1 hour ago, rkwz said:
Hi Backer, if you don't mind me asking, what kind of jig did you use to hold the deadeyes in place for the shrouds?
None, i cheat
First assemble the deadeyes on the right place and glue with extra thin glue (Tamiya)
Allow to dry (24h !)
Only after that tie it to the lower schrouds
Ready
Edited by Backer
17 hours ago, Backer said:
None, i cheat
Ready
Sorry I actually meant the lower deadeyes 😁, but I would hardly call that cheating... Those futtock shrouds will be a pain later for me too I foresee.
I was worried that tying clove hitches for the ratlines would look out of scale myself, but yours is proof it can be done and still look great!
No jig has been used. Everything is done "on sight".
Make the deadeyes, drill holes and put in place.
For me, plastic ship model building is easier than wooden ship model building.
Let's say it is something like the"fingerspitzengefühl" build up after more then 1400 plastic models.)
2 hours ago, G.L. said:
Microscopic work.
Nice ropework, Patrick!
Thanks,
The space to work easily on this scale is indeed rather limited.
And this space is becoming less and less as more and more ropes are added.
So the hardest part is yet to come
Small update.
One thing I have learned on this forum is.      If you don't like something you've built. Remove it and rebuild it a 2nd time.
Not really neat and correct. So remove and rebuild.
New parts in progress
IMG_20200208_115619.thumb.jpg.3c35883b9e4e862f44fecbe0edacc7ba.jpgand painted
Better, except the visible error (arrow)
Addet some black paint,  error "invisible"
Not entirely correct but much better.
Did this on all the 3 masts.
Thanks for following.
Edited by Backer
Back when I was a teenager (60's) I spent a day on the Bounty. If I knew then what I know now I'd have
a boat load of pictures. 20/20 hind sight. The quality of your work takes me back to the good-'ol-days.
But I did have fun building my piece of nostalgia.
By any chance, was your visit to the Bounty in St. Petersburg, Fla? I visited the Bounty there in the 60's as well. I believe it was still there in the 70's.
On 2/9/2020 at 4:25 AM, Backer said:
Small update.
This attention to detail is outstanding, especially given the small scale of the model!   The black paint idea is a good one — I have also had to remedy things sometimes when I haven’t got the actual result that I initially imagined, and I think that that is ok.
Thanks again for the nice comments and likes.
The rigging continues.
IMG_20200214_145723.thumb.jpg.c6606269e6b345d35c73f9f7594ab58a.jpgIMG_20200214_145734.thumb.jpg.e5cf1a99e7e6d9b915eecdafc5bc7466.jpgIMG_20200214_145752.thumb.jpg.a50aac5da8ee0bd1ed1a955a81318e0d.jpgIMG_20200214_145852.thumb.jpg.050ed7247b4b3b4a7c1a665d750e255e.jpg
Started with the schrouds on the top masts. These thin parts of the plastic masts are very fragile.
It is not easy to do rigging to these flexible pieces. It would have been better to replace this plastic with wooden parts in advance, i think.
Got the HMS BEAGLE kit around 1966, when I was ten, and built it then, 'oob' as one would say today. Got the HMS BOUNTY kit around 1970, I think and started to built it. In 1972 I first visited the NMM in Greenwich, which was a revelation then. They had some drawings of the BOUNTY on display then and I got the permission to take pictures. However, I didn't know about the archives and how to get access to them at that time.
Already, when working on the BEAGLE, I didn't like the plastic shrouds, but didn't know any better. Still using the dead-eyes from the kit, I properly (well, more or less) rigged the shrouds and rattled them down with ratlines. But then the project ground to a halt, because I just could not come up with a solution for blocks of a sufficiently small size with my limited experience and tooling. No Internet to be even dreamt of ;)
I still have the model, boxed up, but I don't think I will ever complete it, because I recognise my juvenile mistakes and would need to completely redo it.
Good luck with your project !
Thanks for the likes and positive comments.
1966, then I was 2 years old ... These Beagle and Bounty kits apparently recall a lot of memories for some of us.
Meanwhile
Hoera, Hoera. Standing rigging is finished.
IMG_20200220_192713.thumb.jpg.312169570e108636d05e51ce08041328.jpgIMG_20200220_195841.thumb.jpg.5047cf68c1828123b99266b15e489c9f.jpg
Started with the build of a base plate.
An old photo frame that my wife wanted to throw away.  The inside is filled with a wooden plate
And no I don't build a railroad ;)
drilling holes for 2 screws
Drilling holes in the keel. ( i should have done much earlier, this was a bit stressful)
Painted
And the model screwed onto the plate.  Before screwing, liquid plastic glue has been put into the holes of the keel. This way the screw goes in easily and thread is "tapped"  into the holes.
There will be extra supports on the sides. 1 unpainted test model is ready
The blocks that I have now (scale 1/100 of a Heller Soleyl Royal) are unfortunately too large for the running rigging.
I have  made 1 unpainted (test)block in plastic.
The wooden blocks that you find in most wooden kits served as an example.
The hole in the block is diameter 0.7 mm.
Love the base, suits the model perfectly.
A beautiful build.👍
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Patrick, you have done a phenomenal job on this build!  You have taken an average kit and made it a show piece.
I will refer to this build often as well as your other builds.  I am almost sad that you have finished, I look forward to your next build.
such a beautiful ship Patrick........the mods you've done is right off the charts!  the perfect example of what can be done with an old kit ;)    superb looking model :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you everyone for the nice comments and likes.
This old kit has become a real challenge.  And so far also my cheapest plastic model kit.
A kit for free, some plastic sheet, glue, some paint, and some leftovers from the spareparts box.
Meanwhile :  Started making spars.
The designers of this kit made it easy for themselves when making the mold.  Some spars are simply identical to each other (see sketch)IMG_20200224_184610.thumb.jpg.2516adb4f1d8d6a61f83340b240d0f77.jpgIMG_20200224_185306.thumb.jpg.312268d1230c6a22aad3fb9a5d5ef031.jpg
"Cleaning" the spars
Oops,
Very flexible. Later it also appeared that they broke quickly ...
The plastic spars are all in waste bin.
New ones are made from toothpicks
And from small bamboo sticks. They are used in plant pots. The processing of this bamboo was fairly easy
IMG_20200226_190836.thumb.jpg.7219fc55f4b27ee9bda6b412a8f75d25.jpgIMG_20200226_191248.thumb.jpg.dbbc602154403decfc9c73df212f09a8.jpg
Tools used
Wooden spars (Some are still a bit too thick in diameter)
Hi Patrick.
Great work and a pleasure to follow the progress.
About the plastic spars : the minimal tension while rigging your ship would probably deform them anyway.
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
Nice work! For my plastic Victory I haven't decided yet whether to replace the spars with wood... (Was thinking maybe to glue the lines and stretch to give the illusion of tautness but personally prefer it natural).
Watching your progress with great interest 💪
Good to see you moving along again on this fantastic little model. I will follow with joy and ever constant interest on how you improve the kit you started with.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
10 hours ago, SigEp Ziggy said:
So glad you are not finished yet!  Can't wait to see more!
6 hours ago, Barbossa said:
Hi Patrick.
Thanks everyone.
These plastic spars are really not suitable for the use in this way. Cleaning up one spar took about as long as making a new one in wood.
For someone who builds a plastic ship for the first time and chooses this model. Follow the kit's instructions for masts, spars and rigging. At first sight nothing can go wrong.
And, winter is coming to an end (actually we have not had a winter this year).
It is almost time for me to switch back to the shipyard of my wooden shipmodel.
I'm starting to miss the dust and smell of sanded wood
Due to the restart of my Golden Hind shipyard, this build has been temporarily put on hold.
Thank you for following this build and the positive comments.
Reopening of this shipyard is planned for October – November 2020
I hope to see you all back again.
Have a good break from the little plastic Bounty... I will be looking forward to seeing the running rig later this year!
Will you be posting your Golden Hind on this forum too?
Thanks,
