Cruiser Varyag 1901 by Valeriy V - FINISHED - scale 1:75
9 hours ago, Wreck1919 said:
Privjet Valeriy, can you share a picture of how you built the platforms ?
cools stuff. Regards sascha
Hi Sasha. I'm afraid I didn't understand your question. Google translator distorts a lot when translating three times.
  Show on the photo with an arrow what detail you are asking about. :)
Edited by Valeriy V
Link to comment
Share on other sites
37 minutes ago, Wreck1919 said:
Как ты построил платформу в мачте?
извини грамматика 😎
саша
It is fixed between two parts of the mast. Like a washer between a nut and a bolt head.
If I understood you correctly. :)
Link to comment
Valeriy - your soldering is always very neat. You must tell me how you keep it so clean.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Valeriy,
Very nice work - as usual!
I sometimes use a Dremel motor tool with a wire brush to remove excess solder from joints. It is very effective for removing excess solder.
Link to comment
There are also triangular scrapers with the 2.34 mm shank of the standard burrs, which can be conveniently held in a pin-vise.
Long before I learned about all the fancy jeweller's and engraver's tools, I bought a couple of cheap, about 2" long screwdrivers and ground their ends into chisels/scrapers for cleaning out soldered corners.
Link to comment
Arrrrgh! You have all shattered my dreams. I thought Valeriy had discovered some way of only making the solder go where he wanted it to go. I am a broken man!
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Well, flux is usually what will steer the solder, especially if you use it sparingly.
Yves
Link to comment
53 minutes ago, Brett Slater said:
As someone who is yet to venture beyond plastic and wood but is thinking of metal work can anyone recommend books or other resources that would help me get started ?
Brett - this would be a good start:- https://www.amazon.co.uk/Model-Building-Brass-Ken-Foran/dp/0764354949
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Brett - alternatively look up Gerald A Wingrove - he has written an number of books and you can find some of his work on MSW. Sadly Gerald is no longer with us. RIP.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Good work as usual Valeriy
Ras
Current builds:
Stern Paddle Wheeler ZULU-1916-1/48 scale
Previous builds:
Freccia Celeste-1927 350cc racing motorcycle-1:9 scale-Protar kit
Boeing B17F- 1/72 scale- Hasegawa kit
HMS Mimi-scale 1/24-Fast Motor Launch
Amapá 1907-1/64 scale-Brazilian Customs Cruiser
Scottish Motor Fifie. 1/32 scale. Amati kit
Patricia. Steam powered R/C launch. 1/12 scale. Krick Kit
African Queen. Steam powered  R/C launch. 1/24 scale. Billings ki
Emma C. Berry. Sailing fishing smack. 1/32 scale. Model Shipways kit.
Link to comment
Valeriy. Very impressive - as usual. The ratlines are particularly neat.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
1 hour ago, Valeriy V said:
Metal ratlines  are therefore easier to work with
 Ah! that makes a lot of sense - good idea. What are the vertical lines (shrouds) made from - they look like a braided wire?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
I gather this depends on what was used on the prototype. In Valery's case, these are not sail-carrying masts I believe and at that time, indeed, iron bars or wooden battens were used as rat'lines'. In Keith's case this is a traditional sailing rig with (probably) metal-wire shrouds and hemp ratlines.
It is rather difficult to tie knots into wire (I tried repeatedly ...) and wire kinks easily, which then are difficult to remove. If anything, I would use twisted wire for the purpose, as twisting two or three wires together makes them more flexible and less prone to kinking.
Still, I would look for the thinnest fly-tying yarns that you can get hold of. The thinnest I found was Veevus 16/2. Caenis also makes very thin ones. Avoid the monofilaments, because knots dont't hold in them very well and they look unnatural, because they are smooth.
Link to comment
You cannot fool me  Valeriy. We all know that the Russians like to have the largest of anything and you keep inserting giant matches into the picture to make all else look small!:D....................... I am, as always, astounded with your work. Hope that translates OK!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Lou, I realized that my little trick with the big match failed.  :) :)  I'll have to think of a plan "B"...  ;)
Thank you for your cheerful feedback.
Link to comment
Masterful work once again Valeriy.  Such excellent craftsmanship.  And I really like that point-of-view photo in post 682.
Gary
Completed Scratch Builds
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
