Everything posted by cog
Wonderful work, as Jan wrote: Life like details. I am very much taken by your brass work. Well done
- 193 replies
- wilhelmina vii
- fishing
Brittish/Australian Navy WWII V&W-class destroyers were blue as well, e.g. HMAS Vendetta (1944), HMAS Stuart I00 (1942-2, 1945), HMAS Warramunga I44 (1943), and some Pacific located battleships e.g. HMS Duke of York, HMS Anson . These had a blue rectangle on the side. Very nice details, Greg. The PE makes the model come to life ...
No hazards wheather wise here, John, this is the wet part of the globe. Although it seems a bit strange to wish a happy new year when those are "threatened" by fire/smoke. Dispite the former I hope you and yours will have a very happy and healthy 2020, and I hope to enjoy the fruit of your modelling endeavours
HMCSS Victoria 1855 by BANYAN - 1:72
cog replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Pat, those skylights look marvelous, you should take scale into account, and not mix up realism, with reality. Somehow modellers seem to think they can recreate at a small scale up to some tiny detail which would hardly be visible on an enlarged image of the real thing. You can be proud of your creation. Your deck is filling up nicely!- 1,021 replies
- gun dispatch vessel
- victoria
Derek, A drawplate is used to make round dowels at certain sizes, you "draw" a squarish piece of wood through a hole in the metal plate. At least that is what the drawplates used on MSW are applied for in general Parallel pliers are pliers of which the beak is bent. When you open the beak, the distance between the tip of the beak up to the curvature, will be equal over that length, instead of getting smaller over it's entire length nearing the swivel point. The advantage is you get equal grip on that part of the plier
Lovely progress Dan. The red does indeed accentuates the cutted edges, so ithose do not look like something partly finished. Looking forward to the "under ground" merry X-mas & all the best for the new year to you and yours
- 238 replies
- leviathan
- troop ship
Roger, Wouldn't that create large tears in the bulkheads (once you get there) Usually those rasps are a wee bit rough for this. Besides, there is the difference between the hard and the soft wood which could deliver a surprising effect whilst rasping. It's just a thought as I have no experience with rasping the combination, and am used to cutting soft wood like balsa (with a knife) if I need to take off slivers, and sand the last bit
Take care, we'll be waiting ... even if you need utill next year. Getting better is of primary importance
- 52 replies
- artesania latina
- titanic
Can i live without a BYRNES TABLE SAW
cog replied to shihawk's topic in Modeling tools and Workshop Equipment
What's 16 days on a modellers life. You can still saw your wood the old way Once you have used the Byrnes ... you suddenly can't anymore, it is very odd You mean you can't argue ... with her -
Have a look at some of @kees de mol's builds. He has made some plastick scratch builds which may help out
It can be, however, we loose more and more knowledge on the use of so called "craftmanship"
As per your usual, very lovely and crisp details, especially at the scale you work Interesting mobile laser cutter. Concerning the vector driver, does the cutter support the required software? For just the driver might just not be sufficient to get it working with vector graphics. Keep us informed on your findings please
Thanks G.L. Darn, Dutch block? I just changed from ISP, I still have access to the net from my old one, which gives the same result
- 599 replies
- sidewheeler
- arabia
(and 4 more)
As G.L. wrote: Fascinating! Can't wait for the next update. It is nice to see the difference in approach between you and Yves though building the same boat from the same kit. It shows you can do almost anything you want as a modeller in just as many ways. Most importantly, you, Yves, RGL, and many others show that Plastic isn't boring!
Unfortunately not visible for (continental) Europeans due to EC laws, that is to say, I get a big fat "Access denied" based on IP-address
- 599 replies
- sidewheeler
- arabia
(and 4 more)
