Blue Ensign
  1. Impressive Mark, a good point to finish the year on, look forward to your progress in 2014. Best wishes for Christmas and the New Year, we three are also having a quiet Christmas, and I suspect I will be sneaking off to my office at times for a bit more fiddling with Pegasus. B.E.
  2. The thing about the False Rails Peter is that as they just sit on top of the Main rail they can be added later, just need drawing out on a bit of thin stuff and shaping.. The Bumkins are just a length of tapered dowel that I soaked and curved using my fingers. I haven't fixed them yet, will leave that as late as possible. B.E.
  3. False keel looks good Bob, and I'd be very pleased with the coppering. B.E.
  4. Hi Robert, The Training tackle eyebolts were introduced post 1779 and one was placed centrally between each port on the same line as the Port tackle eyebolts. The diameter of the metal used in the ringbolts/eyebolts ranged between ½” (loops on carriages) ⅞" (Ringbolts) and 1" Breeching ringbolts/port tackle eyebolts. 0.2 - 0.4mm at scale. The wire obviously needs to be robust enough not to pull out of shape when tackles are attached, the commercial stuff I used was of the order 0.4/0.5mm in diameter. B.E.
  5. Hi Robert, as per our recent conversation, I see that Mars was equipped with 6 pounder guns, as was Pegasus, so I can provide you with some details for those. Fittings on the ship. Breeching ringbolts in bulwark These are 5”ø overall = to 2mm at scale. I used Amati 2mm brass rings for this purpose clenched in a modified 2mm eyebolt; the eye reduced in size and squeezed around the ring. Port Tackle eyebolts in Bulwark 2¾” ø overall I used Amati fine 2mm copper eyebolts, reduced slightly in the size of the eye, and set above the Breeching ringbolt in the bulwark. Training Tackle eyebolts in Bulwark These were used when traversing the gun left or right Same size as the Port Tackle eyebolts, Relieving Tackle ringbolts – set in the deck opposite (or nearly) each gunport. 3⅞” overall diameter =1.54mm at scale. I used Amati 2mm brass rings for this purpose clenched in a modified 2mm eyebolt; the eye reduced in size and squeezed around the ring. Note: on Pegasus some of the larger stopper bolts do double service also acting as tackle bolts. Fitting on the gun carriages. Breeching ring bolts – 3⅞” overall diameter =1.54mm at scale. I used Amati 2mm brass rings for this purpose clenched in a modified 2mm eyebolt; the eye reduced in size and squeezed around the ring. Gun tackle Loops - 2” overall ø = 0.8mm o/a I used Amati fine 2mm copper eyebolts, reduced slightly in the size of the eye and countersunk a little in the carriage to look like loops rather than eyebolts. Gun breeching rope 4” circumference - scaling to 0.50mm dia line. This looked a little thin to my eye so I used 0.7mm diameter line. Gun side tackles The gun tackles were fitted with 1½” circumference rope which scales to 0.19mm ø line. I’ve used Morope 0.15mm ø line which is pretty close and provides a nice size contrast with the breechings. Side tackle blocks The blocks are around 6” = to 2.38mm. I used 2mm JB Pearwood blocks, but I reckon Chuck’s 3/32nd single blocks would be just about right. I see from your build log that you are using Chuck’s 12 pounder barrels masquerading for the six pounders. Six pounders did come in different lengths and I used RB 32mm guns for Pegasus. I have examples of Chuck’s six pounder barrels and I also thought they looked a little undersized for Pegasus. The Twelve pounder barrels are very similar to RB’s 32mm in diameter, but are longer by 5mm, equating to a 7’ 9” barrel which is still within the six pounder range. Twelve pounder guns incidentally had a breeching rope of 5½” circ. (0.7mm) which is what I actually used on Pegasus. The tackles were of 2½” line (0.3mm at scale) but I only used line half this thickness. I provide the above as a guide, but as with all things items don’t always look right with direct scale reduction so let your eye be the final arbiter. Cheers, B.E.
  6. Hi Peter, On the model the Bumkins are forced into that position by the absence of a 'False' Rail atop the Main Rail. The Bumkins should sit in a cut out on the False Rail, secured by a capsquare. I re-made the bumkins and imparted a slight downward curve in them whIch serves to reduce the sharp downward angle you otherwise get. Glad to see you're back on the build, the rigging is coming along very nicely. B.E.
  7. There is a useful book for those building Warrior - Building a Working Model Warship (HMSWarrior 1860) by William Mowell. Available from the HMS Warrior Trust. http://www.hmswarrior.org/supportus/mailorder B.E.
  8. The stern post face should really be coppered. One solution is to use self adhesive copper tape scored to the plate size and marked with one of those little wheels that simulate nail heads. Being very thin it doesn't show much of an edge, as in practice the copper plates were bent around the stern post and lipped over the plates that run down the stern post not just butted to the adjacent plates. I did this when I coppered my schooner Pickle. Copper tape is also useful to cover the recesses in the rudder where the pintles fit. Cheers, B.E.
  9. Hi Bob, my false keel was if anything a little undersized. It should be 4" deep - at scale 1.58mm, but I went with around 1mm. which looked ok to my eye. I have had a look at the dimensions given for Bellona (AotS series book) and this is 7" deep - 2.78mm at 1:72 scale. The False keel will need to be chamfered down towards the fore end to meet the gripe of the stempost, that is the curved bit at the bottom that fits against the keel. I think you may need to trial a depth of timber to suit Vanguard, you can always laminate some of the strips you have to build up a depth, and the lengths can always be joined or scarphed if you're up for it. B.E.
  10. Nice job with the decorative strips Michael, I'm pleased you are enjoying the Mill. Thank you for your very generous words about my use of the Mill, but like you I'm very much a beginner. However, I think it is useful to show pics of what we do on the Mill, even at our superficial level it gives a lead to others who may be just starting. Good idea of yours to use the balsa support for the strip whilst milling. Cheers, B.E.
  11. Hi Bob, a fine job you've done on the coppering. Not much can be seen of the false keel with the model the right way up, but basically it was a strip of wood nailed to the bottom of the keel to protect the copper in the event of the keel grounding. I fitted one to my Pegasus. It was just a thin strip of timber slightly narrower than the keel width ca'd to the bottom of the keel. I didn't go to the trouble of scarph jointing the false keel but just used a continuous strip. It obviously needs to be done whilst the model can be inverted. Cheers, B.E.
  12. Nice job on the first planking Richard; I'm interested to see your gunport cutting thro' to completion and hear your views on the plank/cut method compared to using the provided gunport patterns. B.E.
  13. You surely have moved along since I last looked in Bob, very nice progress, those ports and inboard planking looks excellent. B.E.
  14. Hi Jason, nice work on that serving and stropping. The Burton Pendants were important bits of kit used to attach tackles for heavy lifting and ideally they should go over the masthead before the shrouds are rigged. As far as gluing the masts in place I tend to only apply a small smear of glue, which is good enough to hold in normal handling but in the event of a catastrophe I can ultimately twist them out. This has happened to me in the past. As far as bunt and leech line blocks are concerned either on the yard or as feeds beneath the top for the lines, my view is even without sails they should be fitted, even if the actual lines are omitted. A lot of the running rigging was taken down with the sails, but for those to wish to show it a common practice is to knot the bunts and leech lines which would otherwise be attached to the sail cringles, where they pass thro' the yard blocks and then having passed thro' the feed blocks belay them at the appropriate point. That's what I intend to do on my Pegasus. I can relate to what you say about becoming obsessive about the rigging detail I seem to be sucumbing to that somewhat as well. Cheers, B.E.
  15. That’s a given Danny, I was obviously referring to the open ports, which on the model are the ‘show’ ports. The question of 'run in' and secured or secured 'side on' is interesting given the small space on a Swan, particularly in relation to those adjacent to the Galley Stove and those within the partitioned Captains bed space and Coach. The latter is not an issue with Kingfisher and other 14 gunners as the ports did not house a gun. B.E.
  16. I got my replacements from RB Models. Here's their website and also one for Radek ship models. http://www.rbmodel.com/index.php?action=products&group=011 http://www.radekshipmodels.cz/en/list-of-kits-and-accessories/accessory---armoury When you've worked out the scale length of your guns, you might just find suitable replacements. Cheers, B.E.
  17. Beautiful work on the head Matti if you can work out the scale length of the guns you may find some aftermarket brass ones that would suit, or be close enough. That's what I did for the replacement guns on Pegasus as the supplied originals were much too big. Cheers, B.E.
  18. I’m not entirely sure that that is the case. There were different levels of securing the guns, and there would no doubt be differences between the heavy lower deck guns with port lids in place and lighter open deck guns where run out and secured would be an option. This is in fact shown in Seamanship in the age of Sail (John Harland) which includes a chapter on securing the guns. He makes the point that the Upper deck guns were ordinarily secured in the ‘run out’ position and shows the side tackles frapped. On a small vessel like a sixth rate with six pounders, I would suggest that 'run out' with tompions in place would have been logically applicable. B.E.
  19. That's a fine present Michael, and one I think you will make great use of, did you receive the milling bits as well? the standard Proxxon set is 1mm 2mm and 3mm bits, but they also do a smaller range in 0.6mm 0.8mm. B.E.
  20. Nice start Richard, looking forward to seeing how this one develops. B.E.
