Thanks Ben. Of course! :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Looks really good Rusty, you leave any wiggle room when you cut it out?
Ben
Can I have a translation or explanation  for "wiggle room " ???????
Sjors
Hi Sjors,
To me "Wiggle room" is cutting the transom a tiny bit oversized and the window openings a little smaller so the I have a little room to adjust, wiggle, to the correct position and then sand or trim to the finished size.
Rusty
Fudge factor, that way if you really mess up it rhymes with the next words out of your mouth :) Rusty, I noticed your files do you use cheapo ones like me and replace them often or are they nice ones that stay shrarp?
That a good question. I got the same ones also and still use them. When I think it's time to replace them I do. I will wait and see what Rusty says about his.Like I said this is a good question.
Wacko
Joe :D
Go MSW :) :)
 I noticed your files do you use cheapo ones like me and replace them often or are they nice ones that stay sharp?
Thanks ASAT and Joe,
They are relatively inexpensive ones. I only use them on wood and I’ve had them for 5-6 years now. They are
still in an acceptable condition but once they head south I won’t feel bad about chucking them.  :D
Rusty
Oh my where did it get them?
The diamond files were either Micro Mark or Model Expo. The metal files were from a local hobby shop. I think.
Rusty
I’ve started working on the fancy molding on the transom. The molding is cut from 1/32” thick
stock and is 1/16” wide. The shapes were traced and then rough cut out with a scroll saw.
I then sanded them to their final shape. I then used a scraper to obtain the profile I wanted.
Here is where I’m at so far.
Rusty
Hi Rusty, lovely work.  Did you make your own scraper or buy somewhere?  Would love to try this myself in the future.  I was going to ask Chuck if there is anyway to get some similar to those provided in the Confederacy kit.
Cheers,
Jason
In the shipyard:
Thanks Jason,
I made my scraper from a leftover Confederacy scrapper.
I just used small files to form my desired profile as Chuck describes.
Rusty
Hi All. Sorry for the delay in posting but between pc problems, the holiday and general family stuff I’ve been a
little busy. That’s not to say I haven’t gotten any modeling done. Well now that I have a new pc and I’m not using
the Admirals laptop and the backup files have been transferred I’ll start getting caught up.
I have completed the moldings on the transom and while doing so I noticed a minor problem. Self induced I must say. :angry:
The upper counter is supposed to be uniform from port to starboard. Mine wasn’t! It was easy to correct this but in doing
so it threw off the height of the bottom of the quarter galleries. They are supposed to set on top of the black strake. Mine
will be into the black strake. It was the only way I could correct my error without tearing out the transom and wales. It just
goes to show the relationships between so many portions of the build. Miss on the wales placement and it alters the counter
which alters the quarter galleries. :huh:
Here you see a set of laser cut lights and trim on laser board that I got from Chuck. This is really nice
stuff. Very thin and delicate but durable. I don’t the gentlest touch but the outer lights survived my
handling. :)
More to come in a bit.
Rusty
That looks fine Rusty.  Nice save on the gallery counter.   They are tricky buggers.   The hard part is making sure the angle is correct so the windows fit OK.    Luckily...if your windows for the galleries need some tweaking,  I can just make some adjustments and cut you new ones.  So dont fret about that.   All you would need to do is send me some templates with the correct angles.
Chuck
Thanks Augie and Chuck, also thanks for the offer to re-cut the windows. You are right the angle was
off and now makes this an oh crap moment. I adjusted the rear most upright and that corrected the
angle for the rest of the windows.
Here is the new angle.
For the roof I had to make shingles and as Chuck described slicing them from a strip of 1/8” boxwood instead of
cutting from a 1/32” sheet was much easier. The pieces are cut a little thinner than 1/32” and then sanded to clean
them up and make them even thinner. The shingles were placed one row at a time. Once dry the tops of the shingles
were sanded smooth to match the roof angle so the next row would sit flat.
This catches me up on the work I had done while my pc was down. Now I have to decide do I rip it all out and get the
new windows at a different angle or continue on and make the columns for between the windows. Hmmmmmm. :huh:
Rusty
She is looking superb Rusty and build into a very fine model.  Chuck's 'bits and bobs' look excellent quality; thanks for the feedback on those.
cheers
Pat
Hi Ben. Until Chuck offered to cut new windows I was perfectly happy! Now it has me wondering.
I'll contemplate for a bit and see what happens.
Thanks Pat. Like we already knew his parts are the best.
Rusty
Here I’ve completed the decorative rail on top of the quarter galleries. My rail, Chucks has 3, has
4 decorative pieces in it :( . My curve was a little bolder so it ended up too long for three so I
modified it to make four fit. I’ve decided to leave well enough alone with the windows. They won’t
be installed until much later as there is a lot of sanding and they will just trap dust and debris.
The only thing left to do for now on the galleries is to make the decorative columns. I am waiting
on a .016 kerf saw blade so I can cut flutes down the face of each column.
That will complete chapter 6.
That will also catch me up to where Chuck is at right now. That will leave me time to work on
some other models I’ve shoved to the side. Also my daughter is moving to another house next
month and I have a looooooooong “Daddy do” list that will keep me quite busy for the foreseeable
future.
I just have to remember how to work at full scale again! :D
Rusty
Just spent the last few hours here admiring the fine work you're doing Rusty. The planking turned out beautiful along with the stern. Very nice! I hope you don't mind my following along this late in the game.
Cheers  :cheers:
GEORGE
Hi George, Thank you and welcome aboard!
Thanks Pat, Yes now that the hull is planked it will be fun adding more detail to her.
Thank you all for stopping by and all of the likes. :)
Rusty
Hi Dave,
Thanks! Yes they are both beauties and the Winnie would be worth the wait. :)
Rusty
  • 2 years later...
Is this build still alive??  Has there been any progress on the Winchelsea??
I was very interested in following along with this (or Chucks) Winnie build.
Probably make this my next build if/when that time ever gets here....
It's a beautiful ship !!!
Thanks
Till next time.....     😎
Steve
Finished:              Artesania Latina Constellation;   Model Shipways USF Confederacy:  Medway Longboat 1742 - Syren Ship Model Company
Current Build:     Syren's Winchelsea
Interesting you should mention the build.   I am making preparations to begin working on the Winnie within weeks.   It is very much alive.
Chuck
