Roman Quinquereme and Claw by Glen McGuire - FINISHED - 1/500 - BOTTLE
The concept for this project was inspired by @Ian_Grant's amazing build of a working quadrireme.  I have been following that build for a long time and it has been an object of utter fascination for me.  While I don’t have a fraction of the mechanical engineering skills required to do what Ian is doing, I did think it would be a cool idea to put a quadrireme or quadrireme-type ship in a bottle.
In choosing a ship for a project, I am drawn to ones that are unique and/or have an interesting story - ships that have historical significance but might be a bit off the beaten path.  I also want to pick something that offers an opportunity for an interesting presentation.  So after deciding I wanted to do a quadrireme type of ship, I started digging around and stumbled upon something called the “Claw of Archimedes.
Brief History
Archimedes was a Greek mathematician who lived in the city of Syracuse from 287 to 212 BC.  Many consider him to be the greatest mathematician of ancient history and credit him with laying the foundation for calculus, approximating the value of Pi, and a host of other mathematical achievements.  In addition, he was also a renowned inventor.  During the second Punic war between Rome and Carthage (218 to 201 BC), King Hiero of Syracuse tasked Archimedes with devising a defense for the seawalls of Syracuse.  The king’s particular concern was an amphibious assault from Roman quinqueremes under the command of Marcus Claudius Marcellus.
Archimedes solution was to build a mechanical contraption which became known as the Claw of Archimedes.  The Greek historian Polybius described the claw’s build and performance:
“…(the claw) let down an iron hand swung on a chain, by which the man who guided the crane, having fastened on some part of the prow where he could get a hold, pressed down the lever of the machine inside the wall; and when he had thus lifted the prow and made the vessel rest upright on its stern, he fastened the lever of his machine so that it could not be moved; and then suddenly slackened the hand and chain by means of a rope and pulley.”
Here's a couple of artist's renderings of how it worked:
Picture6.jpg.13906a944e2adb9a49b61f7b0c178e09.jpgPicture7.jpg.b843d2e21694a5e1763d450508dd07e4.jpg
Multiple claws were deployed along the Syracuse seawall and were used effectively during the siege, sinking or damaging many of the Roman quinqueremes and causing much destruction of the fleet and soldiers.  While the Romans eventually breeched the seawall of Syracuse and stormed the city, the claws protracted the battle and were credited with large casualties on the Roman side.  Unfortunately, Archimedes eventually lost his life during the siege despite Roman orders not to kill him.
Link to comment
Share on other sites
Quadrireme vs Quinquereme
While Ian is building a quadrireme for his project, the Roman ships attacking Syracuse were primarily Quinqueremes.  The tyrant of Syracuse, Dionysius I, is credited with the invention of both types of ships in the early 4th century BC.  Quadriremes were based on biremes and propelled by two banks of oars on each side of the ship.  The quad in the name comes from having 2 oarsmen per oar, thus 4 oarsmen for each vertical pair of oars.   Quinqueremes, on the other hand, have 3 banks of oars on each side.  The quin in the name comes from having 2 oarsmen per oar on the top 2 banks and a single oarsman per oar on the lowest bank.  Quinquereme cut-away illustration below.
According to Polybius, the typical quinquereme was 45m long with a beam of 5m and 90 oars per side.  It had a displacement of about 500 tons and carried a crew of approximately 420 men, including 300 oarsmen and 120 marines.  Here are a couple of examples of the full ship that I will try to model mine after:
Picture4.jpg.826627c653c8953913f5eacc5ecac508.jpgPicture5.jpg.008a2c0c12b08dacaa9f5fb4a98a81c1.jpg
Edited by Glen McGuire
Link to comment
SIB Concept
My rendition will have a Roman quinquereme inside a bottle as it approaches a portion of the seawall of Syracuse.  I will have a claw of Archimedes hovering over the top of the seawall.  The claw will be hooked onto the neck of the bottle lifting it up out of the water.  Here’s the usual crude powerpoint drawing of the concept.
So without further ado, here we go!
Link to comment
Wow, what a cool subject!  I'm in for this one Glen!  So creative!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
You learn something new every day!  Never heard of the Archimedes claw although he certainly knew lots about making ships float, or in this case sink.  If these Galleys weighed 500 tons.  Building a muscle powered mechanical device to lift even a fraction of this weight is remarkable.
Roger
Link to comment
Glen, you have surpassed yourself with this idea. Very interesting history; I had never heard of the claw nor did I know that Archimedes was killed in a siege. I do remember, though, spending a lunchtime hour puzzling my way through his geometric approximation of pi in a "History of Science" course in first-year engineering. Greek mathematicians were very clever and it amazes me how much they were able to calculate; another example is Eratosthenes's calculation of the circumference of earth which was only about 2% in error. Surprisingly perhaps, his math was very simple compared to Archimedes's calculation.
Just a correction: my galley is a quadrireme not a trireme.
It's surprising how little we actually know for certain about these ships. A quadrireme may have had 3 banks of oars with 2 men on one of them (analagous to your quinquireme drawing above), or 2 banks of oars with 2 men apiece. This is because it is thought that the "quad...." or "quinqui...." indicated the basic "unit" of men per "subset" of oars. I opted for two banks of oars to keep my model simpler.
There were also "sexteres" which are broadly interpreted as triremes with 2 men per oar.
But there are also mentions in surviving texts of "twelves", "sixteens", and even "twenties". To my knowledge no one has any idea what rowing system they employed.
As an aside, it is interesting to analyze the effect of multiple men per oar on total power for the ship. Adding a second man on an oar does not double its power because the outermost rower exerts pull over a shorter distance therefore adds less energy. According to Pitassi he generates about 0.8 "manpower" giving 1.8 "manpower" per double-manned oar. (a third man adds only about 0.6 manpower).
If you believe a quadrireme had 3 banks of oars having 1-1-2 men, each set of 4 men generates 3.8 manpower.
If you believe a quadrireme had 2 banks of oars having 2-2 men, each set of 4 men generates 3.6 manpower ("only" 5% less but speed was critical in galley battles).
Ancient galleys are a fascinating subject. I'm looking forward to your build progress, and can't wait to see the little oars moving! 😉
Edited by Ian_Grant
sp
Link to comment
I remember a Scientific American article from many years ago examining the design of these large Galleys.  One conclusion suggested that they might have been catamarans- two triremes linked together as a catamaran would allow efficient disposition of six banks of oars.  This would also provide the stability necessary for the large heavy siege towers shown in the pictures.
Roger
Link to comment
I fixed my reference.  Not sure why, but I had it locked in my mind that your were building a trireme.
Thanks for historical context of the ancient galleys or "reme" ships as I've started calling them.  While doing my research, I was also surprised at how many versions of history there are surrounding the details of these types of oar ships.  I decided I to pick the version that made the most sense to me and run with it for this project.
Thanks also for the engineering lesson.  I find it fascinating, but way over my head.  That's why you are able to do what you do and I'll have to stick to what I do!!  😃
And just so the right expectations are set in advance, the only way my little oars will move is if I drop the whole thing and they go scattering across the floor!!
While doing my research on the claw, I also ran across another interesting invention he supposedly devised to defend against the siege.  It was an array of parabolic mirrors mounted atop the seawall that would concentrate the sun's light on the approaching ships and set them on fire - a death ray of sorts.  But some historians insist it's legend rather than fact.
Thank you, Mike!  Glad to have you onboard for another ride.  We will see how this thing turns out.  😵
Link to comment
Good luck on your build, following  along. :cheers:
Start so you can Finish !!
Finished:         The Sea of Galilee Boat-Scott Miller-1:20 ,   Amati } Hannah Ship in a Bottle:Santa Maria : LA  Pinta : La Nana : The Mayflower : Viking Ship Drakkar  The King Of the Mississippi  Artesania Latina  1:80
 Current Build: Royal Yacht, Duchess of Kingston-Vanguard Models :)
Link to comment
Of course I'm in too.
One question though, are you going to have the water level (and ship) in the bottle level with the bottle side, or angled with the bottle and level with the sea surface underneath?
Link to comment
Another ship I ran across in my research was called the "Tessarakonteres", which is similar to what you describe, Roger.  It reportedly was a massive catamaran galley built by Ptolemy IV Philopator of Egypt.  There's an interesting discussion about the ship here:  https://www.thearchaeologist.org/blog/the-hellenistic-giant-galley-tessarakonteres-one-of-the-largest-human-powered-vessels-in-history.  Below is what the site calls a speculative illustration.
I nominate this for @Ian_Grant's next servo-powered project.
Link to comment
Hmmmm.  Good question, Javelin.  I have not thought that far ahead yet.  But I suppose I should respect the laws of physics and make the water in the bottle level with the sea surface.
I haven't even started yet and things just got more complicated!!  😳
Link to comment
Interesting project.  I've not heard of the "claws" before so a plus is learning something new.   I"m in for sure.
Link to comment
The transverse stability of a floating body is directly proportional to the cube of the breadth  (BxBxB) at the waterline at which it floats.  For most hull forms, beam decreases as draft decreases.  In other words, the hull becomes narrower as you move closer to the keel.
It was, therefore, probably not necessary for the Archimedes Claw to completely lift the bow from the water for it to work.  By raising it to the point where the waterplane became narrow enough to reduce stability the hull would tip and fill with water through various openings.
Less dramatic, but more likely.
Roger
Link to comment
I believe you are correct, Roger.  The Greek historian I quoted above (Polybius), also said this about the claw's effect after it hooked onto the bow and lifted it some amount:
"The result was that many of the vessels heeled over and fell on their sides: some completely capsized; while the greater number, by their prows coming down suddenly from a height, dipped low in the sea, shipped a great quantity of water, and became a scene of the utmost confusion."
Link to comment
Wow, you are certainly not shy of undertaking a complex project Glen; good luck mate.  I look forward to following this one also.
cheers
Pat
Link to comment
"...became a scene of the utmost confusion."    HaHa...that's one way of putting it I guess.
Link to comment
Obviously a master of understatement.
Link to comment
I know I said in my first post above, “Without further ado, here we go.”  But I actually have some further ado before I officially get started on the quinquereme and claw.  I am dedicating this project to my nearest and dearest friend who suffered a massive stroke 5 weeks ago and spent 17 days in ICU.
She has been a big part of my SIB work even though she knows nothing about ships or modeling (you could say she doesn’t know ship from shinola 🙄).  She gave me the bottle for my first scratch SIB, made me redo my “boring” mono-colored shields on the Oseberg, picked out the eyes for my Kraken, and offered great suggestions on a bunch of other things.  She was also my editor for an article I wrote for the USS Constitution Model Shipwright Guild magazine, The Broadside.  She takes everything I do and makes it a lot better.  So this one is for her as she battles thru rehab.
And now for real, without further ado, here we go!
Link to comment
My thoughts and prays for your friend, my friend. And a extra pray just because she is your friend
  :cheers:
Link to comment
I hope and pray for the best for your friend, Glen.  She sounds like she's a one of a kind jewel.
Link to comment
Glen, my best wishes to your friend for a fast and full recovery.
cheers
Pat
Link to comment
 Sorry I missed the startup, Glen. This one is going to be epic, a great dedication piece for your friend.
Current Builds: 1880s Floating Steam Donkey Pile Driver
Completed: Early Swift 1805 Model Restoration
Link to comment
I’m late to the party (again) Glen, but I’ve pulled up a chair next to Mark beside the bar. We’ll empty a few more bottles for you while we’re there! Best wishes for your friend’s recovery - she sounds like an awesome friend.
Looking forward to following another epic build. 🙂
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
