Hi Vitus,
Thanks for dropping by as well as the good word :)  For the second planking I first established the level of the main wale using three planks, these are the only untapered planks, all the planks immediately below the wale were tapered at the front so as to prevent crowding and the need for drop planks. Because the planks were only 4mm wide bit of edge bending was done at the front in lieu of spilling so as to allow the planks to follow the shape of the preceding plank and avoid clinkering.
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Hi Aldo,
Great to have you back on board my friend, as usual your work is of a very high standard which we have become accustomed to.
Looking forward to further updates mate.
Mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hey Aldo - 'bout time for an update my friend! And you-know-who will be wanting pictures to go with it!
Hi Aldo
Once again I had a look at your Pegasus and find I must use more foul words while working on mine. ;)
I would like to challenge you to use even more foul words while reworking your great cabin and provide it with some real light. Did you notice how B.E. made improvements there? I like that and shouldn’t such a greatly improved quarter badge as yours is allow a real glimpse into the interior of the cabin? :)
Take care
Peter
Thanks for the kind words Mobbsie, Steve, Grant, Sjors and Peter, they are much appreciated :)
Steve, if by gap you mean the area above above the gunports, you are correct, they are indeed unplanked areas, this is how she looks now after completion of the outside planking:
Peter, B.E.'s build is indeed something to look up to and in my opinion, is a Gold Standard for us Pegasus kit builders, I have been keeping tabs on his beautiful build to learn his excellent techniques B)
Internal lighting and complete cabin interior is a very tempting suggestion my friend, but it will be quite difficult at this stage as it will entail even more major surgery in the aft area. My bulwarks are already weakened by my removal of the bulkhead extensions and this may further weaken it, so for now, I aim to just detail up the exterior. Still it isn't over until it's over so I am not completely removing that from my options ;)
Grant and Sjors, you beat me to it guys, I was just about to start an itsy-bitsy update when you posted ;)
Now for my itsy-bitsy updates ^_^ :
As usual, work has been really hectic, and work on Peggy Sue has practically ground to a halt since my last update :( Thank goodness for the Lenten Season, I have been able to sneak in a few hours build time :D
Let me direct your attention to the kit's Main Sheet Bits, they look really cool out of the box as seen below:
Unfortunately, TFFM and Contemporary references of Swan Class Ships again show a different picture:
Good thing Amati has their "Super-Duper Main Sheet Bitts Upgrade Set", in my kit, they included in this set a historically accurate Main Sheet Bitts for my ship ;). I think this comes with their latest release of Pegasus kits :D:
HEHEHE JUST KIDDING!!! ADVANCE HAPPY APRIL FOOLS DAY TO YOU ALL!!! :D  :D  :D  :D  :D
I actually made these from TFFM plans. My first attempt has complete sheaves and the bitts have been spaced further apart than recommended to allow them to fit the slots for the original parts:
post-256-0-45447300-1364741102_thumb.jpgpost-256-0-08486300-1364741099_thumb.jpgpost-256-0-49466800-1364741052_thumb.jpg
The problem with this first attempt is that the bitts are too wide apart and the sheaves are way overscale compared to TFFM dimensions. I thus decided to forego the sheaves in my second attempt below to allow making the cheek blocks more to scale.This new Main Sheet Bitts also has the proper distance between Bitts and thus will not fit the original slot on deck. I will just close these slots with scrap wood, cover them with deck planking and just pin and glue this new Main Sheet Bitt to the deck:
Well, that's about it..... oh wait, by the way, I forgot to say that I fell in love with a frigate named HMS Triton :wub: so I also added these new cutting tasks to accomplish in my shipyard:
I'll thus be having another log soon, yes, I know that I have barely enough time for one build, let alone two, but I can't help it, it's the scroll saw's fault  :P
I'm not in a hurry, but I do plan to finish Peggy Sue before the end of this Decade and Triton before the end of the Century, fair enough goals right? ^_^ That's all for now, Ciao Y'all B)
Best regards,
Aldo
Currently Building:
Past build:
Hi Aldo
OK, you got me with your 1th of April upgrade kit. :unsure:
Great work then, if not by Amati, by you!
And I didn’t mean interior electrical lightning, just real windows. With those already demonstrated surgical skills I wouldn’t fear for the patient.
Cheers
Peter
Hi Aldo, Happy Easter.......... nice to see you back in the saddle again, really sharp work on the bitts ,It's going to be areal winner when you finish her up. Thanks for your remarks on my post. It was my intention to have the rigging set to work, but unfortunately my fingers are bigger than I thought, I had to glue the belaying points, so now they'er set just where they are :P
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Aldo!  You old scratch builder you!  Nice work, and great to see you back in the shipyard.  And Triton too?  Wow :)
Cheers,
Robert
Current Build: HMS Mars
Hi Aldo, your replacement Gallows look so much better. I scoured all my references looking for an example that matched the kit version without success, and I couldn't live with the Chinese Pagoda look either in the end.
I rather liked your bitts with the sheaves, and the set up on the deck didn't look out of scale to my eye, on the photo at least.
One thing to bear in mind re the spacing of the bitts, the rhodings for the pumps are attached to the inner faces of the bitts and will need to line up with the pump cistern centres.
Cheers,
M.
Hi Aldo,
With Valdamart and you I can see a profit in putting you both on stage, nice April fools.
Peggy is looking very good my friend and it's great to see some progress, thank you.
mobbsie
mobbsie
Next Build :-
Hahahaha.  Good job on pulling my leg!!!!!
Seriously though, your upgrade looks fantastic (as does the finished hull).  WELL DONE!!!!
Now, as for the scroll saw being responsible for a whole new voyage............... :)
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
That's a nice update Aldo,
You are gonna be sniffing at the dark side?
And don't listen to that guy Mobbsie.
In about 6 weeks we are visiting him and the Admiral and he is a little bit nervous about that…...
AHA -  so the cat is out of the bag.  You are going to England to hand pick your Aggy.  I just KNEW something was afoot!
Augie
Previous Builds :
Hello Aldo,
Good to see you back in the shipyard. Nice work. I'm glad you found the time to do a little building.
And what is that ..... Going over to the 'dark side' with the HMS Triton?
Good on you! I wish you good luck with the Triton.
Thanks for looking in at my build.
Take care,
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Hi Aldo,
Great to see an update - and what a way to make an entrance! Your April Fool's joke got us all I think!!! Nice work on the bitts, but I'm inclined to agree that the first version with the sheaves looked pretty darn good too.
And sneaking over to the dark side too I see. Well, if life wasn't already busy enough for you, it will be now! :)
Aldo,
You got me also on the bitts.  Well done!!! post-76-0-65158300-1364786746.gifpost-76-0-65158300-1364786746.gifpost-76-0-65158300-1364786746.gif
I'll be looking forward to your Triton.  :)
Hi Aldo. Beautiful work on the Bitts there my friend.
You may not have as much time with your build as you'd wish but you do wonders with those few moments you have.
I was on my way to send a e-mail to Amati demanding the new bitts!  ^_^
Happy Easter even though it's almost over.
Eric
Bummer!
Thanks, Peter, Frank, Robert, M. (B.E.), Mobbsie, Augie, Sjors, Anja, Grant, Steve,Mark, SketchupModeller, Eric, Patrick, Arthur and Wim, your kind words are much appreciated :)
@ Peter: I appreciate your vote of confidence with regards to real windows and interior details for the great cabin, I'll consider them among my options ;)
@Sjors and Anja: Have fun on your visit to England my friends, give my regards to Mobssie and his Admiral B)
@M., Arthur and Grant: thanks for the good word on the bitts with sheaves guys, I am indeed tempted to use them, but recent pictures provided by Dr. Greg Herbert in the link below has given me an excuse to forego the sheaves:
http://modelshipworld.com/index.php?/topic/1533-swan-class-model-no43-usna-museum/?hl=%2Bnaval+%2Bacademy
I am referring to this particular picture, which shows no sheaves on the bitts in question (thanks very much, Greg, for sharing those pics). B.E. aptly refers to it as my my "get out of jail card" :D  :
Best regards,
Aldo
Currently Building:
Past build:
Hi Aldo,
We are going on 10 of May for a few days to Mobbsie .
I shall give him your regards  :D
Me on a trip with a moderator…….wowie!
looking super  Aldo..........you've gone much farther than when I last saw her.   slowly getting all of the builds I was following back,  but that's a never ending task.......so much eye candy out there!   nice planking and glad your fitting out the deck.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Looks very good. I'll be following your progress.
John
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
