HM Cutter by Edwardkenway - 1:48 scale from Caldercraft plans
You’re doing nice work on your cutter, I’m sure the skills learned will transfer to Winnie. Just remember it’s single planked so the work will require patience as I’ve learned on Cheerful.
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Share on other sites
On 8/20/2020 at 7:50 PM, mtaylor said:
a clean work bench is the sign of a sick mind and work not getting done.
I must be sick then.  I have to stop every once in a while to clean up and reorganize otherwise I’m just looking all over for the tool buried in the rumble.
Regards,
Glenn
Link to comment
On 8/16/2020 at 12:49 AM, Edwardkenway said:
Hi again, thanks to everyone who has looked in and also for the likes.
Planking on the port side slowly proceeds, as I put planks on from the keel and the main wale, I kept adjusting the marking out for the plank lines and it seemed to help.20200815_214626.thumb.jpg.3c071c4fd5cb1e34f993a0102c8a4be1.jpg
Another day and it's done, I'm much happier with this side than the starboard,
stern planking is also done, but I think that I will put a moulding across the bottom of the counter. 20200815_214721.thumb.jpg.e181d0089643ac58f475f150b4600d66.jpg
just need to give both side a good sanding, paint the main wale and a coat of matt varnish or oil.
I am happy I've got the planking done, I'm hoping  that when I do finally start to planking Winnie that the AYC will edge bend better than the walnut I used here. The cedar I used on Triton definitely in my opinion took bending alot easier!!
Til next time
Cheers 😃😉👍
i clap hands as well very very nice. hat off. .Vlad. british cutters are so special.
Link to comment
Thank you kindly Vlad👍😁
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
  • 2 months later...
Hello playmates, whoops, sorry fellow modellers, I'm back on my Cutter and taking a break from planking Winnie. She sure is big!
Anyway, I've been trying to sort out the aft companion way, but I've made two that when placed did not look right 🤔 so I started a third and this time it also includes a skylight  for the Masters cabin. Sorry but I'm having the same problems as popeye (Denis) and my camera on my phone has stopped working,  waiting for new phone, so photos coming soon. I will be working my way through the deck fittings for a while. So I'll see you all next time👍
Cheers :D
Thanks for stopping by and the likes.
Edited by Edwardkenway
Current builds;
Completed:
Link to comment
A little bit more done, made hatch coamings and main hatch grating, the companion way
and skylight are well on the way.
I've also began to put the moulding along the bulwarks
the photo below is a test as my new phone camera has a macro setting.
Next time I'm going to have a crack at making either a windlass or a capstan, I'm leaning more towards a windlass.
Thanks for the likes.
Cheers 😄👍
Current builds;
Completed:
Link to comment
A cutter most likely would have a windless and not a capstan, so good choice.
Your deck is looking good, nice work.  I like your moulding, and your macro photo.  Probably interesting to drop down to this size from the huge Winnie.
Regards,
Glenn
Link to comment
Thanks Glenn,  I have been scouring the internet for  pictures of windlass so I have some sort of idea of what to do. I'm also thinking of maybe mocking up a different companion hatch.
It is nice to be able to have a break from planking Winnie, it seems never ending as she's so big.
Current builds;
Completed:
Link to comment
You might take a look at Chuck's 1:48 windlass kit for Cheerful ( instructions )
Even if you don't use the kit, it may be useful as a design idea..
( The store is closed right now, but here are the details in the prototype build log..)
Luck is just another word for good preparation.
—MICHAEL ROSE
Current builds:    Rattlesnake (Scratch From MS Plans
On Hold:  HMS Resolution ( AKA Ferrett )
Link to comment
Thanks Gregory,  I shall be sure to have a look at that windlass
Current builds;
Completed:
Link to comment
Returning to my Cutter for a bit of relief from the smell of the glue whilst working on my Panther non ship build.
 There's been change of mind concerning the companion way, instead of a deckhouse I'm just doing a simple coaming and a ladder down to below. 20201117_174427.thumb.jpg.74e59e928776ad8625ab5f0e8fe98c24.jpgConsequently I've cut out the false deck to allow for a platform to set the ladder on. I've still got to tidy the hole up.20201117_172918.thumb.jpg.1f1eddae520528ca5c942ec5aefa2a2b.jpg
For some reason macro mode makes the Cedar very yellow. 20201117_175136.thumb.jpg.16755fb5d109b26f9157a45beccc3cae.jpg
also have cut the small components for one side of the skylight, which is staying. Needless to say this has put back the making of the windlass.
Thanks to everyone for your posts and info for said windlass.
For the likes and dropping in....
Cheers 🙂
Current builds;
Completed:
Link to comment
Just a little bit done, the window frames on the skylight have been glued, they'll need sanding when the glue's cured20201117_184316.thumb.jpg.28b639fac087f297ab34fc873e18658b.jpg
I've given the deck one coat of poly
I'll get the platform and ladder sorted next time 20201117_184303.thumb.jpg.459c996058abf46061ad903dd642d504.jpg
thanks for the likes and having a look😁
Cheers
Current builds;
Completed:
Link to comment
Very nice job on the skylight! I’m quite interested to see how you retrofit that deck. I regret not planking those areas; but I will on the next build.
Link to comment
Thanks Tim,
With great difficulty, I've had four attempts before I got one I was satisfied with. 20201120_205016.thumb.jpg.abf1f4b9690a00df4a85489cce2c94ed.jpg
This was #1, a bit too small as you could see into the open hull past the edges. 20201120_205036.thumb.jpg.f9684e0cb65e03040370cfa15290ff07.jpg
#2 not as poor but I wasn't happy and #3 never even made it down the hole.20201120_222820.thumb.jpg.c3d2e836345298a5e66b0f06b65accc0.jpg
#4 made in two pieces and glued to some cross beams wedged and glued between the hull and the false keel. It's about 3 times as wide as the hatch and really tested my dexterity to fiddle it in to position. 20201120_222817.thumb.jpg.1dfc9834f11709ac59ea429aa910316c.jpg
I'm  re-doing the ladder.
The lower deck is now in and 32mm below the upper which if scaled up to full size would be somewhere between 4'11 and 5'1
Next time I'll do this before the top deck but I wasn't planning this companion way.
Thanks for popping in and the likes😁
Cheers
Current builds;
Completed:
Link to comment
Hiya mate,    dont know what happened - I must have kept missing your updates on this,   thats an exellent  bit of work on your false deck, and not an easy route in there  - fine job indeed.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Creative work, nice adding these details.
Regards,
Glenn
Link to comment
Thankyou for your kind remarks Tim, OC, Tom and Glenn 🙂
I remade the ladder,20201121_213850.thumb.jpg.8c27350ff13c27677793e47375b3c8ee.jpg
but I'm not sure wether it's any better than the first one, although it20201121_213944.thumb.jpg.387d2431ed6e91b0a04bad85883064b7.jpg
doesn't look as bad in the photos as it looks in life.20201121_213933.thumb.jpg.cd79f066b1b3b1a563f480d0d980690d.jpg
still I'm going to knock another one up, just so I've got the choice 😏
will be starting on the rest of the deck fittings, with the windlass, main and bowsprit bits first. Hopefully the weather will be fine enough for me to get my table saw outside to cut some timber for said parts.20201121_220351.thumb.jpg.e51a96553079ec0ba14ffd8c6226580a.jpg
you can just see a bit of a twist in the ladder in the above photo.
Anyway thanks to all who looked in and the likes.
Cheers 😁
Current builds;
Completed:
Link to comment
Hello again, a fine sunny morning here and the table saw was out on the backyard. I cut a 40 x 65mm piece of pine into a selection of different size sticks.
These will be used  for the deck furniture that will be painted 20201122_213021.thumb.jpg.7728622b10587de1293248dd76c1ddb3.jpg
first was the windlass supports, and that's as much as I got done because  the Admiral and my eldest daughter decided we needed some fresh air, so ended up going for a 5 mile walk. I'm going to re-read know to make an octagonal stick from a square one and get the windlass barrel done.20201122_213037.thumb.jpg.94e3db081ef3ca2c823a16d82185a3fb.jpg
thanks for the likes👍
Cheers:D
Current builds;
Completed:
Link to comment
Thanks for the compliment RK, as is your Victory build at a much smaller scale😱with much more rigging.
Current builds;
Completed:
Link to comment
Hi again,  so I did my homework and found the post on how to turn a square stick into an octagonal one, and after several abysmal and downright awful attempts, (scrap bin was well fed with this little project) I've got one that is acceptable. 20201127_220407.thumb.jpg.4ee54c7e429e29337efff85f619fb135.jpg
I'm still making the cap end pieces and have still got to make the ratchet part .20201127_220354.thumb.jpg.8a1481671ec99142a22682839ef9938a.jpg
also need to add the details like the holes for the levers.
Thanks for the likes and visiting👍
Cheers 😉
Current builds;
Completed:
Link to comment
Nice looking ladder, I don’t see any flaws.  Your scratch made parts are impressive work!
Regards,
Glenn
Link to comment
Kind of you to say so, Glenn.
The deck furnishings continue, albeit slowly, tonight I've roughed together the main mast bits.20201129_213319.thumb.jpg.5fe7c67b52e623a50692bff811dc5e14.jpg
sanding is still required.
I'm using some scrap AYC and still cannot get over how nice it is to work with. 20201129_213401.thumb.jpg.b577f6ed28e078f7571fa7dc945d1088.jpg
Thanks for looking in ang hitting the button.
Cheers 😄
Current builds;
Completed:
Link to comment
8 hours ago, VTHokiEE said:
That looks really nice! Did you use any tricks/jigs for the top bevel (or any of it for that matter)?
Thanks Tim, no jigs at all just freehand with sandpaper and files.😁
7 hours ago, rkwz said:
Wonderful craftsmanship!
Thank you very much.😁
Current builds;
Completed:
Link to comment
At home today because of the rain, so thought I would make the bowsprit. Using my cordless drill and sandpaper  I have got a basic shape20201203_151801.thumb.jpg.f9a23cfa0a35eade091c56f7dbe427a0.jpg
also painted the windlass supports and the skylight body20201203_152002.thumb.jpg.a1babd6106e52f907f832cb07a09826a.jpg
still got to make the ratchet and the bowsprit bits, which I'm thinking of putting the pal for the windlass on.
Thanks to the encouraging comments and the likes.
Cheers 😉
Current builds;
Completed:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
