Thanks Kevin and Nipper.👍
@ Kevin,  - I think the jury is still out on that one, I'm always edgy until the first planking is done.
@ Nipper -  Kind of you to say so, it's not that time -consuming, there's only so much concentrated effort I can handle at a time. I take quick photos as I go along, write up the post on a word doc, and copy and paste to MSW. Doing the log is a nice break from actual building.
My motives are not entirely altruistic, I use my own logs as crutch to my memory. I'm at the stage of life when I think  how did I do that last time - I've just looked back on Sphinx to see what I did with the Garboard.🤔
Cheers,
B.E.
Your work clearly shows the benefits of taking your time, maintaining high patience levels and a determination to not take short cuts.
Coming from a manufacturing planning background I am having to educate myself in a similar vein.
What May seem slow is often the quickest.
Loverly work.
Thank you
Paul
Right there with you🫣🤔
Regards,
Glenn
Current Build: HM Flirt
Post Nineteen
Hull planking continues
I can now work out the planking runs.
If my arithmetic is right, on paper at least I will need (20) strakes of 6mm stuff and (I) of 5mm.
At the bow the planks will need to taper to 3mm.
0718
I am using the MSW download planking fan which has the added advantage of being the correct 6mm spacing at the maximum width of the base of the fan.
The provided lime strip is of a nice quality but there are variations in widths. A random sample indicates a range between 5.3 – 6.0mm and thickness 0f 1.42 - 1.58mm. These small variations do have a cumulative effect and create ridges and hollows. This is not a big issue and there is plenty of meat to sand out the irregularities.
0706
On first layer planking I use tick strips to mark the central and every other bulkhead with the planking lines.
Variations in plank widths will also impact on the marked plank runs and there will inevitably be error creep as the strakes are applied.
0707
At this point five more strakes have been added, together with another strake adjacent to the Garboard.
0713
On this build I didn’t bother to thin down the false keel in the area around the bearding line to accommodate the second planking. I thought I would follow Jim’s example and finish the first planking short, and fay it to suit the second planking against the stern post.
0714
0716
0709
Edge bending is now required on all bow strakes.
0720
0721
Not a pretty sight in its raw state, but hopefully she will emerge as a swan at some point.
0726
I will now re-mark the tick strip results in the remaining space and apply another five strakes.
B.E.
10/04/2023
Looking good as always B.E.
As an aside - where do you get those yellow (brass?) inserts for the foldback clips you use? Looks like a nifty little clamping system.
Cheers
A
Cheers
Alistair
Current Build -
Thanks Alistair, Glenn has provided you with the answer. You can make them yourself using the spring clip with  one of the handles from another inserted lengthways to provide the tongue.
Post Twenty
… and more planking.
0731
A couple more plank strakes are now added up from the Garboard and slowly the gap reduces. I am content that the midships gap each side remains even at 60mm.
0736
I now have ten strakes left each side to complete the first layer planking.
0729
At the stern, once I reached the stern post I began tapering; this is not a hull shape that requires wider planks at the stern.
The tick marks have been recalibrated three times to this point.
0737
0749
0751
0750
Two, maybe three days should see the first planking completed and ready for sanding, and I suspect a little filling.
B.E.
12/04/2023.
Post twenty-one
Light at the end of the tunnel.
I am now alternating the plank strakes from top down and keel up which should leave the final strake below the round of the hull at midships.
This is a good place to have it in case the final strake works out to be less than uniform in shape.
0752
So, Gromit, how’s it looking – RUFF.
Have faith Gromit, there’s a fair bit of fettlin’ to do yet.
0761
Five strakes now remain, and I have re-marked the ‘ticks’ hopefully for the last time.
0755
0757
Don’t say it William, I’ve heard it all from Gromit.
0760
Has it only been three weeks since I started planking, how time flies when you’re having fun. 🙄
Onwards…
B.E.
15/04/2023
On 4/14/2023 at 11:50 AM, Blue Ensign said:
three weeks
Winchelsea took me six months, planking is fun stuff
Your first planking is looking great, nice start!
Edited by glbarlow
Regards,
Glenn
It seems when it comes to planking you are, in fact, fatigable 🙃
Great work - I'd dread planking a hull of that size.
A
Cheers
Alistair
Current Build -
Cheers, Glenn, and Alistair,
I expect the second layer planking will take a lot, lot, longer to complete as I transfer each and every tick mark from hull to plank. My approach has been somewhat abbreviated on this first layer, but it has given me a lot of pointers to consider when I reach that stage.
I don’t know about ‘fatigable’ Alistair, I tend to keep at it once I’ve started, sometimes to the exasperation of Mrs W.
This is the largest hull I have planked since Norske Love and that was so long ago I’ve forgotten how I felt. The difference with Norske Love is that it is single planked, which without the comfort blanket of two layers, tends to concentrate the mind.🤔
Regards,
B.E.
Hello Spy,
The single lengths are 900mm long, too long in my opinion to handle the run. As I mentioned in an earlier post to halve the runs down the double middle bulkheads offends my eye.
I  can't bring myself to apply the first planking 'any which way',  simply because it's 'only the first planking'.  I prefer to  use a limited tick strip, edge bend, approach which gets me into the rhythm for what is to come.
Just one of my little foibles , but in the final analysis 'any which way' will get you there, providing the fairing and  sanding is completed to a reasonable standard.
Cheers,
B.E.
4 hours ago, Blue Ensign said:
reasonable butt shift pattern, and more or less scale lengths.
5 hours ago, SpyGlass said:
indeed actual planking lengths ?
Good call BE. The extra effort shows well, especially on a hull of this size but really on any hull.
Regards,
Glenn
Post Twenty-two
Countdown to completion
0762
0766
Three strakes left.
0768
0769
Two strakes left and getting a little tight at the bow.
0771
I could get a fit but I decided just for the fun of it to add a drop plank here.
0774
It extends from the stem back to the fourth bulkhead.
0776
0779
One strake only left to abut the drop plank.
Things have worked out pretty well with the remaining strake sitting below the hull round.
0783
A good supply of lime was provided in the kit; I have a fair number left over, but I did use a few wider strips, to form planks like the Garboard and drop planks.
0784
0792
0790
0787
It’s now a case of sand, sand, and sand again.
B.E
17/04/2023
Indefatigable!!! Great planking and brilliant for a first layer. What an epic hull. I now have to plank a 26' launch at 1/64 - not an epic hull at all.
Sand away!
A
Cheers
Alistair
Current Build -
lovel 1st planking, far better than my 2nd
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
1 hour ago, Blue Ensign said:
I think I'm feeling the weight of the large investment in this kit plus the expensive timbers I could potentially  mess up.
@Blue Ensign, you have nothing to fear but fear itself...
Ron
Former Director, Nautical Research Guild, 2021-2025
@modelshipdood on Instagram
Current Build: HMS Diana Update
Completed Builds: HM Gunbrig Cracker #13 (HM Adder Gunbrig)Grace & Peace (Wyoming, 6-masted Schooner), HMS GrecianHMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
Post Twenty-three
The Sanding business
0811
This is a lovely hull to sand, large enough to sweep along it with flexible sanding sheets and blocks.
0812
At the stern the planks are feathered into the false keel to receive the top layer.
0815
There were a few low spots that I filled and sanded and once I was satisfied with a blind feel test I deemed the job complete.
0819
The whole process was completed over two days, and the hull was finally given a coat of sanding sealer.
0821
Sanding sealer contains Xylenes, and is nasty stuff, best done in the open air and wearing a mask and gloves.
0822
At this point I dry fitted the stem, keel, and sternpost parts.
The stem fitted neatly into place with a light tap of the hammer, but before final fitting I was interested to see how the facings related to the curve of the bow planking.
0810
These facings of 1mm stuff are engraved with the lines that denote the various parts of the head and provide a rabbet for the second planking.
0830
I fined down the plank ends a little to provide more leeway in the rabbet.
I find it always pays to constantly look a few steps ahead in a build, and check what’s coming up.
B.E
18/03/2023
19 minutes ago, Blue Ensign said:
Post Twenty-three
0811
0812
0815
0819
0821
0822
0810
0830
B.E
18/03/2023
great job, and now to do it all again
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Looking very good as always.  Nice feature to have the stem fascia create the rabbet.  Are you going to taper the stem, or will that mess up the figurehead fitting?  Looks like the main stem piece could be tapered before attaching the facings.
Cheers,
Jason
In the shipyard:
Post Twenty-four
At this point I skip sections 165-191 and move to fit the keel, stem, and sternpost pieces.
I want the keel pieces in place to modify the build board for the upright hull which will be used for most of the fitting out and detailing.
All these pieces fit together nicely.
Note: The keel facings are numbered 437/439 (Fore) and 438/440 (stern) – not as shown in the manual. The pieces are  port and starboard specific.
0832
I found the trickiest part was fitting the stem facings. I needed to further tweak the planks ends using a micro chisel to allow the facing pieces to sit flat against the stem at all points, and line up with the peg slots.
The hull will remain inverted for hull planking and that board has been modified to protect the vulnerable stem piece.
0833
0835
The stem protectors can be swung in and out of position.
It would be a tricky issue if the delicate figure seating at the prow was to be broken off.
0840
0841
The upright building board has now been modified to support the planked hull.
0842
0838
Indy is now secure and sitting level, I don’t want this beast moving around whilst I am working on her.
On with the show.
B.E.
19/04/2023
The building board a clever piece of work.
Always a joy to see your work.
Doug
Completed:
HM Brig Supply - JoKita / Caldercraft 1:64
HMS Fly - Caldercraft 1:64
HMS Sherborne - Caldercraft 1:64
HM Brig Flirt - Vanguard 1:64
Saucy Jack - Vanguard 1:64
Damn, I should let you do my first planking. I don't get within 10% of being that neat!
Ongoing:
