Posts posted by Chuck
Only the wales.....its a single plank on bulkhead, But rather than use a thicker plank for the wales and molding, those are done in two layers.
Unfortunately you cant base everything 100% from Peterson's book. It is based only on one model. There are countless examples of a cutter from many different time periods rigged with a bobstay. The Surly is rigged with one as the image shows above. Earlier examples had the bobstay go through a hole in the stem. Later they had an iron fitting with an eyebolt attached to the front of the stem so they didnt have to drill through it. This made it prone to rot. The cheerful in the Rogers collection has one.
Chuck
I started the planking today. This always begins with placing battens on the hull. The top of the batten represents the bottom edge of the wales. I really spent a lot of time on these because it will establish the run of all of the planks on the hull.
It was added to both sides so I can check it from every conceivable angle. Once I was satisfied I planked the wales with two strips. This will be the first layer. After I plank the hull from here up to the sheer, I will come back and add the final layer. Its a hold over from my time building kits. I like the idea of being able to make small adjustments with the run of the wales on the final layer. Since it will be painted black and this isnt the final layer it laid down in one long strip rather than in 25 foot long pieces.
Now on most ships you can just start planking from the wales up...the run of the wales determines the run of the planking above it to the sheer. Mostly anyway.
In this case however it isnt true. It is again one of the reasons I chose the Cheerful. Its not difficult work at all but requires careful planning. If you examine the plan for the cheerful you will see the run of two moldings just under and through the gunports. I was fortunate to have the original draft for teh planking expansion and my model will follow it exactly. The same number of strakes and their run are precisely copied from it. The space between this molding and the wales is not consistent. So I decided to add the 1/16" strip first which for the most part runs right under the ports, leaving a 1/64" rabbet along the bottom of each port.
Then I divided up that space between the molding strip and the wales equally so I can taper these two strakes that will fit between them. You may be able to see my tick marks defining the space and strakes on each bulkhead.
The molding strip is just the first layer also....Once its all done I will come back and add the final layer after scraping the fancy profile into it. Once again, having a little wiggle room to adjust teh run of the molding later is a huge plus.
Then its just a matter of finishing the planking and other molding strip as I work my way up to the sheer.
Chuck
Nicely done Dan. Cannon rigging look good.
Chuck
Basically you should taper the bulkhead former a bit more than 3/32' thick at the stern just to be safe. This was my first kit design trying out the rabbet strip concept. From the bearding line to the rabbet strip it should really be a gradual tapering to 1/16" thick. But after the hull is planked it will be a bit thicker than the stern post, so yes, you will need to gradually sand the hull planking along the stern post so it sits flush with the stern post (1/8" wide). Because the planking is 1/16"' thick....its really too thick for this scale. So gradually sanding the finished planking toward the stern post to make it flush will be required. It only need to be done really at the lower corner of the stern post where the keel meets it.
Because the original kit supplied basswood at 1/32" thick couldnt be used as planking material...its real crap and would literally fall apart. I had to substitute thicker 1/16" basswood strips. This means it will stand proud of the stern post and keel by 1/32"
This extra thickness needs to be gradually knocked down to sit flush against the 1/8" wide stern post and keel after you finish planking the hull and add them..
- Mahuna, Stuntflyer and RichieG
- 3
Thank You!!!
Its Windsor & Newton Acrylic Galleria paint from a tube. The color is crimson.
Chuck
You are correct. There would not have been breech rings at that time. But it simplifies the process of rigging them. Have you ever tried to splice plastic rigging line properly? So it was an oversimplification to spare folks the headache when trying to rig the breech line around the button of the cannon as supplied by MS. Especially after a fine paint job. I talked about the decision quite a bit on the original build log for the prototype. Nice catch again and hopefully this log will now serve as the place to get the scoop on that.
Its looking great Augie.
Chuck
- augie, mtaylor and popeye the sailor
- 3
The loose end would indeed be fixed to the shroud itself. Just above the upper block. Think of it in terms of mirroring the way the lanyard is fixed above a deadeye. Its the same thing.
Its hard to see the definition in the lower and upper counters. This can be tricky unless you define it better. Note in the first picture I drew the shape of the counters with lines on the right. But on the left side you can still see a very crisp edge and corners that define these areas. I would take some sandpaper and sanding sticks to your counters and see if you can better define their shapes as shown in this photo. Remember the upper counter (the skinny long one on the bottom in these photos) needs to be a consistent width as it works its way port to starboard. Most folks have a tendency to make it wider in the middle and I can see that happening in your pictures. You can correct this buy working the sand paper across the counters carefully as you fair it more. Remember to try and create hard line breaks between these counters and the sides of the lower counter.
Chuck
Thats the plan Druxey. We shall see how it goes. I think it will work out OK.
Bill,
All laser cutters cut on an angle. You can minimize it a lot but never get rid of it entirely. Basically the laser is cone shaped as it travels through the lense that focus' it. Much like how you would focus the sun through a magnifying glass. So it gradually comes to a point. If you focus that beam so the point ends in the center of the thickness of wood you can minimize the angle of cut but its hard to do.
So its just a matter of focusing well and the,
choosing the proper laser power for that thickness along with the most appropriate speed. If you pick the slowest setting possible along with the least power possible to just cut through the wood, then the Kerf will be as thin as possible......thus reducing the angle.
The angle is always more noticeable on thicker pieces which are few on a model. So I enlarge them by 1% or 2% to compensate. Once the laser char is removed with a sanding stick while you at the same time make a true 90 degree angle the part will be the appropriate size. Its just a fact of life for laser cutters and all kit cut pieces. But you can minimize it quite a bit with practice, trial and error.
Chuck
I managed to finish the skeleton for Cheerful today. So its now ready for planking. The stern framing was pretty standard although the design concept was modified for the square tuck. This is a feature that is rarely shown correctly on these cutters. There are some pretty complex angles. Its hard to tell in the images but the square tuck is not flat and completely perpendicular to the keel. It has a slight convex curve as it works its way from the center outward.
It isnt complete yet. The actual framed square tuck will be added after the sides of the hull are planked. Its probably the trickiest part on the model but I simplified it quite bit as far as the construction is concerned. But when its done it should look exactly like the real thing. Thats my hope anyway. The first image shows the Rogers collection model with its square tuck. The frame around the vertical planking will be added after the hull is completely planked. Then I will fill it in with the vertical planks.
Chuck
Oops I meant earlier......wrong choice of words.
Thank you. Its a tough thing to describe in writing. It is so much easier to demo it. That was a good idea about doing another demo at next years conference. I will talk it over with the guys. I actually did one for my local club members. I just showed them how to prepare the surface and paint a solid color without brush strokes. What brushes to use and how to paint a straight line without using tape.
When I was in college I had to take an entire course in color theory where we had to paint 2" x 2" square swatches of solid color. Th e teacher was rough to say the least. If the painted swatch wasnt completely flat without brush strokes and perfectly even color you would fail. I can only now see where that class had a purpose that was worthwhile so many years later. I had to paint hundreds and hundreds of swatches. Oh the memories of art school.
Anyway, after spending hours cleaning the shop, I had a chance to cut those forward ports. I used a scroll saw blade that I snipped a small length off off. I placed it in my hobby blade handle and used it to cut out the ports. You can see it in the photo. Then it was a matter of refining the sides of the port opening with files and chisels. This was to try and get straight sides and sharp corners.
Then I wanted to do a quick preliminary fairing inboard at the bow. I didnt want to look at that disgusting thick bow with all the laser char as I planked the hull. You can look at earlier pics to see just how thick it was. I used a sanding drum in my dremel to cut down the thickness to around 1/8" thick at the bow. It needs much more attention and will eventually be thinner. But its easier for me to look at now as I work on other areas.
Tomorrow I will start framing the stern permanently. Then its on to planking. You will see how rough and uneven the inboard side of the bulwarks look. I wasnt careful about how uneven the pieces of wood stuck out on that side. As long as they were deep enough to faired later I didnt care. I will take the sanding drum to it after the outboard planking is done and it wont take long to make it all look nice and clean. You can start to see that taking shape at the bow after just the preliminary thin-down. The stern frames are still just taped into place temporarily. You can see how they are let into slots in the two last bulkheads. It makes proper placement a lot easier.
- KenW, Elmer Cornish, AntonyUK and 25 others
- 28
Gesso
Thick milky white base used to coat canvases for painting.
see this link
http://www.art-is-fun.com/what-is-gesso.html
Chuck
- Bill Hime, Mirabell61, PeteB and 1 other
- 4
Hopefully not to confuse the situation, But here is a better image of Cheerfuls stem parts. You are using the outboard plan. This is from the inboard draft. I have seen this arrangement on two other cutters but sadly these details are not shown on most cutter drafts. The Alert is much younger also so this may not even be applicable.
But I wanted to mention how all of the lines on the draft you posted are dashed for these elements. On the inboard sheet however it shows the dashed lines as if they were parts cut for the other side of the stem only. Meaning that the stem was intended to be cut in one piece and the two other elements used for the boxing joint and apron on the other side only. That is ...if I am reading the draft correctly. It seems unlikely that they could find such a large piece to make the stem like that. So I agree with Ed that in all likelihood it depended on what wood they had on hand and probably ended up with a much different "made up" stem that may not have matched any of these choices.
So I simplified it a great deal for my project because I dont find all of these elements an attractive addition to a ship model anyway. Its too distracting and busy. In fact....you never see the separate pieces on almost all of the contemporary cutter models I have seen. The stem is always one piece down to the boxing joint.
Thanks Guys....
Tom, I will bring her to the meeting tonight along with the plans to show our Jersey Club Members. Its bring a model night!!!!
I finished framing the port openings in Boxwood. I used the reference line from the batten to mark to top of the gunport sills. They should paint nicely because they are all boxwood. Unlike the first port which will be cut from ply fillers. You can see it marked in pencil. I am about to cut it out right now. I also laser cut and tested the stern frames. They are not glued in yet. Its just a test and all looks good. It helps make the shape of this little cutter come to life. I will begin permanently framing the stern as soon as I cut those two forward ports. Before painting them I will prepare the surface with wood filler or even gesso to smooth it out. This creates a nice surface to paint on after its sanded with a very fine sandpaper.
- qwerty2008, sonicmcdude, Archi and 25 others
- 28
I have yet to use a full can before having to throw it away. Th e plastic top gets crusty and the poly gets thicker over time. I end up buying a new one every six months. So I am very interested as well.
Chuck
Kevin....look a few posts back. It was already discussed.
Thanks guys, I am glad you are enjoying the process. Yes ....this is the process. Usually any questions are bounced off a few guys and different research aspects are exchanged. I figured it was best to do it publicly so everyone can see the decision making process. Most of it is done. I have only a few things left to decide on....
Chuck
- Ryland Craze, aliluke, Bill Hime and 3 others
- 6
Yes Alistair...that is exactly what a buckler is. I have seen bucklers in many configurations. For example...sometimes a half lid was hinged on the bottom of the port opening and the buckler used only on the top half. In other instances the buckler was full size for the port. They are usually temporarily secured by ring bolts on the inboard side of the buckler and tied off to ring bolts on the bulwarks. Even the same ring bolts used for the breech line of the cannon or the gun tackles.
Also note the vertical planking on the square tuck in that drawing. This cutter has the same based on the original planking expansion. Normally you see the diagonal planking.
- qwerty2008 and mtaylor
- 2
- aliluke, WackoWolf, qwerty2008 and 4 others
- 7
As I am about to start framing the ports, I would like to have a bit of a discussion about the. Please feel free to chime in if this is something you are familiar with. I have seen cutters with and without port lids in paintings and drawings. I am talking about 1800-1830ish. My issue is that I have never or rarely seen a contemporary model or set of plans with port lids. I am already resolved not to show them on Cheerful.
BUT, that leads to my question. On many contemporary models I can see the rabbet around the port opening. On others still there is no rabbet. I can only assume there wasnt and standard with this. Maybe some sort of buckler was used rather than a port lid. But then why some models without a rabbet.
I have yet to decide if I should show this feature of a rabbet around the sides and bottom of the port openings.
Cheerful in the rogers collection has them
This contemporary model does not...except at the bottom maybe...
All of the others from this period that I have seen have no rabbets.
Any thoughts or research out there to help me in my decision? Thanks in advance.
- WackoWolf, Archi and Elmer Cornish
- 3
Today I wanted to get the crappy part out of the way. What a mess. Fairing the outside of the hull before I start putting in the port sills.
Lots of saw dust. You folks are very familiar with this. Even with a smaller hull it took the whole day. This is the single most important part of the project. Unfortunately because its such a pain its easy to understand why people rush through it only to have issues later on.
At the bow is the usual "Bow filler piece" and a few horizontal pieces which is where the forward port will reside. Fairing the bow was challenging. Whenever you think its done...its really not. This is easy to spot using a batten. I dont angle my rabbet for the planking until this stage. And its important. Most folks angle the rabbet before gluing the bulkheads into the former. But I can never get the angles right. Its easier for me to visualize when fairing the bow and inserting battens every now and again to see how they fit.
Before fairing
After a good start at fairing the bow. Notice how the bulkhead former within the rabbet is faired to match the angle of the bow filler after its faired. If you dont do this then the plank wont fit nicely into the rabbet and defeats the purpose of having one to begin with. This is what takes lots of time. Small chisels nd sanding sticks...the usual suspects to do it. I am using the laser char on the bulkhead edges to check how the fairing is progressing as I work towards mid ship. Then I switch around and work from the stern to midship again to complete the fairing.
Here are some battens added to check the run of the port sills. There are laser reference marks on each bulkhead as is usually the case. After some careful adjustments the top of the batten was marked off on each bulkhead edge to indicate the top of the port sills. Notice how the batten fits into the rabbet and because of how its faired, I didnt have to even pre bend this strip. It lays in there perfectly and no pins are used to hold it in the rabbet. That will make planking so much easier.....which would have been a fight if I didnt take my time with this fairing. I am gald its all done, but I can still see some spots...
Tomorrow I will add the port sills and port framing before starting on the stern framing.
- Archi, Elmer Cornish, sonicmcdude and 21 others
- 24
HM Cutter Cheerful 1806 by Chuck - FINISHED - 1:48 scale - kit prototype
Thanks guys
Rusty it will be basically the same. Except in this case the original planking expansion did show one drop plank at the bow. I am basically replicating that draft exactly. So I will include that drop plank and then divide the bottom of the hull into belts. But only two this time. Then I will line off the hull before moving forward with the planking.
Heres what the hull looks like after those two planks were added between the molding and the wales. I only darkened the seams where it will eventually be noticed. This helps if I need to tweak the placement of the second layer for the wales and molding. Without the seams darker its easier to move the second layer without folks noticing.
You will notice the darker wales. This was just a sheet of boxwood I had that was noticeable darker. I figured what the heck, I might as well use it for the wales. Its going to be painted anyway. It also helps me visualize the run of the wales as I plank above them.
