Proof that dogs will eat anything. What are the other two pathological objects, I wonder? Hopefully recovery will now be smooth, Toni, for both woman and dog!
Hmm... complementary $15 pedicure for I'm guessing $3000 of veterinary bills. Sounds like a good deal, Toni. It's an axiom among us veterinarians that if there is to be a "complication" it will always be a physician or lawyer's pet. I hope she continues to improve under you home care and remember - she's as likely to eat your new galley oven as she is her treats!
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Thank you everyone for your kind thoughts.  She is sleeping right now so I have a few minutes to post my progress on the stove.
There are a lot of descriptions of the galley stove on MSW as well as in TFFM Vol 2, so I will not belabor that here.  The stove is a model in itself and I have been playing with it for a month already.  The first decision to be made was what materials to use.  This would also drive the construction technique.  I decided that this was a detailed "representation" of a stove but that no one would be cooking with it.  Therefore, sheet brass was eliminated from consideration except for details.  What I came up with is a collection of wood scraps, aluminum adhesive tape and shim brass.  The side panels have three larger doors and one small one.
After these were made, a spacer was put in the middle of the stove and the fore and aft faces were constructed.  The bolts, cooktop and chimney were added.  The rest of the details will be added later.
The stove was fit in place on the model and was too tall.  So back to square one.  I shortened the height by 6" and it fits nicely.  It was painted with flat gray primer and flat black (Testors rattle can).
I am sorry the pictures are not of be best quality.  It is hard to pick out details on a black object so I played with Photoshop so you could see more than a black blob.  The lids for the pots are brass sheet which was drilled for the brass wire handles.  So far I am happy with the results.  It actually looks like a stove!
Next up will be adding the details to the stove, making the base plate and installation.
Toni
Member IPMS
                           Utrecht-1742
prayers to your dog, here's a picture of our former dog Sadie and My son, who's now 20
Sorry it's not nautical but I'll take the hit/warning as how many other Dalmatians named Sadie do I know
Captain America and Wonderdog
by jr jacobs, on Flickr
D3X3279-Americana
by JRJacobs aka System13
Photos can be seen at https://www.flickr.com/photos/system13
From U.S. Navy
I keep coming back to look at it over and over again
I have to say I really like your stove
Alan O'Neill
Great looking stove.  It looks like iron to me.
System, thank you for sharing your picture of Sadie with me.  Hopefully my Sadie will be able to pose for the camera soon.
Thank you everyone for your kind comments and thanks for all the likes.  The good thing about a recuperating dog is that they sleep a lot.  So I got in a little workshop time today.  With something as complex as a stove, one needs to ask how much detail is necessary.  I decided to make the spit holders, the vertical ash grate (the horizontal one cannot be seen once the stove is installed) and the ash bin.  These were made from brass wire and shim brass cut and filed to shape.  I rolled the grate rods between my fingers to get that "used" look.  I left the ring bolts bright just for some contrast.  I may change my mind and blacken them before final installation.  They are only press-fit in place.  The stove and ash bin sit on an iron platform.  I used blackened brass and burnished it to get some color variations.  I am considering removing it as the stove visually fades into the black background when viewed from above.  One must remember, unless I put a fiberoptic scope through a gunport, the only way the stove will be seen is from above.  I will decide in the next few weeks.
Edited by tlevine
Toni
Member IPMS
                           Utrecht-1742
A fine looking stove Toni, to complement the rest of your very fine build. Best wishes to Sadie for a speedy recovery.
Best wishes to Sadie!  Let me join all the cynophiles in hoping for the best.
And that's a great looking stove -- I like the idea of using wood instead of styrene-covered foam or something.  Wood is always more fun to work with.
Cheers,
Martin (and Bounce)
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Grant and Greg thanks.  Martin, I thought about using brass sheeting rather than wood, just for the experience.  However, wood is a lot easier to cut.  The  more I look at the stove installation, the more likely I will keep the "iron" plate underneath the stove.
Toni
Member IPMS
                           Utrecht-1742
This is an interesting observation.
When the only function of a piece is to look like something else from a visual point of view in a general way, without needing the other attributes of strength or function. It makes sense, at least to me to use the materials that one finds comfortable working with.
There will be plenty of opportunities to practice with brass when it is a more appropriate material for its functional attributes.
The only time I would fuss or worry about using the same type of materials is when making a replica of something that clearly shows the materials that the original was made from when viewed up close.
Patina over copper or brass comes to mind, and there are folk who can do a convincing job of that with paints even so.
Nice work on the stove it looks great.
Michael
The stove is looking eally great
Regards Christian
Toni your stove is great and it is a shame that most of it will be hidden from sight and will not be noticed by most people.  It i  model in itself.
David B
Thank you Michael, Christian and David.  Robin, I have been away for the weekend so am not near the ship.  I will take a good look at her tomorrow and hopefully have some type of answer for you.  As to the four-legged friend, Sadie is doing very poorly and will probably be put to sleep tomorrow.  Thanks for asking about her.
Toni
Member IPMS
                           Utrecht-1742
I'm sorry to hear about Sadie, Toni.   This is not good news.
Toni, I'm sorry to hear you may have to put your dog to sleep.  As a dog owner I know that's the hardest thing to do, but it's the ultimate gesture of love shown to your pet.  You never want to see  them suffer.  I don't look forward to the day when I will have to make that decision for my dog Toby.
Toni, so sorry to hear about Sadie. I know how hard it is to make that decision. You have my most sincere sympathy.
Jim L
What we ever hope to do with ease, we must learn first to do with diligence. - Samuel Johnson
     On the Building Ways:                           Launched:                                                 Contracts Signed:                    Member:
       The Nautical Research Guild
        The US Naval Institute
Thanks everyone for your kind thoughts.
Robin, now I understand what you are referring to.  I deliberately left out some of the filling pieces to allow daylight to enter the lower aspect of the hull so possibly some detail could be seen.
Toni
Member IPMS
                           Utrecht-1742
I am SO VERY sorry for you, and pray she has a gentle time. I didn't know her and I already know I will miss her.
Rocky the dog, as pictured in my avatar was 148 lbs and 14 years old. We had to let him go a year ago last April, and I still tear up.
We planted a dogwood over him and I find myself some days talking to a bush.
If I didn't live far out in the country my neighbors would think I was a Druid
D3X3279-Americana
From U.S. Navy
So sorry about Sadie.
Maury
Toni -- This is a bit tardy, as I've been out of town, and just this morning picked up my own dear Bounce from the boarder -- but I do have to say that it is sad to hear about Sadie.  There aren't many things we do that are harder than deciding when to say goodbye to a friend.
Martin
There has been very little time lately for modeling but I was able to build the forecastle bulkhead.  In keeping with the rest of the model, I only made the port side and mid-portion of the bulkhead.  I made this up with a center core of basswood sheet.  Costello was then applied to both sides of the basswood to represent the bullkhead and doors.  The edges of the center panels are sanded down to simulate a floating panel.  At this magnification, I must admit that some of the edges look a little rough but when you look at it installed, it really looks ship-shape.  The hinges are brass photoetch from Admiralty Models.  The window is glazed with acetate.  I will not install this until the forecastle beams are permanently glued into place.  Once installed, I will add the edge piece that intersects with the hull and the deck cant into which the bulkhead inserts.
Toni
Member IPMS
                           Utrecht-1742
Nice looking bulkhead, Toni, although I was puzzled that you applied a comedian to both sides of the basswood. Perhaps you meant to type 'Castello'?
Thanks for keeping me in line, Druxey!  Now how do I slip in an Abbot?
Toni
Member IPMS
                           Utrecht-1742
