Thank you all for all the likes!
I am done making mouldings now.
Now, it is time to do some filling and sanding and then to do a little paint work before getting to the inside of the head rails becomes difficult.
This will also give me a chance to fix some minor problems elsewhere with the paintwork.
Edited by GrandpaPhil
Building:
Thank you all for the comments and the likes!
 I did some priming and some paint touch ups (the black anyways).
The Victory is looking better.
Tomorrow she’ll have some color added.
Building:
Very nice job, the headrails look A1 with the coat of black paint Phil👍
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thank you all very much for the comments and the likes!
I have the starboard side base coated and have done some touch ups.
I’m happy with how it’s turning out.
Now, on to the port side!
Building:
Thank you both, very much!
Mark,
  I carved them from 1/16” basswood based on the picture in the AOTS.  You should give it a try.
This build has been a great learning experience for me.
Building:
I have read thru your complete as of today, thread on the most excellent craftmanship, you have put into your model of the Victory.  Not sure here, but looks to me as if you might also build card models with use of card/paper incorporated into your build.  I was most impressed over the video in this thread that corrects the color palette for the HMS Victory.  Years ago, and where the article was slips my ole memory, I read that the guy doing the article said the shades of yellow were not correct for the time/period.  He was lamb blasted for the comment from the modeling community!  Looks like he is due a apology.  Will admit, does take some getting use too in that shade.  But some research will show for the time frame as the Victory has been shown with the orange/yellow would not have been correct, because the color did not truly exist in that hue for that time.  Where as the color as we see now being applied, did in fact exist!  So does give one pause, too bad we can't ask Lord Nelson.  But I digress, your build shows what one can do if willing to put in the time and effort.  I have never tried wood carving, my ole eyes are too tired now for such as that, but for those who do give it a go, are rewarded with great results.  Oh, I liked the Crow, have ate my share of it in life!  Just so happens, I have setting in front of me a project that has been calling my name for over a year.  Two years ago, I purchased for a song the 1/78, Kit#782, Mantua/Sergal HMS Victory.  This is the pre-laser cut kit.  One has to hand cut parts from sheets.  Does have the then what was referred to as Photo-Etch for the Stern Galleries and other assorted details.  This is a monster of a kit.  The box w/material is heavy to say the least.  Is packed w/a lumber yard and the fittings are wonderful.  The figures/figurehead are lost wax castings in brass.  Many say the figurehead as comes with the kit is too out of scale, but I will use it anyway.  Years ago, I ordered from the UK a small piece of wood that came from the Victory.  It came w/a certificate stating it was removed during her last refit.  I plan to use on the model and think it is just way cool to have a piece of the real ship in the model.  I also have all the books and material, will add as I see fit, but not get bogged down in the details.  I do plan to paint and copper the bottom.  Yes, I will go with the new color bands and mast.  Looking forward to more of your build.
Rick
Neophyte Shipwright
Wisdom:  When all else fails, read the instructions!
 I adjusted one paint scheme and have the opposite piece mostly carved.  It’s currently drying because I may or may not have broken it in multiple places and had to glue it back together.  I threw in a ruler for scale (English units, I only use metric if I have to).
Building:
Rick,
  Thank you very much.  I have built a few card models.  I haven’t had much luck with card kits, but I did scratch build the Prince de Neufchatel from card, which came out well.
I have found that it is easy to work and very useful.  It’s also surprisingly strong.
Building:
17 hours ago, GrandpaPhil said:
Rick,
If one is willing to experiment, using the right weight material.  Many small details can be made from card.  Complex shapes can be made from laminations.  Then seal the card and paint.  One is hard pressed to tell it was made from this material.  I have built many card models over the years and I have seen some that rival conventional model building materials, ie: wood and or plastic.  Looking forward to more of your build.
Rick
Neophyte Shipwright
I carved another piece of the figurehead.  That’s definitely one of the more complex pieces that I have ever carved.  It went better than expected.  I have the port side made, except for the scroll work which goes across the bow.
Building:
