HMS Indefatigable 1794 by Glenn-UK - FINISHED - Vanguardodel Ms - 1:64
Adding Futtock Staves to Main Mast
I have now added the futtock staves to both the main and mizzen masts. I have attached a series of photos of the process I use.
I placed a length of blacken brass rod in my quad hands and positioned it against the shrouds in it required position. The brass rod is oversized and will be trimmed once the catharpins have been added.
I-1140.thumb.JPG.5546b50f4946ef650823450370caf97a.JPGI-1141.thumb.JPG.c9f1fc5e31bc285002dcec9e41409004.JPG
The copper rod is then secured to the shrouds in two places, as indicated by the blue arrows. Once this is done the quads hand can be removed.
It is then a process of securing the the brass rod to each of the shrouds. I use a figure of 8 pattern for this. To do this the first diagonal is made using a overhand knot. The direction of the tied knot, when tightened is indicated by the blue line
The two free end are then repositioned so second overhand knot can be tied and the direction of the knot, when tightened, is shown by the blue line.
After a touch of ca is then applied to the knots and the free ends are then trimmed.
It did not take too much time or effort to complete the task.
Glenn (UK)
Link to comment
Share on other sites
Nice clear explanation and photos!
Tim
Current build: Continental Navy Frigate ALFRED (build log)
Past builds:     Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
Link to comment
Bowsprit Gammoning
Today I added the gammoning to the bowsprit. It took two attempts. On the first attempt I did not have the figurehead in place. I discovered I could not fit the figurehead once the gammoning was complete as the helmet was fouling with the wolding. Unfortunately I managed to damage the figurehead, the tip of sword broke off. I will try to reglue once the bowsprit rigging is complete, The bow rails also fell off which actually made adding the gammoning easier.
I started the gammoning process by cutting a long length of 0.75mm black thread. I then passed the thread through a beeswax block a couple of times and melted it using a hairdryer. I then made a thimble at one end of the gammoning thread and checked the thread would pass through it.
In the next photo I have started the gammoning rigging. The thread has been looped around the bowsprit and the free end has been fed through the thimble.
In the next photo I have made 4 passes around the bowsprit. There is still some traces of beeswax on the gammoning thread but once the gammoning is complete I will use the hairdryer again to remove.
The gammoning is progressing well, 8 loops have now been added in the next photo.
I ended up doing 10 loops and then tied off the free end. The excess beeswax has been removed with the hairdryer.
Glenn (UK)
Link to comment
Sorry to read about the damage to the figurehead. I'm afraid it might only get more crowded from here on!
Alan O'Neill
Link to comment
Bowsprit Shrouds
I have managed to reattached the broken sword to the figurehead. I also reattached the rails.
It was then a case of adding the 4 shrouds for the bowsprit. The rigging of the shrouds was relatively easy to do.
Next up will be to add the foremast stay and preventer.
I-1153.thumb.JPG.1314f1fce905848e4f0365b50be0b91f.JPGI-1154.thumb.JPG.2ebe37464a420a092950e39b06c96248.JPGI-1155.thumb.JPG.3a1405d95ed04fdbcce7c2555700c813.JPGI-1157.thumb.JPG.650f4d199a8e326fdeef2679899e3183.JPG
Glenn (UK)
Link to comment
Your build continues to be superb!
One question hope you don't mind..  Is there are reason the stay has a single collar with the heart rather than the double collar?  Just curious and I realize at 1:64 this is a tough one.   From Lees The Masting and Rigging English Ships of War pages 41 and 169 below for a better explanation of what I asking about.  I looked to see if both methods were common after 1730 but so far I cannot find any information contemporary to Indefatigable 1794 with a single collar.
Thanks Glenn
Allan
Openheart1.JPG.946952d7321fc4e6884b4321c8712c56.JPGForestaycollars2.JPG.f350ae55324686e9ccb964971dd68297.JPG
Link to comment
Thanks Glenn
Allan
Thanks for the info and kind comments. I generally follow the rigging plans provided with the kit. I also refer to Longridge and Petersson's books to help to get a better understanding.
The forestay and forestay preventor stays are open heart type fixed to the bowsprit (Type D in your photo) and closed heart types fitted to the actual stays as shown in the photo below.
Glenn (UK)
Link to comment
Yes, that is my understanding, but Lees, Longridge, and Petersson all show doubled collars thus my confusion as to why the kit would show a single if the double is what was actually done.  No matter, your build and the kit are super!!
Allan
Edited by allanyed
Link to comment
FYI - This is the image from Petersson's Rigging Period Ship Models (pg.20) that was being referred to.
It is a small detail that would not be spotted by most.
Alan O'Neill
Link to comment
On the Indy the fore stay and preventor are not looped around the bowsprit and spritsail as shown in Petersonn's book.
They are actually located nearer the bow and are only looped around the bowsprit. The bowsprit shroud deadeyes are also fitted to these loops.
Glenn (UK)
Link to comment
There are claimed to be a few "issues" with the images in the book.
Alan O'Neill
Link to comment
Foremast Stay and Preventor
I have now added the foremast stay and foremast preventor and I have detailed the method I used to complete this task.
I started off with making a thimble in one end of the stay and preventor threads. I made sure the thread would pass through the thimble.
Next I added a mouse to each thread. This was a two part process. I used some 0.1mm black thread for the central section and then added some 0.25mm black thread before, over and after the 0.1mm black thread. The mouse does slide up and down the thread.
The stay and preventor were then wrapped around the foremast and the free ends passed though their respective thimbles. The position of each mouse was then adjusted and a touch a ca glue was used to prevent further movement of the mouse.
The close heart was then positioned in the stay (and preventor). I used my quad hands for this, certainly one of the best and essential tools used for my model making when adding the rigging. I have started to add the seizing in the next photo.
I ended up added three seizing's to the stay and preventor.I-1162.thumb.JPG.2a051eaa1703953b225d2f2a013b0099.JPG
I created a thimble to one end of each of the lanyards and then added them to the closed hearts.I-1163.thumb.JPG.f4c88a5e04767c3049dd6f2dab40a3ec.JPG
It was then a simple case of adding a few loops.
I-1164.thumb.JPG.f80c46a7aca3dab4b92618f29faa5eea.JPGI-1165.thumb.JPG.fffb101961385966676fab8d29910bf6.JPG
The completed stay and preventor, ready and waiting for the snaking to be added. I am currently experimenting with different methods for adding the snaking as my first two attempts did not passed muster, fingers crossed it will be third time lucky.
I-1166.thumb.JPG.a5aa5d64c057d4279bdaa7b6ad6a4adb.JPGI-1167.thumb.JPG.a58969a591f065098ce7b9a4e6cb97b5.JPG
Edited by Glenn-UK
Glenn (UK)
Link to comment
This seems to be the case but this book's drawings are a good guide in many respects as long as further research of contemporary based information is done to confirm or correct any item.   Unfortunately it is somewhat limited as it is based solely on the contemporary model  Melampus (36) 1785 which as Petersson points out on page 1, has been attended to by restorers over the years.   Rigging restoration is not uncommon and based on the single collar, it appears someone may have gotten it wrong.
Allan
Edited by allanyed
Link to comment
You might ask Chris.
― Jimmy Buffett
Current builds:    Rattlesnake
On Hold:  HMS Resolution ( AKA Ferrett )
Link to comment
Adding The Snaking
This is this first time I have added snaking to one of my models. I tried a few different methods to add between the fore stay and preventor but I really struggled to get them looking anywhere near passable.
This morning I thought I had thought of a fool proof method, which was based on what I use to do when building Airfix models boats as a young boy. The method was essentially to pre-make the snaking and then to attach to the stay and preventor. I started this process by making a template.
I added a series of pins where the snaking connects to the stay and preventor. A length of thread was then wrapped around these pins. A coat of diluted pva was applied to the thread. and left to dry. I was hoping that, once the thread had dried out, the thread would retain the required shape and that I could then tie it to the stay and preventor. I made a schoolboy error in that, as the diluted glue dried the thread had become stuck, in some places to the template. I lost the shape as I tried to release the thread from the template. Although I thought the method was a viable option I decided to abandon this approach.
All was not lost. I retained the template and clamped it to the stay and preventor.
It was then a case of securing the thread to the stay and preventor. I ended up using a clove hitch to secure the thread to the preventor (top). I used a simple wrap around for the stay (bottom).
I did not make a great job of the snaking but, compared to some of my previous efforts, I am reasonably happy with the end result.
I-1174.thumb.JPG.e562b65f69b53889fbf90e78721d9c1e.JPGI-1175.thumb.JPG.591758229cf92780a4f2f7b2f831f890.JPG
The final task was to apply some Indian ink to dye the snaking. The snaking is not perfect but I do not have the patience or will power to rip it off (again) to get a better end result.I-1176.thumb.JPG.2070b3dfb1e840828e348a9a07082aa7.JPG
Edited by Glenn-UK
Glenn (UK)
Link to comment
Hi Glenn, Thanks for sharing your tips on trying out snaking. I have only tried it once on a build and found it to be a torment. Hopefully one of our MSW Sages will come to the rescue. I think yours will look very good indeed when you have blacked them with ink.
Edited by AJohnson
Andrew
Completed (Kits):-
Vanguard Models (1/64) :HM Cutter TrialNisha - Brixham Mumble Bee'
Link to comment
7 minutes ago, AJohnson said:
Hi Glenn, Thanks for sharing your tips on trying out snaking. I have only tried it once on a build and found it to be a torment. Hopefully one of our MSW Sages will come to the rescue. I thinks yours will look very good indeed when you have blacked them with ink.
Many thanks, I know I could have done a better job. The template really helped and I feel confident I can make a better job for the main mast stay snaking.
Glenn (UK)
Link to comment
Futtock Shrouds
Over the last few days I have been working on adding the futtock shrouds to the right-hand side. The first task was to make all the shrouds for both the right-hand left hand side. Next I populated the mast platforms (both sides) with the deadeyes.
Once that was done I ran the right-hand side shrouds in and used clamps to apply to light tension. I then applied a coat of diluted pva to the shrouds and left them dry. The clamped shrouds are shown in the photo below.
Next each shroud was wrapped around the back of the futtock stave. A clamp was used to keep the line in place. The shroud shown in the next photo is now is having the seizing added.
When adding the seizing I first ran the seizing thread through a block of beeswax a couple of times which I have found has made it easier to work with. Once each seizing is complete I use a hairdryer to melt the beeswax before adding a touch a ca. The method of wrapping and securing the shroud I have using is not strictly in accordance with the two methods outlined in Longridge's book but it is a close enough approximation for my needs and ability.
The completed right-hand side foremast is shown in the next photo.
The complete right-hand side main mast is shown in the next two photos.I-1181.thumb.JPG.ded54f69400b3a27fe2c868e19b64aa2.JPGI-1182.thumb.JPG.6f82717f6cba4cea4d1037c2eaf9bef4.JPG
The mizzen mast proved to be a bit more of a challenge. In order to leave room for wrapping the topgallant shrouds around the bottom of the deadeye stroops I placed some thread around the stroop base, as shown on the next photo. Unfortunately thread I used for this was too thick and I there was too much vertical movement of the stroops within the platform once all the shrouds had been added.
I was able to carefully remove all the seizing's and start again. Second time around I used a much thinner thread, as can be seen below.
These yielded much better results and once seized, as can be seen in the next photo.
I will now add the ratline lines to all the right-hand side futtock shrouds before moving on to repeat the process for the left-hand side.
Glenn (UK)
Link to comment
Futtock Shroud Ratlines
It did not take me long to add the ratlines to the right-hand side futtock shrouds. I used a template to set the distance between the shrouds.
The completed foremast futtock shroud
The following is not a great photo showing the completed main and mizzen mast futtock shrouds.
A final picture of the Indy
Glenn (UK)
Link to comment
Futtock Shrouds - Completed
It was a intense day in the shipyard yesterday as I wanted to complete the futtock shrouds as I will have very limited shipyard time over the next few days.
Working in to the early evening the shrouds were finally completed. This is another milestone reached with this project but there is still a few more months work ahead to complete the build.
The completed fore mast futtock shrouds is shown in the next two photos.
I-1190.thumb.JPG.62a8224f09a611c09a0d7c2fdfad7139.JPGI-1191.thumb.JPG.50408319ee95b5f2cb90d3a926ba9198.JPG
The completed main mast futtock shrouds are shown in the next two photos. I might need to redo one of the catharpins which looks a bit odd in the photo below
I-1192.thumb.JPG.57733301a556822226cb4bf81b1a6912.JPGI-1193.thumb.JPG.9d876068f18cf2e100b2cabed4773e9c.JPG
The completed mizzen mast futtock shrouds are shown in the next two photos. I might redo the aft catharpin which is a bit oversized, as it is a bit long as can be seen in the second photo below.
I-1194.thumb.JPG.b16ea32d33eba6d1b0b6bfcdbabd024a.JPGI-1195.thumb.JPG.0efbe7d1e6373da2986ca1e978886019.JPG
Finally a few pictures of the Indy. My white backdrop is not big enough for taking pictures of the Indy.
I-1196.thumb.JPG.13e5d433962369a0618ac211428e3090.JPGI-1197.thumb.JPG.25d7839503cb3190341cd52704c3f000.JPGI-1198.thumb.JPG.6b5f9d9d351d7bbae6aea511e50d33ed.JPGI-1199.thumb.JPG.1013ecfeff999919099eb09224a9f90d.JPG
Edited by Glenn-UK
Glenn (UK)
Link to comment
Hi Glenn,
Sorry if this was raised before.  There are no wooden hoops shown above and below the rope wooldings on the masts which I thought was always done so they did not get chafed or move on the mast.  Was it not as common as I thought or could this have been an anomaly on Indefatigable?
Regardless, she continues to be a superb build.
Allan
Link to comment
24 minutes ago, allanyed said:
Hi Glenn,
Allan
Thanks Allan
I have no idea regarding wooden hoops. I am just following the plan sheets provided with the kit for for the position of the woldings and iron banding.
Cheers
Glenn
Glenn (UK)
Link to comment
3 hours ago, Glenn-UK said:
Thanks Allan
Cheers
Glenn
The wooden hoops are never shown because scaled down to 64th, they would be less than 0.6mm wide (1.5 " or 38.1mm wide full size).
Vanguard Models on Facebook
Link to comment
Hi Chris
I looked at a number of contemporary drawings of masts and as you say, the wooden hoops on either side of the wooldings are not shown on any that I have seen.  Looking at photos of contemporary models they all have the wooden hoops above and below the wooldings but these are all 1:48 scale so a good bit more noticeable than they would be at 1:64.
Allan
Link to comment
2 hours ago, Blue Ensign said:
Kit provided hoops at 1:64 scale are probably not feasible, but that doesn't mean they can't be added at that scale.
Well said B.E.  I did a 1:64 drawing to see if they show up and they are quite clear when printed.  I am guessing that it would not be difficult to include a sketch or verbal instruction about these hoops even if supplying material is impractical.
Allan
Link to comment
Indy Build Status
My time in the shipyard has been very limited over the last 10 days so progress has been slow but I have completed adding the stays and preventors for the main and mizzen masts.  I have attached a couple of photo's of the current build status.
I-1200.thumb.JPG.e7112e7412b4b18304f9b1db79972486.JPGI-1201.thumb.JPG.834fd6f939289ae211dd94a6e4dd5cae.JPG
Since my last post I have added the main stay and preventor. The aspect which I found difficult to add was the snaking. It took me a few false starts before the snaking was completed to an acceptable level, albeit it is far from perfect.
I-1202.thumb.JPG.9a99abce034bb4285ed9d3e504d54075.JPGI-1203.thumb.JPG.86454c3256a6b50fbbedc7f3f743efb5.JPGI-1204.thumb.JPG.ce624bf740f6e2a2d82aa333b2e42ef4.JPG
Next I added the mizzen mast stay which was a very easy task to complete.
I-1205.thumb.JPG.80a4a14c8e2e5e9c12915e2edbbf20e1.JPGI-1206.thumb.JPG.fc86e88098c4bbed8c886f549490d61c.JPG
Before I move on to adding the top and topgallant masts there are a few more blocks which I need to add to the three masts, as shown below.
I-1207.thumb.JPG.2db8bdc5024fa8b52f74a89ee1e60dd0.JPGI-1208.thumb.JPG.53c807e93432ed1afbc47d6243488e82.JPGI-1209.thumb.JPG.9d336bad63cb3cc827dd3a208f6484a5.JPG
Edited by Glenn-UK
Glenn (UK)
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
