Don't you just love those Parrel's, I like the way you done yours though.
Looking real good Ray.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hi Ray,
I'm new to MSW and this build log.
I just finished taking a couple hours reviewing your log.  What an incredible two year journey you've been on constructing the Diana....really an outstanding build to be sure.
I can't thank you enough for taking the time to document at such a great level of detail....with both your informative narratives and simply top notch photography to go along with it    :)
Boyd
Edited by thomaslambo
Boyd
Current Build - HMS Bounty - Artesania Latina - Scale1:48
Thanks for the many likes and positive comments, the photos are getting harder now the rigging is taking place, taking photos of the rigging is more problematical, close-ups are ok but when showing a rigging run, it is hard to get all the run in, and in the longer shots the runs are hard to see, and not just looking like mass of ropes,but as the photos seem popular I will try to keep them coming.
Part 3
Lastly the topgallant yards have been fitted to the mast in the same way as the topsail yards. The Parallels definitely go on better when tacked to the mast.
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
Just a small update
The next rigging job to be completed has been all the yard lifts,the topgallant lifts were belayed to the cleats tied to the shrouds.
Mizzen lift
Main & mizzen lifts
Main yard lift
Ray
 Completed  HMS Diana
Progress has been a bit slow mainly due to having a bout of flu which laid  me up for over two weeks.
The first photos show the tac toggles some start at a block and some go through a rope loop. The next part of the rigging was to add the leechlines and the buntlines to the fore & main yards and the crossjack,I then added the cluelines and sheets to all three masts,I am not adding  the tac sheets for the moment to give access, the next decision, is wether to add the braces before the gaffs and the spritsail yard are fitted as some braces are rigged to the gaffs its is still a mater of turning space.
Tac toggle in the making
Toggle through rope loop
Toggle through a block
Fore main yard
Main yard
Main & Mizzen
Mizzen
Ray
 Completed  HMS Diana
Hi Ray, it's time for me to jump in. A few days ago, I thought I would research this frigate as my next build. A search brought me to your log, which I have read every evening before going to bed. You may have noticed from the "likes" you started receiving for posts made a couple of years ago :) Congratulations on your build, she is a masterpiece and something for all of us to aspire to. And thanks for sharing with us.
Regards, Keith
well done masting and rigging Ray,
Your "HMS Diana" ist a beautiful model
Nils
Current builds
-Lightship Elbe 1
Completed
Spritsail Yard
I decided the next job would be to fit and rig the spritsail yard,this has now been completed with photos below. My next job will be to add the fore ,main and mizzen braces, again leaving the gaffs and the the tac sheets for access, also at some point soon I will make up the ships boats,most likely after the braces.
Ray
 Completed  HMS Diana
Greetings Ray
Excellent work throughout your build, and now lots of cracking rigging work. I have only just purchased this kit and got as far as dry fitting the bulkheads. Yep your build is something special. Keep enjoying it . DAVID
Lower stun sail booms
One other outstanding job was to make and add the lower stun sail booms, the plans and instructions are rather sketchy on these, so a look at the box photos sorted out the main mast ones,but it does not show them fitted to the fore mast but they must have been fitted and a look in R P S M shows them hooked into the hull,the kit supplies enough brackets for four booms so I just lined up the fore mast ones with the yard, and added them the same as the main mast one.
Ray
 Completed  HMS Diana
I love what you are doing with your model, Ray. Rigging looks nice and neat. And the combination of painted and bare wood looks fantastic - I have always liked that look. It is for this reason I am steering away from the Agamemnon/Victory (too much paint hiding that lovely wood) and towards something like Diana.
Regards, Keith
Braces
The braces were rigged next the fore main braces were rigged as per Pegasus and R P S M which runs through blocks fixed the the rear of the top not blocks around the lower mast. The rest of the braces other than those from the mizzen rigged to the gaff have also been added.
Ray
 Completed  HMS Diana
Gaff & Booms
Time to add the Spanker boom and the Gaff boom,again the supplied rigging drawings are sketchy and difficult to follow,so I decided to rig the booms as per L Petersons R P S M which is my rigging bible I highly recommend this book which can be  purchased for around £25.The booms are now both rigged and the last of the braces which rig into the booms have also been added. One thing that will to be attended to is re-tensioning some of the rigging, but I will do this when the rigging is completed,the only rigging remaining are the tac sheets,and then just the dummy rope coils and a few odds and ends.
Next job ships boats or the stand.
Diana as she is now starting to look the real deal
Ray
 Completed  HMS Diana
Just stunning Ray. Your ratlines are some of the best I have seen. Everything looks so clean and crisp.
Tim
Tim
Current build:  Syren
Past builds:    Continental Navy Frigate ALFRED (build log & Gallery)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         Lobster boat RED BARON (Build log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
Thanks for the many ticks and comments guys, I have been working on the ships boats they are turning out to be little mini builds on there own, so I will update the log soon and go through the builds rather than just one update on them all.
Ray
 Completed  HMS Diana
She's a real feast for the eye's Ray, wonderful.
Be Good
mobbsie
mobbsie
Next Build :-
Ships boats
I decided the next job was to build the four ships' boats,I started with the smallest one, the 18ft cutter, this was to be my first real build of a ships boat, as the ships boats on Pegasus were hulls I fitted out. Again the kit drawings are a bit basic, so using the boat kit as a starting point, I built the boats adding detail from The Anatomy of ship Diana s  drawings, off the ships boats and will hopefully, using the experience gained on the first one built, be able to build, the others even more closely to the books boats. ( below is a photo of the the kit plan for the 24ft cutter and the plan from the book)
The cutter hull build went OK double planked with some 4mm x .5mm timber I already had, I made sure to overlap the joints of the first planking with the second planking to add strength (after a little bit of filler to the the first planking), the frame tabs were then broken off and the hull sanded inside and out with only a tiny amount of filling required, I then planked the bottom inside, the A O S Diana shows fore and aft gratings, so some wooded packs, and a plastic moulded one were ordered, they were both way too thick, so I cut the shape for the aft one from the plastic grating, and then reduced its thickness, and it looks fairly good,next the internal frames were added using plastic strip and painted yellow ochre, and the the seats added, the wash strake next, again from plastic, and the row-locks were then filed out. The tiller was again made from plastic sheet with the hinges added and lastly the tiller arm, the outer hull was then painted, on the 18ft cutter a green band waqs painted, and the rest of the hull satin white. Lastly the anchor, boat hooks, ropes and oars were added for effect, overall I am pleased with this cutter and hope to improve my small boat building on the other three, and I have made a start on the next boat whilst waiting for coats of paint to dry on this one.
Kit plan and the plan in A N O S Diana ( these are the 22ft cutter)
first planking
2nd planking
keel added
grating
wash strake thwarts & grating
Painting
tiller
Completed no fittings
Completed cutter fitted out
Ray
 Completed  HMS Diana
Hello Ray,
Your treatment of the ships boats is inspirational, I am keeping copies of each step of your log for when I start on Diana.
Thank you for providing such detailed information on a very competent build.
Regards
Gary
That is a sweet little cutter, Ray. It looks great.
A beautiful cutter to enhance a beautiful ship.
Well done Ray
Be Good
mobbsie
mobbsie
Next Build :-
beautiful work Ray,
I`m also curious on the other boats your yard has an build order for, as you said....
The HMS Diana is a fantastic and well built model..
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Ray,
The boat looks great. Who did you order the plastic grating from and what size was it? CMB has wooden grating in various sizes.
Look forward to more posts,
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Hi guys thanks for the coments and ticks.
Nils the other boats in the shipyard are a 24ft cutter which is nearly finished (photos soon), a 26ft launch and a 32ft pinace.
Mort the gratings are Amiti A4328 100x40mm hole size 1.5 mm to my mind they look very good at this scale as mentioned in the log they are too thick but with care can be thined down. I obtained mine from Cornwall Model Boats.
Ray
 Completed  HMS Diana
Ships boats 2
The next boat to be built was the 24ft cutter, which was built the same as the 18ft one again it was a mini build and again towards the end I have started the next boat. I am also very pleased how the boat has turned out and looks nice with the blue painted band, and quite workman like with added oars,anchors,ropes,boat hooks,and barrels.
Frames and  keel clamped
1st plank
1st planking and filler
2nd planking
planking done and false keel added
inside hull prepared
deck & grating
inside painted
inside fitted out
wash strake & rowlocks
painting
tiller
Completed cutter
Both 18ft and 24ft cutters
Ray
 Completed  HMS Diana
The next boat to be completed is the 26ft launch built as the other two plus some photos of all three only the pinace to do now as before the early stages done but on holiday for two weeks from Sunday so they should all be completed by the end of the month.
Keel & frames
1st planking
2nd planking
false keel
inside ribs
decks added
seats
row locks & winch
tiller
painted
tiller added
inside fitted out
tiller inboard
three finished boats
Ray
 Completed  HMS Diana
NIIIIIIIIIIIIIIIIIICE, some very smart little boats there Ray.
Well done mate.
be Good
mobbsie
mobbsie
Next Build :-
