HM Cutter Alert by Thukydides - Vanguard Models - 1:64 - first build
Thanks everyone for all the comments and help. I have been practicing on some paper and will share some of my attempts with you once I get closer to something I am happy with.
I the meantime I have finished the cannons and so decided to take some shots of Alert with all the deck fittings temporarily in place before I have to remove them all in preparation for rigging the cannons and potentially painting the freiz.
Lots of work left to go, but she is starting to look like a ship.
EDIT: I realized after I took the pictures that I placed the jeer backwards :). Good there is no glue involved here.
Edited by Thukydides
Link to comment
Share on other sites
Another minor update.
I have been working on trying to get down the painting style. All your comments and suggestions have been a huge help.
In the picture you can see a number of my attempts, you may notice a common theme of them not being good enough, but I think they are slowly getting better:
A - My first attempt at the transom which I have already shown.
B - My second attempt, still pretty far from what is depicted in the painting. This was my first attempt at the tilting helmet.
C - My latest attempt. The shield on the left I didn’t get the shape of quite right. My transom is a little different shape than in the painting so I have to adjust the items a bit. I am more pleased with the middle which though I am not sure what some of the stuff is, it looks much closer to the painting. On the right you can see me starting to block out the shapes for the right hand item.
D - This was my first attempt at the freize
E - My second attempt, better than the first, but still not very good.
F - Another failed attempt.
G - This is the first time I feel like I have sort of hit the style and flow. It still has some significant issues, but this is good enough that I am beginning to think I may be able to actually do this with enough practice versions.
Link to comment
Another quick update. I have finished a mock up of the right hand side of the transom and though I am not entirely sure what everything in it is, I think it is a reasonable representation of what is in the painting.
I am least pleased with the left side as in the marshall painting that side of the transom appears smaller and I have to "stretch" the art to make it fill the area.
Link to comment
Your artistry in hand painting these is amazing, well done!
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Log #37: Painting the Transom Images
Having done a bunch of practice versions I decided it was time to take the plunge and try putting some paint on the model. I still need to do more practice on certain elements, but I felt confident enough in the centre element to give it a try. In case anyone else ever wants to try this I figured I will document the process for this one in detail and subsequent ones I will just show the final result.
For the painting I am using acrylic paint. You can see all the colours I used for reference below.
I also used a wet pallet (mine is a fancier one, but you can make one with a plastic tub and a bit of parchment paper). I highly recommend the use of the wet pallet for painting with acrylics as it stops the paints drying out too quickly and you can mix the colour easily as needed. I also primarily used a W&N series 7 000 brush. It has a very fine point which helps with the detail we are trying to get here, but if you are a new painter I would recommend using a cheap synthetic brush until you learn not to ruin them. I also have a cheap walmart brush I use for blocking in larger colours if needed.
Step 1 is to find a good position to paint in. I wrapped the model in a dish towel and lightly held it between my knees level with my table. That way I could rest my wrist on the table to steady it as I painted. I used a mechanical pencil to lightly map out the shape.
Then using my main shadow colour I blocked in a rough outline of the shapes.
I then filled in the areas to be covered with this shadow colour and then outlined some of the brighter highlights with a slightly darker ochre colour.
Then it was time to place the darkest shadows so now the highest highlights and lowest shadows have been sketched in. Note the highlights are not very bright at this point, I just am marking where they will go.
Unfortunately I got absorbed and didn’t take any pictures after this point. However it was mostly following the same process, just with increasingly higher highlights, refining the shapes as I went. I constantly shift colours going lighter then back to may shadows again trying to blend the transitions.
It still probably needs some miner refinements, but I think it holds up well.
Link to comment
hmm, kind of makes me think:
6a00d83451b31569e2019aff29b7cd970c-450wi
Just kidding, great paint job and thanks for explaining your technique.
Link to comment
Thanks for your painting tutorial. It's very helpful. 👍
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
This looks great!
Current Build Hayling Hoy 1760 - First POF scratch build
Completed HMB Endeavour's Longboat by Artesania Latina
Completed HM Armed Cutter Alert by Vanguard Models
Completed 18ft cutter and 34ft launch by Vanguard Models
Completed Pen Duick by Artesania Latina
Link to comment
Log #38: Mockups of the lower counter
I have continued to work on draft versions of the various images I hope to paint on the ship and given my success with the first one I gave in to feature creep and decided to make some attempts at the lower counter. These are much more complicated images and they are made more difficult by the perspective in which they are painted. I can’t just copy them as they are since the space they are painted on in the painting are two very different shapes from the actual counter.
Below you can see my first mockup. This one did not get very far before I decided I did not like the way I had drawn it. I stopped after outlining the shape and blocking in some of the shadows.
This next one I largely painted trying to replicate the marshall painting. At this point I am not trying to get perfectly smooth transitions, I am just trying to prove that I can largely produce what I want. Though I was happier than this one, I discovered through this attempt however that the perspective stretching was not working very well and the dolphin leaves something to be desired.
At this point I decided that I needed to bring in some other sources to help better define the images and to allow me to deviate a bit more from the painting. I discovered that these are likely Neptune and Salacia and I found this lovely image of neptune with two “dolphins” looking very similar to the ones on the Alert. I noticed that he is generally depicted as very muscular so I decided to try and incorporate this more into the illustration.
So here is the final attempt (up to this point). I am much happier with the proportions and the dolphin does look much more like what is depicted in the painting. I also feel that doing my own interpretation of the toga or or whatever piece of cloth is going over his shoulder was probably going to be better than exactly replicating what Marshall did. Finally I made the decision to add his trident to solve some of my space issues.
I stopped where I did as though I feel this is better than the previous, I wanted to scale up the image to make sure it fills a little more of the counter. Hopefully the next one will be my final mockup before trying it on the actual ship.
Link to comment
Looking good!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Time for another minor update.
I have not had a lot of time to work on the model lately so progress has been slow. However I was feeling confident enough in the right side of the transom mockups to attempt it on the model. I also made the decision to take the plunge and commit to painting the lower counter.
I have only done the first coat on the counter (hence why it looks patchy and doesn’t have the gradient). I also made the decision to paint the top rail of the transom (not sure what it is called) black instead of the ochre in line with the marshall painting.
Link to comment
Another quick update, I got some more time today to do some painting so I finished the transom. I added an extra wavy thing to the image as it looked a bit empty without somthing to fill in the space above the shield.
I also have started blocking in the highlights for the blue background on the counter. Still lots of work to make the transitions nice and smooth, but it should give you the general idea of what I am going for. I also decided to get rid of all the yellow edges as I felt that either I need to go all ocher (as in the marshall painting) or all black. Once I have the main painting done I will touch up a bit and add the edge highlights.
Link to comment
That looks great !👍
Link to comment
I have now finished painting Neptune for the most part. I may go back and make some minor adjustments smoothing some of the transitions more, but it is good enough I think for me to move on to Salacia on the other half of the counter. The toga flowing over his shoulder is the part that I am least pleased with and depending on how I feel about it in a few days I may try to redo that part.
I also figured I would show a picture from further away as the zoomed in photos in some ways make it look much more rough than it appears in person.
Link to comment
Time for another work in progress picture. I have been slowly working on Salacia (the wife of Neptune). After a few test versions, mostly to try and plot out the layout, I dived in. One thing I have found is that it helps to have a lot of reference photos of the subject. These come in two types:
1) On model pictures (such as the Marshall painting) for getting down the colour and style: https://collection.sciencemuseumgroup.org.uk/objects/co521412/cutter-alert-oil-painting
2) The subject depicted in other artwork to help with context:
https://en.m.wikipedia.org/wiki/Salacia#/media/File%3AAffreschi_romani_-_nettuno_anfitrine_-_pompei.JPG
https://www.encirclephotos.com/wp-content/uploads/Belgium-Antwerp-Salacia-Goddess-Statue-954x1440.jpg
This is my progress to date:
I feel much better about the cloth on her than I do about Neptune. I plan to depict her holding the stick wth the leaves as she is portrayed in the statue I referenced above. I think this will add balance and contrast where they are both mirroring each other holding an object, but the objects better represent who they are.
EDIT: And i got the counter done. I also adjusted neptune a little. Next on to the sides.
Link to comment
2 hours ago, GRATEFUL LITTLE PHISH said:
Looks cool. I'm about to start my first model and it's an HM Cutter. Looking forward to referring to your build log. Take care.
Chris
Nice, which one? Cutters are a great first model. Take it slow and read as many build logs as you can. It is always better to learn from others mistakes 😃.
Link to comment
It's the Lady Nelson. I've been reading quite a few 👍 and watching YT videos.
Chris
Link to comment
2 minutes ago, GRATEFUL LITTLE PHISH said:
There was a guy named vossiewolf on here who had an amazing build log going for Lady Nelson and he appears to have fallen off the face of the earth some years ago. Kinda weird.
That is pretty frequent. If you go look at the forum section for new members there is a post discussing the significant number of people who start a build log and never get the model finished. That is why starting with something small (as you have done), is a good idea. I think even in my relatively short time here I have seen a number of build logs I was following just stop posting. Life happens or people just loose interest.
I myself had a period of several months where I made no progress on Alert due to a combination of life being busy and being unsure how to proceed with a problem I had with the model. This lead to me feeling unmotivated to work on it and it took some effort to push through that. You will likely have a similar moment and the key is to find little tasks on the model you can get done. I find that having progress to share helps me to want to do more.
Link to comment
Great advice, thanks! He may have lost interest in the forum, but his skill level was quite impressive from what I ascertained. Tonight I get to do an inventory and open a few new tools, so I'm just enjoying the evergreen stage, no rush. Good chatting,
Chris
Link to comment
I continue to pick away at the frieze on the side of alert. The sections below were a bit more tangly to do as I had already installed the channels and the deadeyes.
I had to break out the magnifying glasses as I only have about 3.5mm of width to work with.
Link to comment
That looks great, very well done!
Link to comment
Thanks to everyone for all the likes and encouragement. One week later I am still picking away at the frieze. Below you can see my progress so far. To try and help with consistency I have been doing each section on both sides of the ship before moving onto the next one. The tiny scale is particularly problematic for these flowery flowing shapes as you can’t use some of the tricks I used with the transom and counter to fudge things as it is all thin lines. My thumb is included for scale.
Because of this I ended up painting over in blue a number of attempts that weren’t good enough. I do feel that I could have done a better job if I had done this before attaching the railing and the moulding, but that is what this project is about, pushing myself to try and learn skills and gain experience of what not to do for next time :).
Link to comment
I love how you painted your ship the way you paint your Warhammer minis. (yes, i have done both, look at my name)
I never really got into the advanced techniques like shading and highlighting, and i haven't painted Warhammer minis in, like, 4 years. I need to though, because i would like to paint a ship like that.
Link to comment
The frieze and stern painting look amazing!
Incredible work!
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
