Mark - your work is outstanding and inspirational, such clean woodworking.  One question if I may, how do you shape the underside of your beams?  The concave profiles must me challenging than the convex upper side.
Cheers,
Jason
In the shipyard:
Hi ya Jason - I use a spindle sander to make the concave profiles with the biggest cylinder for such a gentle curve.
Its my most least liked machine if I'm honest  - it vibrates - its loud - its just not a great machine to use.
I've been asking Jim Bynes for ages to make a decent spindle sander for ship builders for ages (I never miss an opportunity to say it again) and I hope that he does one day 🤣
Its not challenging to do just not one of those jobs you look forward too - Oh but I should have said its a very easy profile to achieve 👍
On 4/25/2023 at 7:13 PM, giampieroricci said:
Great and neat work!
Thanks mate 👍
Work on the deck continues - Having found the centre line of the beams I placed the templates on each beam to cut out all of the required notches.
There's quite a lot of them to cut and I had to look through quite a lot of the plans to find the required sizes.  I was cutting for the carlings, binding strakes, bowsprit partners, mast partner and pump partners too.  Also some to the cuts follow the curve of the beam and some need to be cut vertically.  There was one dimension that I just couldn't find and a quick email to Gerard Delacroix gave me the place to look - Thanks Gerard :)
So lots of cutting which I mainly did on the mill using a 1mm twin flute end mill and then squared out all of the corners with a chisel
Once that job was done it was a pretty simple job to make the carlings for the hatches - I was just trying to get the tightest fit that I could.
I now need to make and fit the 8 half beams that fit along side the hatches and mast partner.  So I guess I'm going to have to make the mast partner too.  I think this will take quite a while so I'll update you once I get somewhere with it.  Thanks for all of the encouragement :)
Cheers Mark
38 minutes ago, Toolmaker said:
Seriously nice work on show there Mark. A heady mix of carpentry and wood engineering which you have combined perfectly.
Cheers
Paul
Hi Paul - cheers mate thats nice of you to say 👍  I tried to start the mast partner tonight and discovered that the beams that it sits between are 5mm to close together.  After having a good look at my mistake it was obvious that the front beam was 4mm to far aft and the rear beam was 1mm to far forward.  So I've been fixing this issue which is no big deal it just means a few repair pieces in the deck clamp.  Ship building is amazing - just when you think you've got it right.........well something needs correcting 🤣
Hello Mark,
May I ask how you made the recess or angle on the sternson and extensions?
The angle is changing over the complete length of this part and - if the plans are correct - also from the bottom up to the sternson knee extension.
Your part looks just perfect and I'm wondering how this can be made.
Thank you 🙂
Hi Nersch - you are correct the angle gets wider in both directions and this is a tricky job to get right.  I worked out the angles and then milled the parts.  The angle was achieved on the mill by packing the stern end up from the bed of the mill.  It's a very slight angle which had to be replicated to obtain a mirror image on both sides.  As I remember I then finished the job by hand - I hope this helps.
1 hour ago, Nersch said:
Hi Mark,
That was also my thought. I spent today some hours to measure and calculate the different angles. So let's see how it works at the end.
BTW: What milling machine and milling tools are you using? Your surface looks perfect with sharp edges and no break outs.
I use a Sherline mill with a 10k rpm pulley upgrade and more importantly 2 flute end mills as these really get the chips away well.  The surface finish is more down to the wood I'm using than anything else.  Its Castello and is very good at keeping an edge.
Another update from me as I finished the mast partner in far less time than I thought it would take.
The first thing I did was to make sure that the carlings were a very good fit in between the beams.  As mentioned earlier I had placed beam 7 in the incorrect place and once this was sorted the parts fitted as they should.  In this picture they are sitting proud as I had not yet cut the rebates to make them flush.
The cut rebates and how they sat on the beams after.  I have deliberately left them slightly proud so that I have something to sand down to deck level.
Next I cut out the notches for the other two parts of the mast partner and the dovetail for the half beam
Nothing like a nice piece of symmetry 👍
I then made the other two parts which basically followed the same process.  The actual hole is bevelled towards the stern but this is not difficult to achieve.
The parts assembled
The parts on the ship between the beams.
To complete them they still need some small corners made but I'll make and fit them once the mast partner is fixed in place.  I've still got loads to do before I get the half beams in.
Cheers Mark
Hi All
Work continues on the deck and I've been making the short and thinner half beams.  The plans give you a very good idea of the shape but don't give the individual shapes for the undersides although the lengths are shown separately.  This simply means that you have to use your brains a bit and translate the drawings as you see fit.  Thinking back I would have struggled with this concept at the beginning of this build but now I can see what is required.
So here are the eight half beams.
Now just for a change and to try something new I thought that I would make the female part of the dovetail joint first and then fit the end of the beams to suit.  This was not a great idea and I won't be doing that again - it's so much harder that way around and I couldn't get the joints as tight as I wanted.  Anyway they turned out ok and here they are fitted on the ship.
I still need to drop a few of them further into the deck clamp but thats an easy job.  On the whole I think the run of the deck looks pretty good as this is only a dry fit and I don't think it will take much sanding at all.
I can see some slight variations on the dovetails for the waterway and spirketting so I guess that will need some adjustment when the time comes to make them.  I'm not going to make the pump partners until the deck is fixed in place either.  So now I have to remove all of this work and make a start on the deck shelf which is fitted to the entire length of the deck clamp.  This shelf is there as no knees are fitted to the beams on this ship and it looks quite difficult to make.  Hopefully I'll have something to share soon
Cheers Mark
Look's terrific Mark. When you are fairing the deck if you add a little white glue into the joints those small gaps will disappear. I don't do a lot of full sized carpentry but I believe it's standard practice to cut the dovetail first then the recess for it. Much easier to trim the joint to receive the dovetail.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Thanks Greg 👍  Yea it is the normal way to do a joint by cutting the dovetail first and thats the way I have always done them.  I just fancied trying something different to see how I would fair.  They are not too bad but not as tight as they should be - I do these things to get better at using edged tools.
I will put some glue into the joint but I also think I'll run a HB pencil around the receiving part so that I don't completely loose the joint.
I've been looking at the deck shelf and the more I look at it the harder it looks.  I think its going to be one of those parts that gets made more than once - just as well I've got a good stock of wood!!
On 5/14/2023 at 8:55 AM, marsalv said:
Wonderfull built:o.
Cheers mate its starting to come along now!
I've made a start on the deck shelves - Its the usual procedure of running some wood through the thicknesser which in this case is 6.9mm and then photocopying the plans for the templates.
Then cut them out, sand to size and join using scarf joints
The next stage just takes time as the shelves do not sit at 90 degrees to the deck clamps.  The best description I can give is that the point slightly upwards as if to follow the curvature of the beams.  So a bevel needs to be cut the entire length of them and then they also need to be let into the deck clamps for a good tight fit.  This isn't actually hard to achieve it just takes time and a little patience.  Once done I clamped them in place to mark out the recesses for each beam.  I thought that the best way to achieve this accurately would be to use the beams themselves so thats what I did.
This seems to have worked well so now that I have the locations I can cut them out.  I also need to bevel the front of the shelves and round the underside which will be my next jobs.
I've also been treating myself 😊 I bought my sanders little brother for some of the finer work.  Wow what a lovely tool this is - Its not as powerful as its big brother but it has excellent control for both speed and direction.  Just what I needed and another fantastic tool from Model Machines.
Loads to do and thanks to you all for your comments and likes on this build
Hi Mark, really very precise work, very clean.
Greetings Tobias
Member of the:  http://www.arbeitskreis-historischer-schiffbau.de/
On the workbench:
Corvette La Palme (L'Amarante) from 1744 POF based on plans by G.Delacroix
https://modelshipworld.com/topic/32046-la-palme-by-tobias-136-pof/
LE ROCHEFORT - Harbor yacht from 1787 1:36 by Tobias (monograph by G.Delacroix)
https://modelshipworld.com/topic/34810-le-rochefort-1787-by-tobias-136-harbor-yacht-from-ancre-monograph/
Le Coureur - Kit from CAF with the plans from Ancre
https://modelshipworld.com/topic/29843-le-coureur-1776-by-tobias-caf-148/
Looks like a really precise piece of kit that Mark. I have the Proxxon table sander it does the job but the table isn t great and the angles are not very precise. Keep up the excellent work Mark.
Completed     St Canute Billings            Dec 2020
Completed    HMS Bounty Amati          May 2021 Finished
Currently building HM Bark Endeavour
Thanks Tobias 👍
On 5/23/2023 at 9:28 AM, giampieroricci said:
wonderful work!!
Cheers giampieroricci 👍
Hi Dave - I used to have the Proxxon sander and they are great and do the job very well - but Byrnes tools are just in a different league.
So another update from me - First up was to get the mill out and cut out the notches for the beams.
Then they were glued in place which was quite straight forwards.  I did have to bend them a bit so they they followed the line of the deck clamp.
Next was to make and fit the small knees that connect the shelf to the transom.
And finally a last dry fit of the deck to check that everything fitted OK.  I also got the height gauge out and checked the beams one last time for accuracy.
So before I glue all of the beams in a need to put a final finish on the inside of the hull.  Once this is done I'll glue it all together; finalise the mast partner and make the pump partners before fairing the deck.  I'll get some pictures up hopefully next weekend.
Thanks for all of the encouragement - Mark
2 hours ago, druxey said:
Looks great, Mark!
Thanks druxey much appreciated mate 👍
1 hour ago, dvm27 said:
That's some of the best joinery I've seen Mark! In the close-ups you don't even highlight the beautiful scarph joints on the clamps.
Wow thanks Greg - I think it will all look really nice once it's glued up and tightly clamped together which will take some time as there's quite a few nails to go in too.  Having looked at the plans I think one of the real tests of this build will be the waterway - now that looks tricky as it has to fit tightly and be symmetrical too.   That will be the next big job on my build.
That joinery looks incredible.
Toni
Member IPMS
                           Utrecht-1742
Hi Toni - thanks very much 👍
Not too much of an update but I've been installing the deck permanently  - It really did just click together with very little in the way of clamps.
After all of the beams were installed I finished off the mast partner with the corners that I had not made originally.  I also set the angle aft within it for the mast.
Next were the pump partners - I admire all of you builders who work in a smaller scale.  I wanted to keep it true to the original ship and made the joints accordingly.  This was tricky at 1/24th scale so how you lot do it on a smaller scale I have no idea.
Lastly I faired the deck - this is as satisfying as fairing the hull.  You know that when you have done it - it's another mile stone in the build.  A few pictures
Its so annoying when you see that you cut a beam a little too short - 🤣
So now I need to get nailing - I've discovered that this is not my favourite job.  I'll have a go at that next weekend.   There are some things that I could have improved upon - Firstly the very rear stern hatch is not quite straight and square.  I've obviously messed up a bit there but it's easily fixed.  Secondly I can see that some of my beams are just slightly too short and this will cause some corrections when I make the waterway and spirketting.  Again it's all solvable so I'll tackle those issues at a later date.
I can't thank you all enough for your kind comments - Cheers Mark
It's always a feast for the eyes to see new updates from you. For me it is very helpful to see how you show and describe the individual steps, I can only learn for my construction of Le Rochefort.
Greetings Tobias
On the workbench:
Hi All
Another update from me - before the nailing I decided to have a go at the waterway first.  So here's the first part of my journey trying to make the waterway around the bow.
My first effort went in the bin!  I made two pieces that fitted very nicely around the hawse timbers but I made them too narrow.  Here's a picture of the plans and how I made my error.  I used the measurement "A" which completely failed to take into account the thickness of the planking that sits above it.
Below - The binned parts and the incorrect measurement that I used.
So after a quick message to Gerard Delacroix I got back onto the right track and realised that due to the camber of the pieces I needed to take my measurements from the underside to get the correct thickness.  So I made the same pieces again but left them much wider.  I first fitted the outside to the hull and then placed my templates on the underside to get the correct thickness (I hope this makes sense)
It was only then that I sanded the inside of the parts to shape and this worked quite well.  Next I needed to cut the matching dovetails so that they fitted to the beams.  I couldn't get a pencil in to mark them so I used the plans instead.  I placed the parts onto photocopy so that I could see how the beams lined up.  I then cut out the dovetail templates and glued them onto the waterway parts.  All of the templates are upside down as if you are looking through the part.
Now this may seem a bit extreme but I couldn't see the point of going to loads of trouble to make the dovetails on the beams of the waterway parts did not fit tightly. Next I milled out the dovetails.
It was all worth it as I got a very nice fit.
Next I marked out and sanded the bevel into the face of the parts and this is the result
They should be ok once clamped and glued permanently but I have to say these are not easy parts to make and get a good fit.
I've got to do some decorating at home now for the next couple of weeks so I'll get some more up on the build when I can
Cheers Mark
Beautiful work.
STAY SAFE
current builds:
