cog
Everything posted by cog
  1. I am acquainted with the time problem. As long as you can make progress from time to time it's alright. Difficulties arise when the build turns stagnant ... looks good, I like the black at the bottom of the structures, makes them seem to float above the decks
  2. Always nasty those self moving chairs. You never know when they take off. Glad it's mainly your pride which has been hurt.
  3. Maybe some time has passed, but it is worth the wait. I like the crowsnest and how you build it. Lovely detail as usual
  4. Good , you are back. I nearly started missing you 'round here. What size/width do you make your treenails?
  5. Keep it in the dark ... nice work Jan
  6. Welcome to MSW, Robert. A Very nice build. I'll certainly follow your progress
  7. LEGO-man is some what rigid anyway, not an asset when it comes to steering
  8. Dick, I just wonder, wouldn't it be more logical that depending on the lee side the rudder on that side would be used, as the other one wouldn't give enough steerage way, Which in turn would imply druxey's rower (nice touch by the way) wouldn't be able to row, as the horizontal bar would be much, much shorter
  9. You got out from underneath the table! Did you find all that there?? A truely lovely collection of deck furnishings and furniture, Nenad. You have come quite a way, lovely detail, certainly at tthat scale
  10. Knowing you, Mike, you'll get there sooner than later. Look forward to your progress
  11. Hello Mike, Good to see you work your magic. Thanks for the magnet tip, I'll have to remember that one, will also come in handy on my regular workbench Yes it does, for you remove all moisture, and the longer you heat the wood, the further inside the moisture will be "vaporised", and the wood will turn brittle and break. By heating the wood you change the cell structure, and if you do it long enough you burn the cell's wall due to heat, and lack of moisture.
  12. But for the "loose ends" a really stunning build, Johann
  13. Yes you should, can you make a video from the way you did it
  14. Whilst you wrap your head around (what paper do you use?) ... most POB builds have the curving part of the stern as a shaped block of wood, on which the planks can be glued ... you may consider the same method
  15. I know of powder boys, youngsters running to and fro from powder magasin to gun, never read anything about youngsters and shot, interesting
  16. druxey, that depends largely on the number of hairs, you will use, and the length, I was thinking in the line of two to three. Furthermore, my experience with enamels and saber ... not good for the long term, acrylics, I haven't used that long enough to be able to form my opinion
  17. Another option is to cut some hairs from another brush and glue those to yancovitch's toothpick
