M16 US Multiple Gun Motor Carriage w/ Church Ruin by Jack12477 - 1:35 scale - Tamiya / Verlinden - FINISHED
8 hours ago, Jack12477 said:
The "rear wheels" are a tank tread.
I knew that, but my eyes still want to see real wheels and tires at the rear differential. It is kind of like looking at a Stryker. For some reason it seems like it should have tracks.
capture-13.jpg?w=624
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Yea, I've seen the Stryker, Lou, always wondered about those tires tho. A good marksman with a amour piercing round or a .50 cal round could easily take out all 4 tires on one side and disable the thing.  Kinda hard to disable a tank tread with anything short of a bazooka or RPG or another artillery round.
Small Update:
I finished building the front and rear assemblies and getting them attached to each other.
IMG_7984.JPG.51c313c489998a8d0d57059679b1e734.JPGIMG_7985.JPG.54b7fd13501fd4a26776e79b356e7ab3.JPG
I am using Tamiya brand Olive Drab paint for the entire body.  In comparing it to another model of this same vehicle I made back in the 1980s using Floquil brand Olive Drab paint I notice that the Tamiya is noticeably darker in color than Floquil was some 40 years ago. And at that time Floquil's paints match the US' Federal Standard (FS-55) color charts.    See the comparison below. Model in background is the 1980s Floquil painted version.  Notice how much darker the newer model in foreground is with Tamiya brand paint.
Jack
Current buildUS Constellation
Hmm the older OD looks a bit more of a dusty green rather than the darker green of the newer OD!
Build looking good tho'😁
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
I think both colors are "accurate." OD seems to vary so much from one week or another. Our helicopters were all OD color but no two looked quite the same shade. Sometimes even different parts of the same helicopter didn't match in hue.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
The Stryker tires are designed (according to Google search) such that they can run flat.  They're not bullet proof but the pressure can be controlled from inside the cab (built in compressor apparently).
Looking good, Jack.  And Lou is right.  Don't sweat the "shade"....
Many moons ago, I was a swamper for dozers working in the mountains doing gas and oil pipelines. Because of mud and clay sticking to the tracks, would have to clean and adjust the tracks daily, sometimes  multiple times a day. Otherwise, the tracks would jump right off the drive sprockets. I'm certain military tracked vehicles would need the same kind of regular maintenance, which is why I believe they went to wheels/tires on some of these newer combat vehicles. Of course extremely heavy vehicles such as M-1's need the tracks to spread out the extreme weight of the vehicle over a larger surface area.
I think at least some of the newer wheeled vehicles were done for the relative simplicity of using wheels. As Craig explains tracks can be a PIA to keep tensioned and maintained.Wheels also offer higher speeds without causing other issues common to tracks. As for their bullet proof characteristics, it probably makes little difference if the tire can take a .50 hit when the armor of a Stryker can just barely take that caliber of hit. Even though they look like tanks, they are really personnel carriers and history shows us what happens when you put a Battle Cruiser in a line of battle against a Battle ship.
Apparently others felt much the same way and intend to use this instead of the Stryker mounted with a heavy gun.
https://www.popularmechanics.com/military/weapons/a23206/griffin-light-tank-general-dynamics/
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Well, the Stryker is supposed to be "air portable'... Adding tracks may also have pushed it over the max weight.
That link Lou, is interesting.
Finished the M16 half track this morning.  The decals were a bit of a problem due to their age. Took a long time soaking in water before they were release from the paper and then some were brittle and broke off pieces as soon as I applied them to the model. Guess I will just chalk up the missing stuff as "battle damage".  Next up is some touch up of the paint and then some weathering of the model before I address the diorama scene itself. Still trying to visualize how I want it to appear.
Some pre-decal photos
IMG_7988.JPG.b6e4a401f19702053fa9b7357d0ef48f.JPGIMG_7989.JPG.8a1b43f33473148177d9a870e3f9cd80.JPGIMG_7990.JPG.83d8a4cc9a063fa65de34570578a10a4.JPGIMG_7991.JPG.70c97b45e545e182e0e77afc894adbe5.JPGIMG_7992.JPG.fa418780f8f6a0373d1a213ca72ae236.JPG
Post decal application
IMG_7994.JPG.e3624c54fdd59b0448b40b6446e02111.JPGIMG_7995.JPG.4bbab1887a5456b294ef362142c0cd7e.JPG
Little OOOOOPS on the speed limit decal - slipped after I applied it and turned to the other side of model. Oh well.  Soldier must have been a little drunk when it taped the stencil on the back
IMG_7996.JPG.82782975655b51e572e34d5c35c70480.JPGIMG_7997.JPG.6f838287b419c911fe75275fba70b071.JPGIMG_7998.JPG.42d18beba51f0c0dbb39b98b9da5ae17.JPGIMG_7999.JPG.12f7183eca91812450de66e5ea77c5e7.JPGIMG_8000.JPG.1b42992a518f5109043d46826bc2440f.JPG
Jack
Very nice work Jack, I think the speed limit decal looks just fine at an angle.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
yes, I guess they had too much of that French wine to drink last night ;)
Jack
On 3/13/2020 at 7:47 PM, Old Collingwood said:
One of these  -  I built the kit years ago  - very nice kit.
Pic of the net.
OC.
I have that tank in my stash of completed models - only not in the camo colors shown on the box - just straight OD.
Jack
Nice work Jack. I wish I could make as much progress in a build as you guys do. I like the "Left hand drive" warning. They much have been spending some time in England where they insist on driving on the wrong side of the road!:D
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
super job Jack...i've got at least four different tints of Olive Drab ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Could be worst  - Australia where they drive upside down.
OC.
Current builds
Completed works.
But they drive on the wrong side too! Seems they learned it from their English ancestors. So it seems they are not only upside down but backward too!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Good job Greg aint about.
OC.
Current builds
Completed works.
How do you know? If one drives upside down and on the wrong side of the road they could end up anywhere!:D He might be sneaking up on your backdoor even now
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Are but  - our back door would be gregs  front  first floor  door  - he would  need to stand on his head  on upside down  stilts  - while jumping down/up down/up  and I wouldn't be able to understand him  as his speech would be upside down - back to front   - very odd.
OC.
Current builds
Completed works.
On 3/15/2020 at 5:45 PM, Jack12477 said:
The "rear wheels" are a tank tread. ;)  Hence the name "half-track".   You will see shortly
Actually, modified conveyor belts..... They had "America" & "Detroit"  flashing all over them.....
Great build so far.....
Quote:
32 minutes ago, Roger Pellett said:
How does the driver do this?
No clue ! ;) But,  I did notice a couple extra levers installed on the floorboards. I didn't see any explanation but will recheck the inventory list for any clues,
Roger, do a Google search on wwii m16 half track operation manual   look for an entry from biblio there is a pdf of the original operation manual. I can't post manual here or get a link, the entry just pops the entire manual up for you to view. Couldn't find much on manipulating the tracks other braking.
Edited by Jack12477
Jack
47 minutes ago, Roger Pellett said:
Nice model!  Looking it the driver has a conventional steering wheel that I assume is connected to the front wheels.  With the weight on the treads it would seem to be also necessary to vary their speed relative to each other to maneuver the vehicle.  How does the driver do this?
Roger
He doesn't, the bogies are driven by a rear axle with differential just like any other wheeled vehicle...  when you go into the turn, the differential handles the difference in inner to outer speed.... The rear return roller just freewheels....
Edited by Egilman
Quote:
Thanks! Could not find that in the manual
Jack
You wouldn't find it in the operations manual, you will find it in the maintenance manual for the IHC M-3 Halftrack
Look up these tech manuals.....
TM-9-707 1943 IHC Halftracks
TM-9-710 1944 Basic Half-Track Vehicles -White, Autocar and Diamond T
TM-9-1710 1942 Powertrain (Axles, Transmission and Propeller Shaft) for Half-Track Vehicles
TM-9-1710C 1942 Chassis and Body for Half-Track Vehicles
They are all available for download online in PDF format everything you could ever want to know about WWII half tracks and they specifically cover the M-14 multiple gun motor carriage. the only difference between it and the M-16 was the M-14 had two .50 cals and the M-16 had four.
Edited by Egilman
Added source information
Quote:
Thanks ! The manual I did find is the TM-9-710
Jack
Thanks.  But you might want to delete the pdf file you seem to have accidentally uploaded.
Jack
I deleted it for him, Jack.
