They look very realistic!
Jim
Current Build: HMS Winchelsea, Model Shipways Mayflower
Completed Builds: NRG Half Hull Project
                                   Model Shipways 18th Century Armed Longboat
                                   Dumas 1954 Chris Craft 36' Commander
                                   Dumas 1940 Chris Craft 19' Barrel Back
  • 2 months later...
I'm still making eyelets and rings, dozens and dozens of the things! I've upgraded my tools for this with new round needle nosed pliers and a decent pair of flush cut snipsIMG20230729214027.thumb.jpg.f0a904338a9753cfd9d72498f81735af.jpg
Oh and I also got a couple of Vallorbe needle files.
Thanks to everyone who's looked in, commented and hit the thumbs up.
Unfortunately I'm going to have to wait until Christmas time before I can start arming Winnie, this year's list is cannon and more cannon, and maybe chapter 7 parts.
Cheers
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Ah, so that's what has been keeping you quiet Edward! Glad to hear you have been beavering away, looking forward to seeing your Winnie getting her teeth! :pirate41:
Andrew
Completed (Kits):-
Well, that, work and holidays, now I've got the massive task of catching up on everybody's build logs .
Current builds;
Completed:
  • 1 year later...
Hello again, after a long hiatus I'm back. Getting on for 18 months, I don't know where the time went!
The order for Winnie's guns has been placed, so it's just a matter of waiting for them to arrive.
Cheers
Current builds;
Completed:
Good to see you back! :champagne-2:
Andrew
Completed (Kits):-
Good news! The guns arrived!
Excellent service from Chuck and the associated postal services on both sides of the Atlantic. Thank you!!
Work on them will commence after the festivities are over. Thanks for your interest.
Cheers
Current builds;
Completed:
Happy New Year to everyone!
So, work has started on the guns, it is going to take me a while to adjust to working at the small scale, after such a long time away from the modelling.
These are just a few photos of progress,IMG20250114125449.thumb.jpg.966d9bb008c6bcdbbfab49a09e999860.jpg
There is still so much to doIMG20250114125538.thumb.jpg.a4273fc06d18739cdf7670b0c2e801dc.jpg
This is the first of 24, IMG20250114125425.thumb.jpg.715c100da391ca4a7e7392f0743fb309.jpg
I have to say, Chuck's carriages are excellent and the barrels too. The jig is a great little tool and so helpful in constructing them.
Thanks for all your interest and watching my fumbling about.
Cheers
Current builds;
Completed:
I now have 8 carriages made up, although I have to give them another coat of paint and paint the beds and quoins.
Obviously I have to also make and fit the iron work on them tooIMG20250116122822.thumb.jpg.594a4f4659e410bfcbb72a9c5e2c8629.jpg
Thanks Fred, I shall more than likely order those when I order chapter 7 and the remaining barrels I require.
It's good to be be back Chuck 😁
Thanks for watching .
Cheers till next time
Current builds;
Completed:
Just a thought. It’s easier to drill and add the various ring and eye bolts before assembly or at least drill the holes for them.
Regards,
Glenn
Current Build: HM Flirt
Yes, tbh, I never even gave making the holes a thought🙄
Thank you Glenn
Current builds;
Completed:
So following the advice given by @glbarlow, the rest of my carriages will be pre-drilled before assembly.
The ones already assembled are being carefully drilled for the ironworks.
I have fitted the 7 ringbolts and 2 split rings to one cannon.IMG20250120070614.thumb.jpg.4763b5545ecc071678c003b105120872.jpg
I am quite pleased with the result.
As for rigging the guns, I'm undecided, as of yet.
As can be seen in this photo the quoin has it's handle, which were provided in the carriage kits, although a couple of the packs have some thin square section, I presume to be used to make my own quoin handles.
Anyway thanks for watching and till next time,
Cheers
Current builds;
Completed:
Good evening, as a small break from the repetitive gun carriages I decided to make the lower part of the capstan IMG20250123124710.thumb.jpg.30baa0dedc5fcc77bde0faa22cd61055.jpg
Following the very precise instructions, I feel I have produced a passable capstan, with only one mistake!
The top of the barrel has five holes, which I completely ignored and didn't line them up with the holes for the bars.
Some gentle persuasion with a razor blade and the mistake was rectified.
Thank you for all your likes, and till the next time,
Cheers
Current builds;
Completed:
Hi, work continues gradually on the guns, and also the capstan and stove.
I have thoroughly enjoyed building the stove and capstan, such great little kits, that can be stand alone modelsIMG20250201102627.thumb.jpg.8a40569d31cfa7c1508f1c9f0fae5f32.jpgthe stove is finished and also the capstan IMG20250201102707.thumb.jpg.d8b1819fb33fc97012165f9832b82542.jpg
As my guns are being painted I painted the capstan tooIMG20250201102619.thumb.jpg.cd0b07adec6502002777725ced6e29aa.jpgIMG20250201102728.thumb.jpg.0d354fcefd44761324dbe716ae6e8dcd.jpg
Thanks for your patience and following my dabbling.
Till next time
Cheers
Current builds;
Completed:
Hello, so Winnie got dusted off and brought out of ordinary.
With 8 cannon completed bar the cap square, I wanted to see them in place!
The stove and capstan were placed too.IMG20250201184216.thumb.jpg.fa6f6669c4b73e6873bca04826d4cce7.jpg
I'm still undecided whether to rig the guns.
Only 16 more to do!IMG20250201184306.thumb.jpg.d250ce6c1d1750c1cc5e5913a213e09d.jpg
Thanks, till next time
Cheers
Current builds;
Completed:
Thank you Chuck 🙂
I am still working my way through the construction of the cannon, I'm on my last batch of eight.
There are so many ring bolts to make, but I'm slowly getting there.
Thanks for you continued support and encouragement.
Cheers
Current builds;
Completed:
So, all the 12pdr carriages are done, 8 have no barrels, but they are on order, along with chapter 7 and the cap squares.
While I wait for chapter 7 to arrive, I will spend time making lots of ring bolts and split rings for the bulwarks, 125 is mentioned in the monograph.
All with barrels are placed in position. Im quite satisfied, even if I do say so myself.IMG20250307113711.thumb.jpg.4de3d9c422a17ae9164ca76c0dee8af7.jpgIMG20250307113732.thumb.jpg.db037e75e65ea216d0f94b69360f83ca.jpg
The barrel less ones in the cabin area,IMG20250307133046.thumb.jpg.34c99736a1342a29af792039e228a6ee.jpgIMG20250307133034.thumb.jpg.8f210a5ab98ecc08bc3c68e23f0b5a19.jpg
And one last photoIMG20250307133056.thumb.jpg.ddfdc41709f9ac7a7f8338c232975b5e.jpg
Thanks for looking, and hitting the like button.
Still no decision on whether to rig or not to rig the guns. Feedback will be gladly welcomed on this matter.
Cheers
Current builds;
Completed:
That is looking very nice...I remember being glad when those were all built...
Onward and upward!!!  Just shipped your new parts.
Many Thanks Chuck!
Current builds;
Completed:
Yes they are…but he still has to trim the trunnion pins flush with the carriage sides before adding the capsquares.
chuck
Hi again, Chuck's deliveries are fast, the parts for chapter 7 arrived in about a week or so again.
So now, it's more sanding and trying them for fitIMG20250316144210.thumb.jpg.ad278f9e0fefd4c7d2aa8044707b5c0f.jpg
And all the barrel trunnions to trim for the fitting of the cap squares
Thanks for looking in.
Cheers
Current builds;
Completed:
