Blue Ensign
Posts posted by Blue Ensign
  1. Thanks Tom, but it's only for my personal interest, and I know who I am ;) :D
    Hi Dirk, I paid £72.00  for the maximum number of pages (120), the basic album is (24 pages)
    It would have cost me not far short of that in printer ink to do it myself on my inkjet, and without the professional binding.
    Cheers,
    B.E.
  2. As I mentioned in an earlier post,  I have used some of my post build time to create a Photo Album of my build utilising some of the many photo's taken over the course of the build.
    The album is large format (28 x 21cm) and runs to 120 pages.
    The book has now arrived and I thought you may like to see how it worked out.
    The book was designed and created from software downloaded from Vistaprint.  who then produced the Album.
    Here's are a few pages to give you a glimpse of how it looks.
    In reality the photo's are far better than may appear on this post, and it's nice to have a record outside of a computer to look back on a build.
    Regards,
    B.E.
  3. Gluing the Bulkheads
    My approach to gluing the bulkheads is to start with the centre one (0) and then work sequentially aft and forrad.
    6804
    To get the important first bulkhead set square I use a mini level and Engineer squares.
    6805
    In addition to vertical planes the square is also used to check that the Bulkheads are square to the keel.
    This will be the benchmark against which all the other bulkheads will be lined up.
    6810
    Each bulkhead in turn is checked with square and level until all are in place.
    6812
    I also set up a separate keel support base so I can turn and eye-sight along the frame tops.
    Well that's the easy bit, progress will inevitably slow as I get into the build proper.
    B.E.
  4. Thanks Guys :)
    The beginning
    Being an American kit all the measurements are in imperial measure whereas we in the old country are now used to the metric system particularly in relation to ship modelling, although perversely I still think in terms of feet and inches, pounds and ounces,  Pints and Gallons etc; in relation to other stuff.:rolleyes:
    The first job is to thin down the false keel from the bearding line and form the rabbet along the keel and up the stem to take the planking.
    The thickness of the false keel is 3mm and it needs to be reduced to around half to form the rabbet.
    6767
    I have used a strip of 1.50mm wide styrene strip temporarily pva'd along the keel to provide a guide to form the rabbet.
    6777
    Once the false keel has been fettled I firstly glue the stem piece using pva.
    6789
    I think it is easier to centre this short piece onto the false keel first, and then line the keel up to it. The scarf also helps hold the long keel piece in place.
    6800
    With the keel in place it is time to make a temporary working stand. Not very pretty but it will do the job.
    The Bulkheads are easily removed, and are a good fit, maybe just a tad tight once the glue is applied, so a very fine sanding of the notches  to ease their passage will be done.
    6797
    6798
    Dry fitting the Bulkheads, no issues with the bulkhead centres, so I will proceed to fettle the notches and start assembly.
    B.E.
  5. My Pegasus build was my last foray into the world of 1:64 scale Square Rigged ships.
    My future projects will consist of larger scale models of smaller vessels.
    Chuck's beautifully designed kits of the Pinnace and the Longboat fall perfectly into this category, and the Pinnace will be my new project. I used the Pinnace plans to produce the reduced scale scratch versions for my Pegasus build.
    It has been some six years since I last planked a hull and I'm feeling quite ring rusty, so I will have to do some serious revision of the art.
    Not quite decided as yet whether to go with the provided Limewood, or upgrade to Boxwood
    There are some excellent Pinnace builds on MSW as well as Chuck's own exemplary build, and I am grateful to the work of Mike Y and MikeB4 whose logs I will browse to assist my own effort.
    May be a while before I have anything to usefully show, but here's the 'mini' version as a place holder.
    Cheers,
    B.E.
  6. Ray what are you doing, I presume you are getting some satisfaction, or why do it, but I find it hard to imagine what image you're seeing from the fruits of your labour.
    I have to tell you that this is not wooden ship modelling as would be recognised on even the most generous of assessments.
    If you have a genuine interest in the subject I think you need to start with the basics of planking a model, and there is a tutorial for beginners on MSW.
    here's the link.
    http://modelshipworldforum.com/resources/Framing_and_Planking/plankingprojectbeginners.pdf
    if you can grasp the principles of fairing a hull before planking, and tapering planks to better fit the hull, you will be on the road to making a half decent model, and hopefully gain far more satisfaction.
    Members are very generous with help on the forums, but they need to see that an effort is being made to understand how to construct a wooden kit model.
    I'm sorry if this sounds harsh, but you're going nowhere in the hobby with your current approach, and I suspect many members are at a loss to comment on your log.
    My advice would be to get a simple beginner kit to hone your skills on, using the tutorial above.
    B.E.
  7. A fine, fine, model Peter, love the look of the boats on the Davits.
    How lucky is your friend to be the recipient of such a  handsome gift.
    I think she will as all models do look better out of a case, and she is of the style that could be kept clean with periodic dusting - easy access and limited rigging.
    Well done Peter :)
    B.E.
  8. Hi Michael, your Masthead and shrouds look great, and I know where you're coming from being attracted to  interesting little rigging exercises, I'm prone to it myself.:rolleyes:
    I don't know if it's perspective from the photo but the blocks look a little oversize for the Catharpin rigging to my eye, and I see that you have used a triple block rather than a deadeye in your trial, both Anderson and Lees show deadeyes, unless I'm missing something.
    Lees has a good drawing of the English setup on page 43 of his Masting and Rigging book.
    It seems to me that the falls between the blocks could be rigged off model (set the appropriate distance apart) and the line made fast around itself. The Catharpin legs can then be secured to the shrouds and rigged thro' the deadeyes, maintaining and controlling the tension.
    There seems to be  sufficient doubt about both fitting and style for anyone to really gainsay you whether you decide to fit or not, but it would be an interesting little feature on your Vasa.;)
    B.E.
  9. The casing of Pegasus took place yesterday, one of the most stressful operations since constructing the Headworks.
    Slipping the cover over Pegasus with only a few mm clearance each side of the Main Studding Booms ends and Jib boom was scary to say the least.:o
    Still all done now, and here she is in her designated place.
    Moving on now, to what not quite decided. :)
    B.E.
  10. There was usually a Rudder Coat fitted to prevent ingress of water thro' the counter.
    The Rudder Coat was a loose fitting bag like cover made of tarred canvas nailed to the rudder head and counter. Tricky little beggars to make at model scale but you will find examples around the model builds.
    Where the Rudder head came thro' the deck another small tarred canvas cover would be secured around the head and to the deck to reduce any water ingress to the deck below.
    The photo's below show the arrangement I used on my Pegasus build.
    Rudder coat in course of fitting.
    Canvas cover around rudder head, on Pegasus an additional cover was built over the rudder head to further protect it.
    B.E.
  11. Hi Ken, I upload photo's directly from my computer photo files, and they appear along the bottom of the log entry I am making. You can do this for all the photo's you wish to include in a particular log entry.
    I type in the blurb for the log, and then move the cursor below the line of print and click on the photo I wish to select which then appears in the body of the log.
    Again move the cursor below the photo and begin writing again in the body of the log, and so on.
    Hope this helps.
    B.E.
  12. Thanks once again Guys, there will be one more photo - when she is encased and placed in the spot reserved for her.
    In the meantime I am using the huge collection of photo's amassed over the past seven years to put together a large format 120 page photo book record of the build.:)
    Regards,
    B.E.
