Hello everybody,
I started chapter 4 now, and made 2 of those fantastic gun's at the beginning. I think the red carriage suits better, but the natural carriage is beautiful as well.
Next I planked the lower deck platforms and glued the deck beams an deck sheats in position. All turned out well, no problems so far.
This broadside will look wonderful, once completed!!
Matthias
Edited by Beckmann
12 hours ago, Beckmann said:
Hello everybody,
Matthias
Stunning Mathias.
4 hours ago, Vladimir_Wairoa said:
Stunning Mathias.
I can't say it any better than that!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
I made the inboard planking of the bulwarks, and of course forgot to insert the little shells in the second layer, I inserted them in the first layer. So I have do drill the holes in the right place and somehow create the notch between them.
After painting everything, I will continue with the paneled captains cabin.
Matthias
The next thing for me to do is the panels and flooring of the captains cabin. I wanted to use my ivory for the panels and started with the starbord panel.
I made a base from a thin veneer and cut out door and gunport in the right position. Then I glued small strips of veneer onto it, for the placement of frames and panels. The ivory parts were cut and profiled on the saw and afterward sanded an glued on the base. Here you see the result.
My material will be enough for the captains cabin, but not for the rooms infront of the cabin. I plan to make that with wooden panels like this one here:
One thing I still have to add, before gluing the starbord panel in position is the door to the Quartergalerie. I am thinking of a sliding door like this one:
After that, I will make the checkerbord flooring, using the material of the panels and some ebony. I started the preparation on this one:
Here you see the strips glued together and sandet roughly, next they will be cut apart and glued on a veneer-basebord as well and then sanded and polished.
Matthias
Edited by Beckmann
Matthias
wow your panels look fabulous Mathias. I will try to mimic same idea though.V.
Hello everybody, I made the checker floor for the captains cabin.
I wanted it like on the pictures on the captains cabins:
13portsmouth-hms-victory-great-room-or-nelsons-day-cabin-aft-end-upper-gun-deck.jpg.dfb387fe6618466c4ea92fdb0802ad79.jpg
First thing was to provide the stripes and cut them without breaking them.
Next step was to stick them upside down on a tape.
after that was done, a veneer template, wich had the size of the later flooring was glued to it upside down.XII-3.thumb.jpg.f671bea82e2cf91c58c84b5deee4bb96.jpg
Afterwards the edges were cut and sanded in shape and the surface was polished.
Her you see the flooring on the model:
Matthias
That looks really good Matthias!
Rusty
Hello Everybody,
I finished the captains cabin rear gallery with the installation of the rudder trunk and the benches. For the small panels between the windows, I made small ebony decoration strips as framing.
First picture is the rudder trunk befor installation:
Here you can see the Captain Sir C. Passaro is giving order for the next work to do :)
The paneled front of the bench were glued against a curved template, to follow the curved edge of the flooring.
And the finished arrangements:
A little talk after everything is done.
Matthias
Edited by Beckmann
On 3/8/2021 at 9:56 AM, Beckmann said:
Hello Everybody,
Matthias
congratulations. beautiful.
Captain Sir C. Passaro's figure is more anatomically correct than that skinny stick figure you substituted. No wonder he gave it a thumbs up. Love the way your treatment of the cabin makes your model unique.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Beautiful work!
Rusty
Thank you all for the likes and comments,
I proceeded with the rudder, wich was so incredibly well designed by Chuck.
 Just following the step by step instructions
She loves doing the fiddly things and her eyes are better than mine anyway...
Not much left to do, and I can turn the hull back over and mount the rudder in its place.
Matthias
Great job!
Rusty
