Great fix job on the cathead sheaves, and I do like the look of your carronade Jason. B.E.
- 800 replies
- snake
- caldercraft
Whalers are great subjects with interesting fittings and I like the look of your Morgan John, a fine job on the copper tape. I imagine as hard worked ships they are a good candidate for a bit of weathering if you choose to go down that route. Cheers, B.E.
- 2,250 replies
- model shipways
- Charles W Morgan
Neatly done Andy, looking good, are you leaving the shroud seizings natural? Love the Bowsprit attachments, very tidy work, anyone would think you were a sailor with ropework like that. B.E.
- 1,148 replies
It must be very frustrating not to be getting the satisfaction from a build time after time, also for those who get interested in following a build only to find it abruptly ends. This one did look interesting and you look to produce a very nice finish to your work Arjan, I do hope you find a project that sustains your interest thro' to completion. B.E.
Very nicely done Frank, a great paint job, love the detail you've picked out, particularly on the shirts. B.E.
- 389 replies
- supply
- caldercraft
Nicely done on the Bowsprit rigging hamilton Re the lanterns: for kit provided stuff they don't look bad for style and six sided is good for the period, presumably they are solid metal? The real thing would probably have been made of metal but painted to represent wood, so you could paint it a sort of yellow ochrery colour to tone in with the model. The glazed areas could be painted appropriately and perhaps finished in a high gloss to reflect light. I am currently trying trying to make something of the Pegasus lantern and I am using the Caldercraft 1:72 Victory stern lanterns.They come in three sizes and if you wanted to go for etch rather than solid the smaller ones may fit the bill. The main central lantern is 23mm h x12mm dia. the two side lanterns are 21mm h x11mm d. and theTop lantern is 16mm h x 8.5mm d. The down side is they are somewhat out of period being Octagonal in shape. Just a thought . B.E.
Neat job Ray, and at least some of the Top and Butt on the Upper deck is still visible. Regards, B.E.
- 536 replies
- diana
- caldercraft
An interesting project Kriss, I think I'm going to like your approach to it. At 1:150 scale most detail can be included, full rigging, even the side tackles to the guns can be simulated. Helps if you've got young eyes and nimble fingers tho' The finished model size fits easily in a domestic setting and even when cased is not too obtrusive, it is a scale I've great affection for. Look forward to following your progress. Cheers, B.E.
Hi Ferit, I've looked at contemporary models and many of the drawings of ship of the period by the Van de Velde's and they all seem to have enclosed channels. The great authority on the subject is Dr R.C. Anderson who writes in his book The Rigging of Ships In the days of the Spritsail Topmast 1600 - 1720. - Deadeyes in the period 1650 - 1720 (and afterwards) were set in slots on the outer edge of the channels and covering strips were nailed over them. This appears to answer your question, but if you like the look of the exposed strops, then you could leave them off for demonstration purposes. Afterall they were only battens nailed on the edge of the channel. Regards, B.E.
Wonderful work Matti, that last shot shows off her sheer lines beautifully; love the colour you have achieved on the stern and topsides. I think you are a 'natural' at this game B.E.
I worked out all the upper masts and yards relative to the correct proportions, as given in Steel, it all starts with the Main topmast relative to the overall true length of the mainmast. For the Main mast I then allowed an extra length at the presumed partners where all the quartering and tapering starts, and then added the actual length of dowel below decks to fit the kit arrangement. The Fore and Mizen masts followed the same procedure and proportions relative to the Mainmast. This gave me the leeway to make final adjustments from the bottom of the masts to suit my eye. From the one reference I had in the Swan book relating to the Foremast the drawing would suggest from an overall length of mast of 56' with just over 19' below the partners to the keel. This left 36.75' or 175mm at scale, looking far too short in relation to the model. My actual length which sits well with my eye is 242mm which has it happens is only 6mm longer than the kit plan! rather annoying really. B.E.
My edition of Lees is the 1984 revised edition and runs to 212 pages. No matter all the relevant information is in the Goodwin book. The main problem I had, in relation to Steel in my case, was working out the below decks lengths, which in the kit are not true as the masts sit in the false keel and bear no relation to actual lengths between the keel and partners at the Upper deck level. When I took a scale deduction from the one drawing given in the Swan ffm book the mast seemed to come up far too short above decks so for this reason I left the masts over long to start with, and used mock ups to judge the final height. B.E.
I have a Proxxon MF70 and have no trouble using cutters down to 0.6mm for slotting etc; I use my mill primarily for wood also. B.E.
Hi hamilton, the dimensions given by Goodwin in his Blandford book are the same as given in Table 5 of Lees relating to the 1719 Establishment (p196) ie 68' 6". The figures given on Table 8 relating to the 1773 establishment (p198) are 67' 11". as near as makes no matter. If you look at Section G in the Goodwin book you will see he gives the length of the masts below the partners (taken at the Upper deck level for single decked ships) in the case of the mainmast this is 14' 6" equivalent to 44mm at scale. You are really interested in the height above the partners which is easily calculated. To this you only need add the actual below decks length on your model to get the overall scale length. I would suggest you mock up the lower masts and see how they look to your eye before before committing to the real thing. B.E.
The repair looks good Mark, and I don't think it will be apparent as the build progresses. I would also like to add my sympathy for the loss of your Dog, we have been thro' it four times over the years and it doesn't get any easier. The hurt will ease, and you will be left with fond memories of your time together. Regards, B.E.
Boxwood planking, Holly decks, sounds marvellous, time to get on with it Bob. In anticipation B.E.
- 1,477 replies
- essex
- model shipways
Just enjoyed reading thro' your log Jason, a very attractive build. Now if only I can produce something like that in 1:64 scale, I'll be a happy man Cheers, B.E.
- 58 replies
- model shipways
- 18th century longboat
Blimey Timmo, wonderful work, I agree with Alistair she has all the look of a contemporary eighteenth century model. Just love what you're doing with her. B.E.
- 366 replies
- granado
- caldercraft
Love that last series of deck shots Jason, she's looking mighty fine B,E,
- 800 replies
- snake
- caldercraft
