Hi Martin, good to see you start on Fly. I did the same as Alistair and simply scored the scarph lines into the kit stem, there are a couple of them that show above the copper line. It's not too difficult a job to open up the stern cabin and I think it is well worth doing, the same applies to beneath the Fo'csle deck. One thing I would do differently is to modify the first gunport which should really be a Bridle port, somewhat narrower than in the provided pattern. The fffm books are well worth getting, Vol 11 is particularly useful for the kit basher as it contains a lot of detail on fittings which enhance the basic kit. Vol 1 also has useful information for the kit builder but also covers the early build stages for a pof build. I have all four volumes and I have used them all as references for my build. Cheers, B.E.
- 467 replies
- fly
- victory models
Hi Mark, using Chuck's bulkhead frame system I also found reducing the thickness of boxwood frames @1:64 scale to less than 1mm made them too fragile. I am making the ones for my Pinnace from 1.5mm thick sheet but will them sand down to 1mm. Once insitu and held by the planking I may be able to reduce the width a little more, but getting down to around 0.5mm is a tall order. I am very interested to see how you get on with your boats. Speaking of French boats, it seems eminently sensible to build them to nest, unlike the British Navy where there were far more sizes and shapes most of which were unsuitable for nesting. On the other hand it must have been a hell of an exercise to get at the Longboat having to remove the cutter and Barge first. Cheers, B.E.
What a beast, don't fall inside her Andy we'll never get you out I think you'll need a mortgage just to buy the paint for her. Can't say it has the same appeal for me as ships of the Eighteenth century, but an interesting project all the same, and almost certainly a unique one here on MSW. I'll be interested to see how she looks in her finished state. Cheers, B.E.
- 382 replies
- stadacona
- sylvan scale models
Is it too late to retro fit a spider band? made in two halves around a piece of dowel the same size as the mizen, pre drilled for the belay pins and glued into place around the Mizen; maybe there's something I'm missing but I'd have thought it feasible for a modeller of your ingenuity and skill Grant. B.E.
Very nice work mobbsie, the snaking looks impressive... but.... Thanks to B.E. this is his method, I got to this spacing after some simple maths, 12mm on each Stay or 6mm combined .I may be having another senior moment, but are you sure it's me you're referring to, I can't for the life of me think I've posted anything about snaking. I'd hate your thanks to go to the wrong person. B.E.
- 1,279 replies
- agamemnon
- caldercraft
A fine looking model Mike, great job on the sails, I'd be proud to display her in my home, very well done indeed. B.E.
- 153 replies
- badger
- caldercraft
Mark, this is what Boudriot has to say about the boat stowage on his 74 gun ship books. The Longboat rests on boat chocks or small cradles of fir, fashioned to the shape of the lower part of the boat's hull; the first chock is placed abaft the forward ladderway, whilst the second butts against the coaming of the main hatchway. The Longboat is stowed so as not to get too much in the way of the forward ladderway, or the running rigging belayed to the main-topssail sheet bitts. Looking at the inboard profile plans at 1:72 scale the keel of the Longboat rests about 2mm above the deck when sitting in the chocks which would equate to no more than 6" clearance to the deck. Boudriot also shows plans for a Longboat, Barge, and Cutter, I have read somewhere but can't bring it to mind at the moment, that live sheep were kept in pens beneath the boats which would perhaps indicate the chocks being higher to give more clearance. I did in fact include sheep in pens beneath the Long Boat on my small scale French Seventy-four build. B.E.
PROXXON DSH 2 SPEED SCROLL SAW – REVIEW.
Blue Ensign replied to Blue Ensign's topic in Modeling tools and Workshop Equipment
Following the above, I found a sheet of acrylic and taped it to the table, what a difference in smoothly moving the work around the blade. The much reduced access hole for the blade was also of great benefit in relation to the small pieces I'm cutting out. Thanks again Intarsiabox, for the tip. B.E. -
Well done Martin, she's an attractive build, and such projects are priceless in the experience and confidence they afford us. I have enjoyed your log and your self deprecating humour, and look forward to the great Fly adventure. Presumably you've informed Bounce of new work to be started in the shipyard M.
- 104 replies
- rattlesnake
- mamoli
canvas cabin roof
Blue Ensign replied to timo4352's topic in Painting, finishing and weathering products and techniques
Tim, I use self adhesive micro-porus tape to simulate canvas coverings on small scale models , it has a very slightly textured surface that shows up when painted a suitable colour. B.E. -
I've been well blessed with seeing some wonderful builds progress when I got up this morning Augie, and yours is no exception B.E.
- 2,191 replies
- confederacy
- Model Shipways
I can't add more to the praise given above Bob, suffice to say I love following your build B.E.
- 1,477 replies
- essex
- model shipways
What an excellent 'how to' and what a fine result Michael, well done B.E.
- 2,215 replies
Nice work Peter, she's starting to look busy now as the rigging progresses. Love the Ensign, great natural looking hang you've achieved. B.E.
- 431 replies
- pegasus
- victory models
Love that Starboard quarter shot of Wasa Michael, what a class build she looks. I'm with Nigel on the 'faffing' about trying to make stuff when I can get a quality bought in product, ropes and blocks are a prime example. 'Faffing' is alive and well in these 'ere parts, but then I'm not far from Nigel B.E.
Hi Martin, I love the close-up shots of the gaff and the iron horse, and the rigging is coming along very nicely. Those knot tails are a nuisance, have you thought of using the 'false' splice as shown by Gil Middleton in his Victory build? you can trim really closely and you don't get the problem of tails. Photographing rigging is a pain but you have answered your own question to an extent; avoiding background clutter is always a good idea, and having a plain coloured sheet behind the shot helps. I use those large coloured boards you get from art shops, a sort of dusky blue colour is my choice, you can see where I've used it in my log for those shots where I've taken the trouble to set it up properly. Cheers, M.
- 104 replies
- rattlesnake
- mamoli
A great looking hull you've produced Augie, the understated finish harks back to those fine contemporary 18th century models, I like it very much. B.E.
- 2,191 replies
- confederacy
- Model Shipways
Thanks guys I'm glad you like the review, and I hope other novice users who may be contemplating buying a scroll saw will find it useful. and Mark and Intarsiabox, thanks for your insights; great tips about waxing or covering the table to assist free movement of the work, I did find particularly with the very thin sheet I was using there was some resistance to free movement around the table. @Yambo - there isn't a ledge to fit an insert in the blade hole which measures 25mm long x 10mm wide. It wasn't too much of a problem except with the very small bulkhead frames. I like the idea of acrylic sheet taped or clamped to the work table top. Will give that a go I think. Cheers Guys, thanks for responding. B.E. -
PROXXON DSH 2 SPEED SCROLL SAW – REVIEW. This is the second of my recent new toy purchases, and this review as with that for the Band Saw is written from the point of view of a user new to these machines. Unlike the Band Saw there’s no picking this up with one hand, it is a hefty piece of kit with a solid cast base weighing in at 20 kilos. Actually screwing it down seems superfluous; in my use thus far on a non slip surface it stays where you put it. I again purchased the machine from:- http://www.tbs-aachen.de/Proxxon/table_top_tools/scroll_saws/Proxxon_28092_2-speed_scroll_saw_DSH_i2477_42308.htm Excellent service, ordered on 26 February, delivered on 28 February and again with a significant cost saving over the UK equivalent supplier. Setting up The machine was pre fitted with a blade and to get it up and running only required tilting the table to horizontal, and fitting the suction nozzle. A check with the spirit level and square ensures everything is ok. The machine comes with five spare blades of coarse and fine each. Changing the blade was simplicity itself, both pinned and pinless blades can be used, but so far I have only used pinned blades. I found it much easier than the band saw to get the right tension on the blade. A non flat ‘ping’ when plucked indicates you are there. There is a clear plastic blade guard which clips into place. This way for protecting the blade when the machine is not in use. This way when working the machine. A little more fiddly getting the guard into place in its working mode. It is spring loaded in this position intended to also act as a foot to help hold the work piece to the table. I thought the instruction book somewhat vague on setting up the guard but it gave dire warnings about using the machine without it. Please note that the saw blade guard is an important safety tool and the saw may not be operated without it but then goes onto say that: The following describes activities in which the guard may be disassembled expediently but it must be clearly noted that the guard must be mounted again when this work is complete. Operation without this important safety accessory is not permitted. In my opinion the guard is a severe impediment to effective working, with very small pieces being too large to allow for the necessary close handling. I looked at quite a few You tube videos concerning the use of scroll saws, some which were of great help. This one is quite misleading. Supposingly an educational video, it makes great play of safety but shows the blade guard fitted the wrong way up, resulting in trying to work the piece from the side. Using the machine. A good sized table, certainly more than adequate for the sort of modelling projects I have in mind. The machine runs very quietly on low setting and is only slightly more noisy on the high speed setting. I was keen to see how it would handle cutting out 1:64 scale Pinnace frames for my prototype practice build. I would not be able to cut a frame like this with the guard in place. I am using stiff card for the frames, so not much of a challenge to the blade. But the idea is to practice the scrolling. This is one of the smallest frames, fits inside a 5p piece. With the guard in place it would be impossible to get close enough to support the cut edges whilst scrolling. With such small pieces you need to work out how to approach the job as your fingers get perilously close to the blade at times. Frame cutting progressing.... There is a blow nozzle to keep the work piece free of dust whilst scrolling, but it didn’t seem to have much blow in it! The vacuum attachment is at the rear of the machine, the quietness of the machine is negated once the vacuum is switched on. The large knob is used for tensioning /releasing the blade, the allan tool for removing the blade is clipped to the side of the machine. There is a narrow tray for holding spare blades. Moving the machine around Unlike all the other Proxxon modelling machines I have, the weight of this machine really dictates that a designated place for storage/working is the best option. Whilst I can use the Mill, the wood lathe, and the band saw on my desk, and then store them away, I really don’t fancy lumping this around particularly with my slightly suspect back; the heavy cast base would cause serious damage if dropped, whether to toes or tiled floors. Verdict. Costing around £134 this is a lot of machine for your money. Seems well built and is smooth running, maybe not as portable as some other modelling machines, but certainly a useful addition to the modellers workshop. If space and portability are important and light small scale scrolling is the requirement then the much smaller, cheaper, and significantly lighter DS230E model may suit. B.E.
Nic shots of Snake Jason, I like the look of models with just the lower masts and standing rigging in place. The ratlines look good to me and your clamping arrangement should also help guard against pulling the shrouds out of line. B.E.
- 800 replies
- snake
- caldercraft
Nice progress Lukas, she does look good on the water. Glad my effort has helped with your build. B.E.
- 110 replies
- heller
- le superbe
