Varyag 1901 by Valeriy V - FINISHED - scale 1:75 - Russian Cruiser
32 minutes ago, wefalck said:
Only two things are missing: the trigger and the finger-guard at the pistol-grip
Modern rules: the guns must be de-commissioned. 🤐
STAY SAFE
current builds:
Link to comment
Share on other sites
Beautiful guns. They look nicer than my Amapa’s and mine is at 1/64. And, by the way, I also missed the firing pistol.
Ras
Current builds:
Stern Paddle Wheeler ZULU-1916-1/48 scale
Previous builds:
Freccia Celeste-1927 350cc racing motorcycle-1:9 scale-Protar kit
Boeing B17F- 1/72 scale- Hasegawa kit
HMS Mimi-scale 1/24-Fast Motor Launch
Amapá 1907-1/64 scale-Brazilian Customs Cruiser
Scottish Motor Fifie. 1/32 scale. Amati kit
Patricia. Steam powered R/C launch. 1/12 scale. Krick Kit
African Queen. Steam powered  R/C launch. 1/24 scale. Billings ki
Emma C. Berry. Sailing fishing smack. 1/32 scale. Model Shipways kit.
Link to comment
Valeriy,
I just spent the day re-reading your log from start to here to refresh my memory of your building techniques. I wanted to see how you get such beautiful finishes on your metal parts.
You said you used Zapon varnish on the brass parts, and you nickle plate a lot of the metal.
How do you polish the metal before paining or plating it?
Does the metal plating just naturally produce a smooth shiny surface?
Link to comment
Phil, polishing brass is not a very difficult process.
1)  If I make a part on a lathe and the forosho cutter is sharpened, then the surface of the part already becomes smooth.
After that, I sand the part with sandpaper of various sizes from about # 320 to # 1200 until I get the desired shiny surface. This part of polishing is easier to do immediately on a lathe, but if the part is complex, then you have to work manually and with a drill.
Link to comment
3) The final operation is the coating of the zapon part with varnish. This transparent varnish will close the surface of the metal from the access of oxygen and the brass part will retain its mirror shine for a long time.
If the detail is small, you can apply varnish with a brush, if it is large, you can cover it with a balloon.
Link to comment
Valeriy,
Thanks. I have used some rouges for polishing but I was interested in how you do it. Your results are beautiful!
I have also puzzled over what to do when a bit of solder flows over visible areas on brass parts. The tin in the solder dissolves into the brass leaving a tin colored stain. Careful positioning of the solder areas to inside or non-visible places helps, but sometimes a visible solder fillet is necessary. Blackening and other coloring agents don't work evenly over these exposed high tin areas.
But it seems you solve this problem by nickle plating the parts. The plating covers the brass and solder areas evenly. Looks like I will have to set up plating equipment. I already have power supplies and I was an undergraduate chemistry major so that part will be simple.
Link to comment
Valeriy, wonderful guns - no one will miss the detail.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Phil, nickel plating won't solve your problem. On top of the tin, the nickel will be darker than in the adjacent brass area.
To solve this problem, it is necessary to open the part with copper before nickel plating.
Link to comment
Valeriy,
Thanks. I did notice that you plated some parts with copper before nickle plating, and wondered if that was to get a more uniform nickle plating.
But the real solution is to just be careful with the soldering. Using a minimum amount of solder helps, and a good liquid flux (I like citrus based fluxes) helps promote solder flow between pieces.
I also have a resistance soldering machine and have experimented some with it. It has the advantage that heat is generated at the contact/solder point, reducing heating of adjacent parts and previous solder joints.
Link to comment
This last session feels like I am attending a class with the best professors sharing their knowledge. Thanks
Valeriy, tell me what is forosho cutter.
Ras
Current builds:
Previous builds:
Link to comment
Wishing you the best Stay safe
Ras
Current builds:
Previous builds:
Link to comment
Ditto on Sasha's comments. Beautiful work. What is amazing to me is how you can duplicate pieces so accurately at such a small scale.
Ras
Current builds:
Previous builds:
Link to comment
Thanks to everyone who follows my work for your likes and comments! :)
Judging by my life, I can say that difficult times exist all the time, they sometimes become less difficult, and sometimes very difficult. But both will have to be lived to the fullest.
Ras, this duplication is helped by the use of turning and milling machines.
Link to comment
Hello Valeriy,
happy to hear from you.
Your philosophic view of difficult times in life pleases me very well, and I am sure you have not forgotten to live to the fullest your easy, beautiful and happy times, too.
Your work is breathtaking as usual.
Best wishes and greetings
Joachim
Link to comment
Valeriy,
  Glad you are doing okay!  Those guns are amazing!
Phil
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
6 hours ago, cotrecerf said:
Hello Valeriy,
Joachim
Thanks Joachim!
I hope that my happiest times are still ahead of me. :)
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
