Halfway done - woot woot!
Also - I've tried at least a half dozen CA glues during this process, and this gorilla glue with the brush is by far the easiest.  It's liquid enough to spread on evenly with the handy brush but also enough of a gel to stay tacky and allow for a little bit of adjustment to the copper plate before it dries.  Really good stuff.
E992B651-CB25-462E-A876-1C7F4567AC59.jpeg.1751bb8a90638a51615b9fd9913328d6.jpegB7130F3F-F258-4084-A283-FF6B7D82C2DD.jpeg.b7547fc7152c53dfff902b0cd297f845.jpeg
It looks like you are doing a great job!
I just finished copper plating my Pegasus a couple of days ago. In hindsight I would say it would be better to reverse the port and starboard plates compared to what they show in the plans. There needs to be a small overlap on some of the plates to follow the line of the hull. With the way shown in the plans and working from stern to bow, the overlap ends up up putting the unriveted short end on top, partially obscuring the rivets of the previous plates short end. By reversing the sides the rivets would always be on top. Too late for me and you - but perhaps future builders might consider this.
Did you roughen up the backside of the plates before applying? I found adhesion was significantly better if I lightly sanded the back with 220 grit first. Same goes for all the decorative freezes.
I can highly recommend BSI Gold+ CA glue for anyone that has sensitivity to CA glue. Using regular CA glue even for a few minutes will make my nose burn for two or three days. But Gold+ is odorless and does not give me any problems even with extended use.
What kind of patina are you aiming for? I wanted my ship to lean more to the decorative side than weathered. So I cleaned up the plates with gentle fore/aft strokes of 0000 wire wool, then coated with ProtectaClear to prevent oxidization. I now have a nice shiny hull that will not dull, and I don't have to be careful about handling as fingerprints are no longer an issue. The ProtectaClear was easy to use and gives a nice smooth finish. The whole hull only needs less than 0.5oz for two coats.
Hey Tech,  thanks for looking in.  I aligned my plates based on the direction in the plans, and they provided for a slight overlap while still allowing the rivets to be prominent - this shows up in my post #96.  You're def right in that there needed to be some overlap to get them to align.
  Thanks for the tip on Protectaclear - I've never heard of it. I haven't yet contemplated how I'll maintain the hull, but I am going for the 'straight out of the dockyard' look rather than weathered with the this gal.
Hey, Bug -- Just checking to let you now you're doing a terrific job on that copper. Also, I've been using C/A with an applicator brush in the cap for some time now and love it. The brush keeps the glue where you want it to be. Would not stray away from the applicator brush at this point.
Pete
Pete
Current Build: Charles W. Morgan - Model Expo
Completed Builds: Santa Maria, Cutty Sark, HMS Bounty - Marine Model Co.
On The Shelf: Flying Fish, HMS Endeavor, USF Confederacy
Excellent job Bug.
I like the foil on the keel edges. I cut the plates to size, however your method looks to give a better result.  Think I’ll give that a try the next time.
Cheers
Craig
Current Build
HMS Indefatigable
Erycina - Vanguard Models
Finished: HM Bomb Vessel Granado - Caldercraft, HMS Pegasus - Victory models, Nisha - Vanguard Models
Terrific coppering job Bug and tips by you and others about the glues and preparation etc. I did restart my Bounty coppering after a couple of hundred plates so 🙄, so nice to see such a neat job.
One question about the keel, does the instructions say to copper the bottom of it?  I only ask as I thought/seen/read somewhere (maybe here on MSW) that ships keels all had "false / sacrificial keel" timber battens on the very bottom and were not coppered?
Edited by AJohnson
The plan does show the underneath of the and I does not look as if coppered. I coppered mine but tbh you cannot see it!
Edited by Craigie65
Cheers
Craig
Current Build
HMS Indefatigable
  Thanks so much Pete, Craig and Andrew.  Pete - Don't know how I lived without it before.  My prior method was dabbing some CA on a toothpick and laying it out where it needed to be - but it often dried too much by the time I got pieces in place; forcing me to rush sometimes.  Ugh.  Loving the applicator brush.
@AJohnson - You and Craig are correct - the instructions say the bottom is to be a false keel (as with other builders on here) and that's probably still going to happen.  My main purpose in using the foil all along the keel was to keep my options open, and also provide a backdrop so if there are/were any little gaps or inconsistencies one sees copper instead of wood.  Mostly because I wasn't sure how the coppering was going to go.
  That said - I also follow my own personal three tiered decision making system:
        Choice #1:  Accurate & Looks cool - a.k.a. "Whatever Dan Vadas did."
        Choice #2: Not 100% accurate, but looks cool/clean
        Choice #3: Accurate, but looks a little funky
Hi Bug
You have been busy. Fantastic work.
Regarding the keel I thought it a good idea to have the keel protected by copper also on the underside. The false keel probably wasn't made from very high quality wood and after losing a part in an accidentally ground contact they would first have had to find a wharf to replace it. So that additional protection by copper would perhaps have paid off.
Being lazy however I usually copper only the underside which is not covered by the false keel.
Cheers
Peter
  Thanks Peter - I'll get the other side coppered then make a final decision on the keel.  Meantime, good timing as I was just looking at your rudder from the Bellerophon earlier this year and dig the rework on the bolt heads.  I'll be swiping that idea for sure!
Edited by Moonbug
Love it Bug - my sentiments exactly! I’ve lost count of the number of times I’ve referenced back to Danny’s logs to re-read how he did something. That said, I’ve referenced your work on more than one occasion, so don’t sell yourself short. 😊
  Thanks Grant, that's quite a compliment!     And yeah - definitely have Dan's build's bookmarked.  And endless source of not only great builds, but no end to innovative jigs and ideas.
  Wrapped up coppering the hull last night and I've got to say - I'm much more pleased with the results than I anticipated. The lines ended up pretty even throughout - of course I had to make a couple of adjustments nearing the waterline and wales as well as the adjustment of the bow angles. But, I made those fixes based on what I thought was logical.  No pictures of it - but the second side went better than the first (of course), so I pulled off some of the bow and stern plates on the Starboard side and redid them to match the Port side. First pictures are finished plating without treating/cleaning the copper and after I added new copper strips to the keel.
Peg_274.thumb.jpg.aeaec7f811ab5e73a3c86a204c853ae8.jpg Peg_275.thumb.jpg.bb853aff9a47a7cf02a6d00c7468bdfd.jpgPeg_276.thumb.jpg.6aa8e6cea68d47caa1e40b8947f8170b.jpg Peg_277.thumb.jpg.eaa55d299ae37e2b0fc3b1f5bb845376.jpg
  Second set of pictures is during the cleaning / polishing process. I lightly sanded down the copper with a 600 grit sponge sander. I bent it up so there were no sharp edges as it was very difficult not to catch the copper plate corners and fold them up.  This sanding was SUPER light and often only in the same direction in which the plates overlapped. As you can see - pretty difficult to get into the areas where the plates meet/overlap.
Peg_278.thumb.jpg.2fee96403e5ab0a0530883ec3a42efe1.jpgPeg_279.thumb.jpg.2d1ba1a12b0b901ed88e2375d51ab4ac.jpg
So - second effort was with this handy wire brush Dremel attachment.  I have a couple of them, and this is the softest.  I also have a plastic Dremel brush which did nothing.  This one however worked like a champ!  I went over the entire hull  on Medium speed - stern to bow, very slowly and barely letting the brush make contact with the plates. Here's the difference before/after.
510334992_WireBrush.thumb.jpg.7d84feb4a9be0ca6c84464da656128ce.jpg Peg_280.thumb.jpg.47efc87bd8fb1849b1e7e4189b2324b4.jpg
  After the brush, I wiped it down with a metal polishing cloth.  Here are some shots of the hull after it's all buffed.  Notice that I did go ahead and go with a false keel on the bottom - however, I kept the copper plate on the bow and stern because I'm happy with the way it turned out.  My waterline strip is walnut to match the little bit of planking that's still showing. I've already decided I'm going to leave this natural - as opposed to painting it black - because I want the main wales to stand out.  Also - there's a Rolling Stones joke in there somewhere but just can't make it happen.
Peg_282.thumb.jpg.42e3b5449b241a4450c9b9ee9ec83585.jpg Peg_283.thumb.jpg.ffdb6f81ec4a719ab32cfb3bd5732c1b.jpg
Peg_284.thumb.jpg.4ec06f356f65fd8a6956a0c98bf0076b.jpg Peg_285.thumb.jpg.83084ccc410e832e0422786cad646b6e.jpg
Peg_286.thumb.jpg.1dc7f7faf2e3af18a2eff5651524c3aa.jpg Peg_287.thumb.jpg.4847e56ca14a7a37f348668b68fba132.jpg
Peg_288.thumb.jpg.20fb83e737818fc2f791a3a41440b2c0.jpg Peg_289.thumb.jpg.6ff7860b3b5241a1a3b2a0c4dbfa1925.jpg
  Next up - how to protect the copper.  I've looked into a few things already - including versions of the Everbrite and protectclear stuff (which sounds a little involved). I've even looked at couple of academic journal studies that talk about chemical elements of copper coloring and deterioration. I'm actually just thinking a couple cotes of wipe on poly.  Any thoughts here are welcome.
Edited by Moonbug
Coppering looks great Bug. As for protecting it, I think you only need to seal it to prevent it from oxidising, so a couple of coats of WOP as you suggest should do the trick.
Bug -- Your coppering job turned out beautiful! That's going to be one terrific model when it's completed. I have a question. Several days ago you commented to "Grant" (gjdale) regarding the value of Dan's posts and his buildlogs. Is it permissable to ask you to identify "Dan/Danny" so I, too, may benefit from his expertise. If so, I'm asking...
Pete
Pete
 Yves, Grant, Mustafa, and Pete thanks so much for the kind words, very much appreciated.   Pete - @SpyGlass nailed it - and that Vulture is my reference for elements of the Peg as well.  It always felt like Danny spent just as much time answering questions and responding to others as he did on his awesome builds. Along with what Spyglass said  (and this is just my opinion) What I still love most about Dan's building is that I honestly don't think he had some sort of huge cache of raw artistic talent - but what he did have was a brilliant mind when it came to how to build something - whether it be jigs he came up with or little tools he crafted himself. His innovation was just as valuable as his perseverance - and that combination always made me feel as though maybe I could do some of those things too.
       I mean ... turns out I can't, but he always made me FEEL that way.  😆
Edited by Moonbug
   Today I worked on the quarter galleries. I still have a few other things to do before they get mounted, but I've been a little excited to get to them. Mostly because I was really impressed with the way @realworkingsailor crafted a more three dimensional version for his Pegasus Build and I couldn't wait to try it - with a bit of my own flair of course.
     I started by adding some additional dimension to the frieze and carvings. The Amati kit uses a couple different layers of photo etch to try to create carvings, but I felt I could add a little more - so I coated the photo etched pieces with yellow ochre, then I went through and carefully dabbed some areas with bits of yellow ochre acrylic and then let it dry.  Then I went through and air brushed a VERY light coat of white, then back over it with Vallejo's yellow ochre "air".
Peg_290.thumb.jpg.200e2ae0dce5415ac9d684b76bfca437.jpg Peg_291.thumb.jpg.a6f16962d93602354b855cccdcb5f13e.jpg
Peg_292.thumb.jpg.2749541e7d1b43ac37dcbb5f27d9ec92.jpg Peg_293.thumb.jpg.21382cb8a605e180639fbc1363791f95.jpg
  On to the quarter galleries themselves.  First step, mark out where they're going to be, then make room with the trim and drill out the space creating a cabin inside and paint it black. Next up, I cut out and shaped some balsa (just as Realworkingsailor did) to give dimension.  One of the most difficult and delicate parts of this operation was separating the window frames which are laser cut as one piece. I used a jeweler's saw with my thinnest blade and very gentle cutting.  Any little gaps are filled with "wonderfill" filler and then the whole thing is painted black and the photo etching is added.  I didn't take photos of that bit, but extra care is needed to bend the pieces to fit the now three dimensional gallery.
Peg_294.thumb.jpg.4facade2898d002807d3d8e02c51a554.jpg Peg_295.thumb.jpg.b706a19c7a143986212eb590f4e8d5b2.jpg
Peg_296.thumb.jpg.5b0478a0114a1f28a97eb05922478547.jpg Peg_297.thumb.jpg.14d976f4b6b34efbbfd1aaca7d48d3ab.jpg
Peg_298.thumb.jpg.8aaba2bc9cdae934e6c62f302157186c.jpg Peg_299.thumb.jpg.f433134b33377e629044c6eb4da1a4a6.jpg
    Now, my favorite part!  I finally figured out that the best way to shape my little microscope slide covers is to carefully hold them against the belt sander!  I marked the shape I needed with a sharpie, and the belt sander worked great.  It was fast enough not to shatter the piece and also half melted half sanded the glass into shape.  It was then glued in place using white glue that dries clear. I actually prefer fabric stitch glue here because it's tackier.  The galleries are just sitting in place for the moment and will be permanently mounted later.
Peg_240.thumb.jpg.7cfb33f5d2f7d38d1a3e0a03ccfdfcf6.jpg Peg_300.thumb.jpg.62343a09cf31c59e622884a630cf84b3.jpg
Peg_301.thumb.jpg.4215a6b8d917409ffe47f938e61f7769.jpg Peg_302.thumb.jpg.4cf4b343957f1238bad526afb75827b8.jpg
  The glass is a bit of a pain obviously, but it looks really good.  I purposely took pictures with an angle where the light reflected so you can see it, but the photos don't really do it justice. Really clear straight on, then catches the light.  As I said, I picked up the tip from a guy on a train model forum and he was right: nothing looks quite like glass, like glass looks like glass.
   Next up - Starboard side.
Edited by Moonbug
Hi Bug
Your quarter galleries could evoke envy among us poor out-of-the-box builders. Wonderful detail.
About the copper: That shiny nice state is beautiful but rather unnatural as copper oxidizes quite easily. My solution is to polish it to remove all fingerprints and stains of glue. Then I let it age just naturally without any protective layer. In a few years it will get that dark, coppery-brown colour which is generally known.
Cheers
Peter
  Thanks everyone for the comments and likes - very much appreciated. Got a bit of stuff done today, but nothing really worth photographing - finished up the port side quarter gallery, a lot of eyebolts, a cleat or ladder here and there - mostly just getting some stuff out of the way so I can start rigging the guns.
  A  quick update on scuppers. I decided to fill them in after all. After a pretty exhaustive search on random little things lying around the house and shipyard, I settled on speaker wires. After finding the closest size, I just stripped out the wiring and used the insulation. I did have to widen the hole a bit with a dental pick at the end of this process.
A03D4064.thumb.jpg.ed2fd1fa273bce026984215166e2bca1.jpg A03D4065.thumb.jpg.8c60175ba61a7c7c94602360f6b958db.jpg
Thanks a lot Greg - appreciate the look-in!
I also got a chance to get rolling on the guns this week.  I started out with a test rig of one gun.  Yes, I know the eye bolt is way too close to the rear of the carriage, but this gun is safely hidden under the aft deck and that will never be seen - hence the "test area."  :)
 Then the all too familiar assembly line process begins.  I honestly have no idea from where these small hooks are leftover - but I'm putting them to use again.  Eye bolts are all painted, two of the three sizes of rope are from @Chuck's Syren shop as are the 3/32 boxwood blocks.
Hooks.thumb.jpg.245486674f00809f7c7aa983eebfc17c.jpg Eyebolts.thumb.jpg.73470fbabaf536fcf46d67598ef81e33.jpg
A03D4077.thumb.jpg.3179a7bd658defb8dbd9bbe9fe829bea.jpg Cannon_006.thumb.jpg.33aa73d7079d639153eb53035e0e24c1.jpg
  I did have to drill out the boxwood blocks to a slightly larger diameter hole to accommodate the rope.  Most gun rigging I've seen always comes across as a little bit chunky to me when it comes to the bocks, so I wanted to use the smallest blocks I could get away with that are still manageable with a rope that maintains some realism.  64 hooks tied with the .10 rope, 32 of which are tied to the .45 rope to create the out-haul tackle.  Of course the ultimate goal here is to get all the rigging to lay in a quasi-natural looking state.
A03D4071.thumb.jpg.0dae4b6ccea43fb6f94596334be841d0.jpg A03D4075.thumb.jpg.c92ae1fe2d85bb3c452920125e17cbd6.jpg
   As an additional note on the above test rig:  I added a tiny dab of glue to adhere the breeching ropes to the sides of the wheels both for aesthetics and ease of mounting. I have not yet made a final decision on whether or not I'll do the in-haul train tackle. I'm pretty sure I don't want to rig them all, and I kind of dig what Dan did with his Vulture where he rigged one train tackle as an example. But I'm not sure my brain can live with that lack of symmetry. We shall see. More to come.
Edited by Moonbug
    I've been plugging away at the cannon rigging. Everyone has their little methods / jigs, etc, for getting the tackle together, so here's mine. I went through and attached one end of the breech rope to an eyebolt and ring, fed it through the rings on the carriage, then clipped it in the soldering holder to tie up the loose end and clip off the extra bits.  I briefly flirted with the idea of feeding it through the carriage bolts/rings, then attaching the entire thing to the carriage - but in a weird way, this actually helped me keep a good measure on the lengths, etc.
Peg_310.thumb.jpg.c96b4f1ece0706e83898e83b7e2ba6cc.jpg Peg_311.thumb.jpg.8f8827c4c6d5a69c750be10d83c30a8a.jpg
    I also opted for the "feed the button into the rope" method as opposed to the wrap the breech around the button - even though the latter is more accurate. It just looks SO bulky to me that I don't care for it. After the guns were rigged, I went through and tried to touch up any blackened/painted areas that got scrapped off; a pretty tough gig.  I've tried a variety of types of paints and other methods of fixident, but still have a heck of a time getting the black to stay on eyebolts and rings.
Peg_312.thumb.jpg.8c2319eb15743056bcd3f53ef2edd0eb.jpg Peg_313.thumb.jpg.73d733c32b5fc072e3c440ba98d13a63.jpg
      You'll also notice that I went with all 16 guns rather than the 14 the Peg calls for.  What can I say, I like a full compliment. Getting the guns in place then allowed me to add the lower deck fittings that I had completed up until this point.
Peg_314.thumb.jpg.ce63221869718572e2af656a98d179f7.jpg Peg_316.thumb.jpg.e48e7fb77e83921bb2034292e4322fc4.jpg
Peg_315.thumb.jpg.10590624285ed7eb40041babb0ccb1d9.jpg Peg_317.thumb.jpg.1fb696d9d709e37b0605ecb62a7ca85b.jpg
Peg_318.jpg.3483ab591031bac0555e7afec18bedf1.jpg Peg_319.thumb.jpg.f6d76578496fe05008b77e25e5f01927.jpg
Been doing some fiddling over the holidays to get the upper decks going.  First, I knocked out the gallows. I say 'knocked out' - but in reality it took a couple of efforts and a few hours to get the decorations the way I wanted them. I saw it as another opportunity to add a bit of embellishment without (hopefully) being too over the top. This is a piece of scrap mahogany.
  Then I started work on the foredeck.  As most of you know - I tend to do things in some unconventional ways and sometimes in unconventional order.  In this case, I decided to try and 'pre-plank' the fore deck before I mounted on the ship.  My thinking here is that I wanted to drill the treenails with the drill press. I don't have quite as stead a hand as I used to, and although my lower deck treenails look ok - they're not perfectly straight. Hopefully using the drill press would achieve that.
   So, I glued my planks to the false deck, and then left some room around the edge of the deck to soak and start bending a bit of Swiss Pear to fit the margin planks. Then I mounted the deck. I missed a couple pictures of measuring and drilling out the treenails, but it's your standard fair - filled in with diluted PVA and sawdust.
Peg_321.thumb.jpg.18d1b1292273ba481f8701d7da35b8fc.jpg Peg_322.thumb.jpg.c5b60b9a7e0cfc29160a1bc4a409dafe.jpg
 The margin plank was fitted by using some card stock as templates, then cutting out and puzzling together the pieces.  Obviously this is a bit tedious and requires cutting and sanding at little bit at a time until they fit together snug. After lots of test fitting, I glued/fitted the margin plank together first, then put it in place.
Peg_324.thumb.jpg.8045da079c15ba9d58bf20401e331329.jpg Peg_325.thumb.jpg.5491a5c3ebe82dd38779bfd3902fe242.jpg
  One thing to bear in mind if you're using anything other than the stock planking strips from this (or really any) kit.  The Swiss Pear is considerably thicker than the thin planking strips provided.  Even after sanding the heck out of it, it's still at least double or triple the size.  So I'll need to beef up the foc'sle bulwark inner planking a bit to make up for that.
Edited by Moonbug
   So... remember I said that I tend to do things a little unconventionally in terms of timing, etc?  Well - here's the downside: I totally screwed up the spacing of deck elements because I didn't think far enough ahead - an error I discovered when I placed the upper deck in the aft of the ship.  As I'm sure most of you know, there can be a pretty big downside when it comes to half following the kit plans and half following the FFM and other builds.  My particular problem occurred with the pumps.
    My big mistake - was following the kit template / false deck with it came to the locations of all the hatches - but then following Dan's more accurate build/locations when it came to putting in the pumps.  I wish I took more 'before' pictures - but I was too irritated and just started fixing. But basically, when I test fit the upper deck in place then looked down through all the holes/hatches -  the larger grate just aft of the pumps is about two times too large - so the the pump handles extending over it go RIGHT underneath the upper hatch that's supposed to be fitted with a ladder.   Doh.   So - even if I were able to fit a ladder in there - folks would be descending right into the pump handles.  Many "potty words" were uttered as I tore up deck planks and fittings.
Peg_327.thumb.jpg.c077ef66ef10b5d418cd36adcf2a1c89.jpgPeg_328.jpg.53eb118f28396ea2d37be66bac099d76.jpg
    I reduced the size of the hatch by half, patched the deck to fill in the gap, shortened the aft pump handles and remounted them into the posts. The good news is - the view of all of this will be severely obstructed by the pumps, subsequent ladder once it's installed, and various rigging and accouterments. I may even throw in a pump dale or two to further obscure my screw up.
Peg_329.thumb.jpg.dbcf8077281bea452daf1b6de0cffe8e.jpgPeg_330.thumb.jpg.632da8354a3e98069ff47a91c457c46e.jpg
  Once again - the reminder here (that we all already know) is - when you're doing a mish-mash of a kit bash that combines the ease and efficiency of a pre-fab kit with other added elements - you can NEVER, ever, think too far ahead.
Edited by Moonbug
That must have been frustrating for you Bug, but you’ve made a very nice recovery.👍
