Everything posted by gjdale
I agree - absolutely worth the wait! Looking very spiffy there Timmo.
- 366 replies
- granado
- caldercraft
Fantastic job on the brickwork Augie - but then again, should we expect anything less from you? Well done Sir!
- 2,191 replies
- confederacy
- Model Shipways
Enjoy your vacation Anja and I look forward to seeing a resumption of your lovely Half Moon when you return.
Looking fantastic Mobbsie. The re-work on the topmast and royal stays looks much better - well done! By the way, nice looking blocks And when you-know-who arrives, we expect nautical pictures from the Lake District.
- 1,279 replies
- agamemnon
- caldercraft
HMS Royal William by kay
gjdale replied to kay's topic in - Build logs for subjects built 1501 - 1750
Nice to see you back Kay. Looking forward to more updates of your excellent build. -
what is the ideal modelling table?
gjdale replied to AON's topic in Modeling tools and Workshop Equipment
Nicely done Alan. When do you start taking orders? -
Nice work Pops - and there's no such thing as "cheating"!
- 132 replies
- 18th century longboat
- model shipways
Okay, so here's the photos that I didn't get to take last night. I'm still experimenting with the photography, but the pics seem to be getting better. First up, I made a "handle" from copper wire and looped it through the gunwales to provide a handhold while painting. It also served as a holding post for the vice while the paint dried: Here is the current state of play with painting. Probably just one or two clear coats of Dull Cote for protection now: Meanwhile, progress with the Cutters (well, one of them anyway): Here's the keel: And with frames placed in the building board and frame "plugs" inserted (as per the Launch): And without the Plug: Finally, here's a couple of shots of both the Pinnace and Cutter Plugs for comparison. They are really quite different hull forms: The Admiral is giving me "the look" again, so that's it for now!!!
Thanks everyone for all the kind comments and also for all the "likes". mtdoramike - your model is a similar scale to this one, maybe an inch or two longer, so you should have no problem with a similar case if you choose to go down this route. Mine is 1200mm long (about 48inches) and is made from 4.5mm thick Perspex. I would have liked to have used 6mm for added rigidity, but that would have added 50% more to the already expensive cost. Short progress report on the ship's boats. I have been slowly but surely painting the external hull of the Pinnace - just applied the ninth coat. I'm thinking maybe one more coat and then a final protective coat of Dull Cote. Following others advice, I've been using very thin coats of paint. I'm using a Humbrol enamel thinned 50% with Thinner. While tedious, it does seem to improve the appearance. While watching the paint dry, I've been progressing the framing for the two 25ft Cutters. I finished cutting the keels for both today, and have cleaned up all the frames. This took quite some effort. Releasing the spot-glued frames from their inner supports required the judicious use of the isopropyl alcohol - judicious because the frames are laminated and too heavy a hand with the IPA and I might just have twice as many frames! Once separated and dry, the remaining glue residue had to be cleaned off using a needle file and a very light touch - these things are REALLY fragile. Only broke two. Once cleaned up, I started fitting the frames into the build boards. One set is complete and the other ready to fit. The Admiral kicked me out of the shipyard before I could finish the second set. Something about needing to go to sleep as tomorrow is a work day! Consequently, I didn't get time to take some pictures. Sorry Sjors I'll try to get some taken tomorrow and post them up then.
I've recently been thinking along very similar lines Remco. Great to see your ideas brought to fruition - looks very ship shape.
- 1,207 replies
- sloop
- kingfisher
Just lovely Toni. A real pleasure to watch this build growing.
- 1,449 replies
Well done on the re-do Michael. I'll bet you're much happier with this version.
- 372 replies
If you're even thinking about re-doing Michael, then I would go ahead and do so. If you don't, it will continue to bug you for the rest of the build. And it will give you the opportunity to try it with the grain oriented correctly. Go on.........you know you want to..............
- 372 replies
Hi David, At the risk of pushing a point, you could have a crack at scratch building the Cutters. It's really not that difficult. Anyway, enough said. Your build, your decisions. Your ship looks excellent as it is.
- 439 replies
- victory
- caldercraft
Nice fixes Michael, until ............. oops! A timely reminder about understanding the properties of wood and the importance of grain direction. I'm sure this one will stick with you! You're doing a great job here Michael. Don't let theses minor setbacks get you down. Mistakes are how we learn best. Of course, if it's someone else's mistakes, then all the better!
- 372 replies
Ah the challenges of model ship building! I look forward to seeing your solution(s) to your current dilemma Michael.
- 372 replies
Ah, so I gather that the "Taj Ma Chook" is all completed now! Good to hear you also had a positive experience with Cornwall Model Boats - that certainly reflects my own experience. If the figures aren't the right size for this build, there's always the next one, or the next, or............... Planking seems to be going well. Don't forget that steam can be really useful for bending planks in addition to soaking. Any old steam iron will do - just not the one you are about to press your nice new white shirt with!
Very nice indeed Augie. As I recall, Remco did a rather magnificent job of the brickwork for the stove on his Swan class - there may be a few tips to pick up there as well.
- 2,191 replies
- confederacy
- Model Shipways
