
Daniel.
Daniel, I use the Byrnes drawplate and use boxwood from Hobbymill cut to 0,8 x 0,8 mm strips. Its a matter of gently pulling the strips through the plate.
Hi Remco,
Unfortunately I didn't take pictures of the process. If I remember right I flattened brass rod, cut and filed the pieces into shape and silver soldered them. By the looks there are 3 pieces, the bolts are simulated by drilling small holes.
Remco
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
